kmartinka 3 Posted March 31, 2017 Author Posted March 31, 2017 Okay, is this something that will fixed in a later revision of Emby? I am unfamiliar with the built in live tv option since I have always used NextPVR with Emby. Does the built in version support DVR?
Luke 42243 Posted March 31, 2017 Posted March 31, 2017 If you have an HD Homerun then you don't need Next PVR.
kmartinka 3 Posted March 31, 2017 Author Posted March 31, 2017 Yes, I do have HD Homerun. I will try the internal Live TV option. Thanks again!
kmartinka 3 Posted March 31, 2017 Author Posted March 31, 2017 Okay, I uninstalled the NextPVR pluggin. Is there anything else that I need to do use the internal Live TV option?
Luke 42243 Posted March 31, 2017 Posted March 31, 2017 I would suggest checking out our Live TV wiki: https://github.com/MediaBrowser/Wiki/wiki/Live%20TV
