PBzeer 6 Posted February 9, 2014 Posted February 9, 2014 Got the sorting figured out in my movies, but the playback sound volume is about half of what it is on everything else I use. I've looked on the computer, the server, mbc and in wmc for a relevant setting, but haven't found one. I'm running Win 7 pro 32-bit with conextant onboard sound (have updated drivers) on a laptop which I plug into my stereo (I'm on a boat, so it's a car unit). Had no problem with MB2 and volume, but I don't know what else to try. Added my music, mostly just to browse it, but in my Classical folder I have a few albums that won't sort to their sort title (edited them in the library on the server. The right sort title shows, and I even added the composers name at the beginning of the album title, but still they won't sort right.
ebr 16331 Posted February 9, 2014 Posted February 9, 2014 The right sort title shows The sort title isn't displayed anywhere except the metadata editor. Is that where you are talking about?
Koleckai Silvestri 1154 Posted February 9, 2014 Posted February 9, 2014 I believe you can boost audio in the LAV Audio settings.
PBzeer 6 Posted February 9, 2014 Author Posted February 9, 2014 The sort title isn't displayed anywhere except the metadata editor. Is that where you are talking about? Yes, in the metadata editor.
PBzeer 6 Posted February 9, 2014 Author Posted February 9, 2014 I believe you can boost audio in the LAV Audio settings. Not sure what you mean by LAV. (Mostly I know just enough to get myself in trouble)
Koleckai Silvestri 1154 Posted February 9, 2014 Posted February 9, 2014 It is one of the codecs used by MediaBrowser by default. Handles the internal playback. If you don't have LAV, you would have to look at your audio codecs.
PBzeer 6 Posted February 9, 2014 Author Posted February 9, 2014 Yes I have LAV. Didin't see anything that seemed volume related.though. I have the Codecs for Windows 7 Pack installed.
Koleckai Silvestri 1154 Posted February 9, 2014 Posted February 9, 2014 You can control channel levels under Mixing. This in turn affects the volume of those channels.
PBzeer 6 Posted February 9, 2014 Author Posted February 9, 2014 Only have 2 channels, but played with mixing anyway. As well as anything else that seemed likely. Nothing made a difference. Next step is re-rip a dvd keeping all sound options (I had been keeping only the highest).
PBzeer 6 Posted February 9, 2014 Author Posted February 9, 2014 Re-ripping with all available sound helped, but I still have to run at about 90% of volume.
PBzeer 6 Posted February 10, 2014 Author Posted February 10, 2014 Did some more checking. Hooked my portables with the VIDEO_TS folders back up, and volume is normal for them, so it would seem to be a problem with the MKV files. I rip the main title and all available sound (in English). Tried converting one to MPEG-4, didn't help any. Music plays fine, as do the VOB files. I guess the next thing to try is ripping the whole file to MKV .... which kinda defeats the whole point in using it.
Luke 42237 Posted December 7, 2020 Posted December 7, 2020 @PBzeer Support for composers is coming in Emby Server 4.6:
