jnfoot 0 Posted March 29, 2017 Posted March 29, 2017 Hello, when I try to play a .ogm container it wont play. This is the Log: http://:8096/emby/videos/7a0d1028105e37845f7d875bf654ce9b/hls1/main/0.ts?DeviceId=2541c1ea3e2c5d62253bc71e2a42da5b&MediaSourceId=7a0d1028105e37845f7d875bf654ce9b&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1371316570&AudioBitrate=112001&Level=51&Profile=high&PlaySessionId=0ffa64eb40604e43b7091e7c740c73f7&api_key=3ca63d43563c455195eae35bd52b10dd&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=9051f73f77a80cd7388c425ab14ad92d&RequireAvc=true&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts&MinSegments=2 {"Protocol":"File","Id":"7a0d1028105e37845f7d875bf654ce9b","Path":"/mnt/sdb2/embyTVShows/[Anime-Supreme][Anime-Xtreme] .Hack SIGN (Dual Audio) DVDrip/[a-s]_hack_sign_01_-_role_play_v2__[ma]debito_dvd-rip__[0DA97021].ogm","Type":"Default","Container":"ogm","Name":"480P/MPEG4/VORBIS","IsRemote":false,"ETag":"9051f73f77a80cd7388c425ab14ad92d","RunTimeTicks":14234880000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"mpeg4","CodecTag":"XVID","TimeBase":"417083/10000000","CodecTimeBase":"2733/65534","Title":"[a-s].Hack//Sign - 01 - Role Play (Dual Audio) version 2","DisplayTitle":"[a-s].Hack//Sign - 01 - Role Play (Dual Audio) version 2","IsInterlaced":false,"BitRate":1242364,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":384,"Width":704,"AverageFrameRate":23.97602,"RealFrameRate":23.97604,"Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":-99,"IsAnamorphic":false},{"Codec":"vorbis","Language":"English","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"English VORBIS stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":112001,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"vorbis","Language":"Japanese","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"Japanese VORBIS stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":112001,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"text","Language":"English","TimeBase":"1/1000","CodecTimeBase":"1/1000","DisplayTitle":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":1466366,"RequiredHttpHeaders":{}} /usr/bin/ffmpeg -f ogm -codec:0 mpeg4 -codec:1 vorbis -codec:2 vorbis -i file:"/mnt/sdb2/embyTVShows/[Anime-Supreme][Anime-Xtreme] .Hack SIGN (Dual Audio) DVDrip/[a-s]_hack_sign_01_-_role_play_v2__[ma]debito_dvd-rip__[0DA97021].ogm" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 1242364 -bufsize 2484728 -vsync -1 -profile:v high -level 4.1 -level 41 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -codec:a:0 aac -strict experimental -ac 2 -ab 112001 -af "adelay=1,aresample=async=1" -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/d89db9631b30081f531a8a24f51ade31.m3u8" -y "/var/lib/emby-server/transcoding-temp/d89db9631b30081f531a8a24f51ade31%d.ts" ffmpeg version 2.8.11-0ubuntu0.16.04.1 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.4) 20160609 configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Unknown input format: 'ogm' when I try to play a .divx container it wont play. This is the Log: http://:8096/emby/videos/b8bc327bbae14768a7db8a365f27cd55/hls1/main/0.ts?DeviceId=2541c1ea3e2c5d62253bc71e2a42da5b&MediaSourceId=b8bc327bbae14768a7db8a365f27cd55&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=1599872000&AudioBitrate=128000&Level=51&Profile=high&PlaySessionId=c012fb10900d44b2bde5c1042aa1980f&api_key=3ca63d43563c455195eae35bd52b10dd&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=399be3b554dfd72b9f787310c2451fc7&RequireAvc=true&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts&MinSegments=2 {"Protocol":"File","Id":"b8bc327bbae14768a7db8a365f27cd55","Path":"/mnt/sdb2/embyTVShows/UFO.Files.Pack-FL/UFO Files - S01E01 - UFO Hot Spots.divx","Type":"Default","Container":"divx","Name":"SD/MPEG4/MP3","IsRemote":false,"ETag":"399be3b554dfd72b9f787310c2451fc7","RunTimeTicks":25953619968,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"mpeg4","CodecTag":"DX50","TimeBase":"100/2997","CodecTimeBase":"1/30000","Title":"Video ","DisplayTitle":"Video ","IsInterlaced":false,"BitRate":1000529,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":464,"Width":640,"AverageFrameRate":29.97,"RealFrameRate":29.97003,"Type":"Video","AspectRatio":"4:3","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":-99,"IsAnamorphic":false},{"Codec":"mp3","TimeBase":"1/16000","CodecTimeBase":"1/44100","Title":"Audio","DisplayTitle":"Audio","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":128000,"Channels":2,"SampleRate":44100,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":1140135,"RequiredHttpHeaders":{}} /usr/bin/ffmpeg -f divx -codec:0 mpeg4 -codec:1 mp3 -i file:"/mnt/sdb2/embyTVShows/UFO.Files.Pack-FL/UFO Files - S01E01 - UFO Hot Spots.divx" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 1000529 -bufsize 2001058 -vsync -1 -profile:v high -level 4.1 -level 41 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -codec:a:0 aac -strict experimental -ac 2 -ab 128000 -af "adelay=1,aresample=async=1" -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/1e24088d361c7807bd98821ac6454941.m3u8" -y "/var/lib/emby-server/transcoding-temp/1e24088d361c7807bd98821ac6454941%d.ts" ffmpeg version 2.8.11-0ubuntu0.16.04.1 Copyright (c) 2000-2017 the FFmpeg developers built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.4) 20160609 configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv libavutil 54. 31.100 / 54. 31.100 libavcodec 56. 60.100 / 56. 60.100 libavformat 56. 40.101 / 56. 40.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 40.101 / 5. 40.101 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 2.101 / 1. 2.101 libpostproc 53. 3.100 / 53. 3.100 Unknown input format: 'divx'
Solution Luke 42245 Posted March 30, 2017 Solution Posted March 30, 2017 hi @@jnfoot. Thanks for the report. This is resolved for the next release. 1
jnfoot 0 Posted March 30, 2017 Author Posted March 30, 2017 (edited) Thanks! Just updated my server, and this is working great again. Quick response and fix!!! Edited March 30, 2017 by jnfoot
