dcook 303 Posted March 24, 2017 Posted March 24, 2017 I have in my server Intel Haswell which from what I understand supports Intel Quicksync. Do I simply need to select Quicksync in the Hardware Acceleration section of the Emby Dashboard? Or do you need to configure something on the server first to make it work? I am running Centos 7
mastrmind11 722 Posted March 24, 2017 Posted March 24, 2017 you need an ffmpeg build that supports qs. You can see in your log when the server first comes up whether qs is supported by ffmpeg or not. I think vainfo on the command line does it too (can't check as I'm not at home). Pretty sure CentOS supports it natively so I don't believe you need to build a new kernel or anything..
Guest plexman Posted March 31, 2017 Posted March 31, 2017 Try VAAPI, it is easier to configure with the same results.
