ebrithiljonas 5 Posted March 31, 2017 Posted March 31, 2017 Hello Emby Team I watch a lot of animes but only with the original soundtrack and subtitles, because German dubs really suck. So it would be really great if it is possible to select a default language for every library, so for example for Movies its German but for Animes its Japanese with German subs. I hope this would be possible. Greez Ebrithil
ebr 16337 Posted March 31, 2017 Posted March 31, 2017 Default metadata language for each library rather than sy...
Happy2Play 9812 Posted March 31, 2017 Posted March 31, 2017 You would have to change the default track flags in the embedded metadata (media info) which is totally different the the library language metadata.
Luke 42245 Posted March 31, 2017 Posted March 31, 2017 You would have to change the default track flags in the embedded metadata (media info) which is totally different the the library language metadata. Yes you're right, my mistake. Thanks.
