Dreamypat 0 Posted March 24, 2017 Posted March 24, 2017 Hi. I've installed the latest codec pack on my daughter's pc and some films have bad like a jerky picture which stays the same but audio is okay. Any idea what it could be as the same film (Angry Birds the movie) runs okay on mine. Her's is running Window 7 and mine is windows 10. Thanks
Guest asrequested Posted March 24, 2017 Posted March 24, 2017 (edited) Theater uses its own codecs and filters. What are settings in Theater? And where did you get the app from? Edited March 24, 2017 by Doofus
Dreamypat 0 Posted March 25, 2017 Author Posted March 25, 2017 Emby Theatre app but also the same running through the browser
Guest asrequested Posted March 25, 2017 Posted March 25, 2017 That sounds more like a transcoding issue. Try playing one, and look in the server dashboard to see if it's transcoding.
Luke 42243 Posted March 25, 2017 Posted March 25, 2017 Yes that would be good information to find out, thanks.
