genesisforlive 7 Posted March 25, 2017 Posted March 25, 2017 (edited) Hi, i use Emby a lot und for early one ore two jears. i use the emby apps for the app connection over https and it works for a long time. but since, i think any month no connection over https possible. i try it with a new clean installation und only test the connection local over https, but no connection are possible (windows app, ios app) but over the browser it works correctly. what can i do? when i Connect no enty in the logs.... ps: local from the same maschine over the emby theater no connection.... the error: connection Failure we,re unable to connect to the selected........ http works fine greets Edited March 25, 2017 by genesisforlive
pir8radio 1313 Posted March 25, 2017 Posted March 25, 2017 What are you entering as the host information? most of the clients require you to enter "https://" ahead of the host info.
genesisforlive 7 Posted March 25, 2017 Author Posted March 25, 2017 i try all, but it works before month with https://(IP or DNS) Port
Luke 42198 Posted March 25, 2017 Posted March 25, 2017 What Emby app are you connecting from? Are you using the default self-signed cert or is this your own cert?
genesisforlive 7 Posted March 25, 2017 Author Posted March 25, 2017 What Emby app are you connecting from? Are you using the default self-signed cert or is this your own cert? i use my own and i use the default nothink work to connect vom app APP: emby theater win10, Emby for IOs, emby for FireTV only http works
Luke 42198 Posted March 25, 2017 Posted March 25, 2017 Can you please attach an emby Server log? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
genesisforlive 7 Posted March 25, 2017 Author Posted March 25, 2017 Can you please attach an emby Server log? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks ! Hi, there are nothink in the serverlogs and nothing in the emby theater logs. i check this before, thats the Problem no informations are logt you can try a complete clean installation, and i cannt connect to the server over any app but browser works fine.
Luke 42198 Posted March 25, 2017 Posted March 25, 2017 I am asking for this information so that I can try and help you. Thanks !
genesisforlive 7 Posted March 27, 2017 Author Posted March 27, 2017 I am asking for this information so that I can try and help you. Thanks ! Here all logs from the fresh Install i have try verios ports and verios konfigs dont works Logs.zip
