Larry SA 3 Posted March 24, 2017 Posted March 24, 2017 Anybody else unable to change the language on emby after update to 3.2.7.0
Larry SA 3 Posted March 26, 2017 Author Posted March 26, 2017 So whats wrong with my version? Will try a reinstall.
Luke 42198 Posted March 26, 2017 Posted March 26, 2017 Can you describe what is happening in more detail? Thanks !
Larry SA 3 Posted March 26, 2017 Author Posted March 26, 2017 So updated to latest beta 3.0.28.13 did not help. Found the problem... Seems Emby Theater on Xbox One was controlling the language it was set to Portuguese. Changes on server made no difference. Once I uninstalled Theater on the Xbox One then reinstalled Theater. Changed the langue in Theatre to English and it worked. Checked server and the language changed on the server also.
Luke 42198 Posted March 26, 2017 Posted March 26, 2017 Each app has it's own language setting in order to allow it to respect any settings on the device. In the future if you provide more detail up front you will get a much faster solution. Thanks.
Larry SA 3 Posted March 26, 2017 Author Posted March 26, 2017 Had no clue Theater language was changed. I just noticed the server langue was not the same as what was chosen in the options. So i thought the problem must be server based. Could have been changed by the kids. Will never know. But hey its fixed now. Just found it strange that the language in theater affected the language on server. Thanks for your help.
