Seexelas 0 Posted March 24, 2017 Posted March 24, 2017 Hi guys, I just installed Emby on my NAS and i'm quite pleased with the results. The one issue I'm facing and when i addind my own ssl certificate, the emby server won't respond in https, when using the self generated cert, i have no issue. By the way there is no place to put the private key for the cert ? Thanks for the help,
Luke 42240 Posted March 24, 2017 Posted March 24, 2017 Right, there is currently no place for it and that probably explains your issue. thanks.
newb 14 Posted April 1, 2017 Posted April 1, 2017 Hi guys, I just installed Emby on my NAS and i'm quite pleased with the results. The one issue I'm facing and when i addind my own ssl certificate, the emby server won't respond in https, when using the self generated cert, i have no issue. By the way there is no place to put the private key for the cert ? Thanks for the help, Hi Seexelas, It should work if you point Emby to a .pfx file which includes the private key and is not password protected. Just make sure you can export your certificate in such a format. Sent from my SM-G935F using Tapatalk
