kmartinka 3 Posted March 25, 2017 Posted March 25, 2017 (edited) I am having a problem with TV recordings not showing up in any Emby client. I can see the TV recordings in the specified folder on the hard drive, so I know the recordings have occurred. My account is set to allow to view recordings. Emby Server - version 3.2.7.0 Emby Theater Client - version 2.5.40 Roku Emby channel Any suggestions? Edited March 25, 2017 by kmartinka
Luke 42243 Posted March 25, 2017 Posted March 25, 2017 Occasionally you might need to run a library scan, although we are working to make sure this isn't' required. But for now, please try that. Thanks !
kmartinka 3 Posted March 27, 2017 Author Posted March 27, 2017 I tried to perform a library scan, but unfortunately it did not help. I have also updated to the latest(3.2.8.15) beta server to see if this would help and it did not. I have tried on Windows client, Roku channel and web browser(I.E. and Firefox) and none of them do not show my recordings. I did realize that all my recordings are a "series" based recordings. Not sure if that helps. Should i submit a log file? Do you recommend a clean and reinstall of the server? Any other suggestions would be appreciated. Thanks again. I forgot to mention that I have one last last minor issue. I am unable to reset my password on one of the accounts. The cursor spins forever and password will not reset. This account is configured for Emby connect.
Luke 42243 Posted March 27, 2017 Posted March 27, 2017 What is the folder structure of the recordings library? is the recordings folder added to emby library setup?
kmartinka 3 Posted March 27, 2017 Author Posted March 27, 2017 (edited) Here is an example path to a recorded TV episode. "I:\Recorded TV\Series\Supernatural\Season 12\Supernatural S12E09 First Blood.mp4" The "Recorded TV" directory is in the Library. Hope this answers your questions. Edited March 27, 2017 by kmartinka
Luke 42243 Posted March 28, 2017 Posted March 28, 2017 with what content type is it setup in the library?
Luke 42243 Posted March 29, 2017 Posted March 29, 2017 In that case, you want to change it so that I:\Recorded TV\Series Is the path added to library setup.
kmartinka 3 Posted March 29, 2017 Author Posted March 29, 2017 (edited) The interesting thing is I did not create "Series" directory. I assumed that was created by the Emby server. I setup "I:\Recorded TV" in "Default recording path:" I did not setup a Series recording path as that is an option. Here is another interesting note. If I login Emby from Android, it has all my recordings in "Latest Recorded TV' on the Home tab, but not in the Recording in Live TV. Edited March 29, 2017 by kmartinka
Luke 42243 Posted March 29, 2017 Posted March 29, 2017 Yea but when Emby Server sets up that library, it uses the mixed content type. How it got forced to TV I am not sure.
kmartinka 3 Posted March 29, 2017 Author Posted March 29, 2017 Interesting. I will recreate the folder in the Library with mixed content type and see if that fixes my issue. If not, I will add the "I:\Recorded TV\Series" to the Library.
kmartinka 3 Posted March 29, 2017 Author Posted March 29, 2017 Unfortunately changing the content on Recorded TV to Unset did not resolve the issue. Also adding "I:\Recorded TV\Series" to the library(performed a Scan Library) did not work as well. I am out of ideas. Any other suggestions? Thanks again for the help.
kmartinka 3 Posted March 29, 2017 Author Posted March 29, 2017 Sorry, I missed your last reply. I am not sure what you are asking when you say "Let us know how you get on?" Do you mean logging into the Emby server?
Luke 42243 Posted March 29, 2017 Posted March 29, 2017 What does "does not work" mean? What do you see in the Emby web app? Can you show some screenshots? thanks.
kmartinka 3 Posted March 29, 2017 Author Posted March 29, 2017 Well, I expected that my recordings would show up in Recordings section under Live TV, but maybe that is not the intent of that area. Could you clear this up for me? But I am now seeing "Recorded TV" folder in the My Media section on the Home screen. That is a positive.
kmartinka 3 Posted March 29, 2017 Author Posted March 29, 2017 (edited) I expected my recordings to show up in the area below. Is this correct? Edited March 29, 2017 by kmartinka
Luke 42243 Posted March 30, 2017 Posted March 30, 2017 In order for that to happen, you'd also need to set that as your recorded tv folder in live tv settings.
Guest asrequested Posted March 30, 2017 Posted March 30, 2017 (edited) Here's how I have mine set. Three separate folders Then in Live TV settings, I set three different recording paths (the drive letters are different because they are mapped) The server will create three different libraries. My recordings then appear under 'Recordings' as well as the library I hope this helps Edited March 30, 2017 by Doofus
kmartinka 3 Posted March 30, 2017 Author Posted March 30, 2017 (edited) Thanks for the suggestions, but I already have a similar setup. Here is my live TV setup. Here is the Library entry that was created. Here is my Recordings in Live TV. (No recordings show up) But the recordings are showing up in my Recorded TV directory found on the Home page. I don't understand why it does not show up in Live TV Recordings. Edited March 30, 2017 by kmartinka
Guest asrequested Posted March 31, 2017 Posted March 31, 2017 That is a general place for everything you record. Try setting a path for recorded series, like I have. @@Luke, shouldn't they be in 'Recordings' in this instance?
Luke 42243 Posted March 31, 2017 Posted March 31, 2017 Have you installed any live tv plugins? If so, try removing them.
kmartinka 3 Posted March 31, 2017 Author Posted March 31, 2017 Thanks again for the suggestions. I have more information upon this issue. I tried to add a path for series and movies as suggested by Doofus, but that did not solve the problem. Then I uninstalled Live TV plugin -> NextPVR version 3.0.6143.20454 and this FIXED the issue. All my recordings are populated in 'Recordings'. Then I reinstalled the same plugin and the problem returned. Is this an issue with Emby or the author of the NextPVR plugin or me?
Luke 42243 Posted March 31, 2017 Posted March 31, 2017 Emby Core. We are just not giving enough testing to simultaneous use of both built in live tv + external via plugin.
