kanipek 230 Posted March 30, 2017 Posted March 30, 2017 (edited) So I updated to 3.2.9 thought everything looked good. Until I was editing recordings - Then I see that it recorded the same channel for all the recordings....that's right All I got was five separate copies of Shot Fired on Fox. The recording names are all correct the files are not. Tried watching a couple channels. All I got was Fox. Quick switched it back to 3.2.7 and all looked good. Logs are attached. Thanks for reading, and any help! server-63626418721.txt server-63626393955.txt server-63626418784.txt Edited March 30, 2017 by kanipek
Luke 42198 Posted March 30, 2017 Posted March 30, 2017 Thanks for the report. We are looking into it.
blade005 185 Posted March 30, 2017 Posted March 30, 2017 Thanks for the report. We are looking into it. @@Luke, Just posted my Recorded TV findings from last night in this thread https://emby.media/community/index.php?/topic/46368-my-hdhomerun-broke-somwhere-between-3289-and-32816/ in Live TV section.
maegibbons 1287 Posted March 30, 2017 Posted March 30, 2017 Hi This is probably the same as my report here: https://emby.media/community/index.php?/topic/46368-my-hdhomerun-broke-somwhere-between-3289-and-32816/&do=findComment&comment=436306 KRs Mark
Luke 42198 Posted March 30, 2017 Posted March 30, 2017 For those of you running the beta server, try 3.2.10.1 which just went up. Thanks.
kanipek 230 Posted March 30, 2017 Author Posted March 30, 2017 Further testing on v3.2.9: Viewing channels is normal from what I can tell. Until a recording kicks off then any channel I try to tune to is the same channel as what is recording. Sounds like similar behavior as noted by @@maegibbons and @@blade005. Also why am I now seeing ffmpeg transcode logs? I don't have any transcoding enabled (nor tuners to support). Is this from watching channels via the web client? (haven't really done that before) More bugs? I noticed on v3.2.9 that scheduling a recording has become different. From the guide when choosing a series to record (see attached) clicking "Series Record" once sets it to just "Record" (single episode), clicking it a second time enables "Series Record". Is this a bug? or new intended behavior? I am including a new log - I was doing some testing around 2pm Eastern Time. Thanks for reading and any help. server-63626462910.txt
blade005 185 Posted March 30, 2017 Posted March 30, 2017 For those of you running the beta server, try 3.2.10.1 which just went up. Thanks. @@Luke, Just tested 3.2.10.1 and it looks good. I just got six (6) Live TV streams up and running simultaneously on two (2) WebUI Clients, two (2) Android App clients and two (2) Emby Theater Desktop clients. Two (2) DLNA HDHomeRun tuners and one (1) older Non-DLNA HDHomeRun tuner. I also fired up four (4) simultaneous recordings and they all grabbed a separate tuner and recorded the correct channel. I have a recording lineup tonight that will tax this crossover of pre and post padding of various channels and will report back on results. Many thanks for such a quick response and fix.
