Subtitle rendering problems fixed by updated VSFILTER.DLL
I have found a few movies in the past having green subtitles that were barely legible and last night found another movie I had that did it.   On every player ET client...so I knew it wasn't just a problem with one.
Switch to MadVR, and the subtitles worked perfectly on all the clients so I knew it was a filter issue (but it ran like crap so that wasn't an option for me) and not a problem with the media file either. With a quick version check and a search found vsfilter.dll with version 3.0.0.306 (vs the 3.0.0.211 that comes with ET) and that fixed it on all clients.
It (like all my movies) was a BDR remuxed lossless to MKV with PGS subs if that makes a difference...but there is something in the changelog for vsfilter that might be relevent. Not sure but it fixed my problem, so I am happy at that.    https://github.com/Cyberbeing/xy-VSFilter/releases
Perhaps the newer file should be included in ET?
Anyhow...not sure if this has been reported or is an issue for anyone....just wanted to mention my experience and solution.   :)
Edited by jbl77
  • Like 2
Hi @@jbl77, thanks for the info !
You're welcome :)
