secagratis 21 Posted March 29, 2017 Posted March 29, 2017 many problems the server can not be updated if the restart does not restart I have to manually start the Clean Database remains at 45% if you do not scan media library me politely ending solve the issue through server-63626384368.txt
ebr 16309 Posted March 29, 2017 Posted March 29, 2017 Hi. That log doesn't appear to match up with that screenshot as the auto organize task is still running at the end of it and it doesn't cover much time at all (just a few minutes). Auto organize appears to be doing nothing but spitting out errors too so I would look into that configuration. I would also try removing some of the plugins installed and go from a clean slate to see if the problems persist. The dropbox plugin appears to be throwing an error on initialization as well.
secagratis 21 Posted March 29, 2017 Author Posted March 29, 2017 Off plug it keeps giving me errors log.txt
secagratis 21 Posted March 29, 2017 Author Posted March 29, 2017 if I click on the restart does not restart the server I have to start it manually
Luke 42198 Posted March 29, 2017 Posted March 29, 2017 The auto-organize scheduled task does not properly support cancellation. That's why you were unable to restart in the middle of it. We'll resolve it for the next release, thanks.
secagratis 21 Posted March 29, 2017 Author Posted March 29, 2017 so I have to wait for the next update? and I tell my users?
Luke 42198 Posted March 29, 2017 Posted March 29, 2017 No, if you're having trouble updating, just install the latest release the website.
secagratis 21 Posted March 30, 2017 Author Posted March 30, 2017 Now it is up to date but the problem is not solved logpro.txt
Luke 42198 Posted March 30, 2017 Posted March 30, 2017 I thought the problem was that you were trying to update but couldn't restart the server. So now that you have updated what exactly is the issue? Thanks !
secagratis 21 Posted March 30, 2017 Author Posted March 30, 2017 the problem that does not finish or Clean Database Scan media library and then does not put me new movies and TV series
secagratis 21 Posted March 30, 2017 Author Posted March 30, 2017 the problem that does not finish or Clean Database Scan media library and then does not put me new movies and TV series server-63626458431.txt server-63626458431.zip
secagratis 21 Posted March 30, 2017 Author Posted March 30, 2017 how to manually delete the Clean Database?
Happy2Play 9802 Posted March 30, 2017 Posted March 30, 2017 To me it looks like something isn't configured right with your library and sorting. Everything is unsortable. 2017-03-30 08:36:21.3739 Info App: Sorting file \\ipaddress\teampremium\szerie tv\La Famiglia Addams\La famiglia Addams - 2x16 - Lo Zio Fester, il magnate.mkv 2017-03-30 08:36:21.3895 Warn App: Unable to find series in library matching name La famiglia Addams
secagratis 21 Posted March 30, 2017 Author Posted March 30, 2017 (edited) even if I remove the TV series section does still makes me scan Clean Database Edited March 30, 2017 by secagratis
Luke 42198 Posted March 30, 2017 Posted March 30, 2017 Try removing the Kodi Sync plugin and you should see faster library scans. Thanks.
