sse450 2 Posted March 25, 2017 Posted March 25, 2017 (edited) I love Emby. But, I have never got subtitle encoding correctly and almost given up on this issue until I read a thread posted a couple of weeks ago (https://emby.media/community/index.php?/topic/45316-subtitle-encoding-problem-with-addon-mode-on-kodi-17/). It raised my hopes for a solution. My setup is Emby Version 3.2.8.11 beta on a Centos server. When I connect to Emby server through the Emby web interface, the subtitle encoding is wrong. If you want to see the examples, please refer to the thread link posted above as it is exactly the same problem. It seems, the encoding of subtitle is ISO 8859-9, but Emby is treating it as ISO 8859-1. As far as I know, there is no encoding setting in Emby server. I would appreciate if you kindly help me in setting up this encoding issue. TIA. Edited March 25, 2017 by sse450
Luke 42246 Posted March 25, 2017 Posted March 25, 2017 @@sse450 can you please provide an example? Are they external subtitles?
sse450 2 Posted March 26, 2017 Author Posted March 26, 2017 @@sse450 can you please provide an example? Are they external subtitles? This is what I get through the web interface: http://prntscr.com/eoklnf This is the one with correct character encoding: http://prntscr.com/eokmqk Yes, these are external subtitles, be it downloaded by Emby or uploaded manually. As far as I understand, It seems, Emby server on Windows has no such an issue as indicated and solved by the thread given in the first post. Thanks.
sse450 2 Posted March 27, 2017 Author Posted March 27, 2017 The template is as below (downloaded by Emby from opensubtitles.org): Movie: XXX.mp4 Srt: XXX.tur.srt
meridyen 0 Posted March 30, 2017 Posted March 30, 2017 (edited) Same issue appeared here with both web client and Apple Tv. on my side it started after latest update to 3.2.9 . There was no problem yesterday with previous version 3.2.8. Edited March 30, 2017 by meridyen
Luke 42246 Posted April 9, 2017 Posted April 9, 2017 @@meridyen, can you please discuss a specific example? Are these external subtitles? If they are external, can you please zip them up and attach them? Thanks !
meridyen 0 Posted April 9, 2017 Posted April 9, 2017 (edited) @@Luke I found out that it is ANSI related problem and i have started to save the files as UTF-8 if it is ANSI. Attached is the sample file. Anthropoid.2016.1080p.BRRip.x264.AAC-ETRG.tur.zip Edited April 9, 2017 by meridyen
Luke 42246 Posted April 14, 2017 Posted April 14, 2017 @@meridyen, you're saying this was in the web app? This particular example appears to be working just fine out of the box for me....
meridyen 0 Posted April 14, 2017 Posted April 14, 2017 @@meridyen, you're saying this was in the web app? This particular example appears to be working just fine out of the box for me.... @@Luke if above is how its look out of the box, that is what i am talking about. Characters are not right. Try to save the file as UTF-8 and play the movie again, you will see the correct one. By the way, It is not just on web player but also on apple tv too.
Luke 42246 Posted April 14, 2017 Posted April 14, 2017 Are you sure? it looks identical to how notepad++ presents it.
meridyen 0 Posted April 17, 2017 Posted April 17, 2017 @@Luke pictures below are showing the results of same screen one with ANSI and the other utf-8
Luke 42246 Posted April 18, 2017 Posted April 18, 2017 Ok, I've got this resolved for the next release, thanks.
sse450 2 Posted July 4, 2017 Author Posted July 4, 2017 I am the OP of this thread. I was away from the forum for some time. Just updated my Emby server to 3.2.20.14. I see that the issue I reported is gone. Luke, I am grateful for your support. Thank you very much.
Oguzhan 0 Posted September 14, 2018 Posted September 14, 2018 I am the OP of this thread. I was away from the forum for some time. Just updated my Emby server to 3.2.20.14. I see that the issue I reported is gone. Luke, I am grateful for your support. Thank you very much. Hi ı dont understand still problem valid. There is no settings on LG tv side for encode external subtitle.
Luke 42246 Posted September 14, 2018 Posted September 14, 2018 @@Oguzhan can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
Oguzhan 0 Posted September 14, 2018 Posted September 14, 2018 @@Oguzhan can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks ! Hello I check information and this is the right topic for this. I didn't want to open another topic for same problem. Also as mentioned external subtitles creates problem on DLNA Tv. Is it possible to add encode settings. Thanks
Luke 42246 Posted September 14, 2018 Posted September 14, 2018 You can post here, but I would still like to go over an example using the information requested in the link above. We're happy to help, but we need you to help us first in understanding the scenario. Thanks.
Oguzhan 0 Posted September 14, 2018 Posted September 14, 2018 As you see on attachment when u select external sub sub works without transcoding this part ok. But some of letters has problem because of sub encoding. This sub has to be 'Ne yapıyorsun' but its wrong. Need UTF 8 or windows 1235 coding or something like that for right meaning. if you ask my opinion ıt must be one setting where we can adjust sub encoding. Thanks.
Luke 42246 Posted September 14, 2018 Posted September 14, 2018 What kind of subtitles? Internal or external? What format subtitles? If they are external, what is the filename of both the video and subtitles? Thanks.
Oguzhan 0 Posted September 14, 2018 Posted September 14, 2018 What kind of subtitles? Internal or external? What format subtitles? If they are external, what is the filename of both the video and subtitles? Thanks. Subtitles external. Subtitle format srt. Film name and subtitle name same. Fury and Fury.srt Thanks.
Luke 42246 Posted September 14, 2018 Posted September 14, 2018 Try following our subtitle guide to rename the subtitles to include the language: https://github.com/MediaBrowser/Wiki/wiki/Subtitles Then run a library scan. In the vast majority of cases this will resolve it because the server can use the language to guess the encoding when it can't be detected from the file.
Oguzhan 0 Posted September 14, 2018 Posted September 14, 2018 Try following our subtitle guide to rename the subtitles to include the language: https://github.com/MediaBrowser/Wiki/wiki/Subtitles Then run a library scan. In the vast majority of cases this will resolve it because the server can use the language to guess the encoding when it can't be detected from the file. I tried with fury.tr.srt it works now ok. But it makes transcoding how can I make direct play without transcoding.
Luke 42246 Posted September 14, 2018 Posted September 14, 2018 Can you please attach the ffmpeg log? Instructions on how to do that are in the link I provided earlier. Thanks.
