dcook 303 Posted March 24, 2017 Posted March 24, 2017 Any ideas on how I can make ffmpeg use less cpu? When this capture was taken, there was only 1 stream going on the server The video in question is a 1.3GB MKV file, so its not huge I have 4 x Intel® Xeon® CPU @ 2.30GHz in the VM currently The FFMPEG version is the one that is installed with the Emby server, should I Install a different version? FFMPEG log: http://myserver.com:8096/emby/videos/7949b9b48219611c6224d5e78f6c5b1a/live.m3u8?DeviceId=6f0e60bf-c0b7-524b-ab0a-53088fadf73c&MediaSourceId=7949b9b48219611c6224d5e78f6c5b1a&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=1690353&AudioBitrate=192000&MaxFramerate=61&MaxWidth=3840&MaxHeight=2160&Level=51&MaxRefFrames=16&MaxVideoBitDepth=8&Profile=high&PlaySessionId=0758d8e584e64774a2b21463230c3fec&api_key=f41b26db7f5a4d02b1ba511f5dab326c&CopyTimestamps=false&TranscodingMaxAudioChannels=2&EnableSubtitlesInManifest=false&Tag=79b360cf2d3dcd2da9d3dbb42c3d3b89&RequireAvc=false {"Protocol":"File","Id":"7949b9b48219611c6224d5e78f6c5b1a","Path":"/emby/media/series/Big Brother (CA)/Season 5/Big Brother Canada - 5x04 - Veto #2.mkv","Type":"Default","Container":"mkv","Name":"","IsRemote":false,"ETag":"79b360cf2d3dcd2da9d3dbb42c3d3b89","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}} /var/lib/emby-server/ffmpeg/20160215/ffmpeg -f matroska -i file:"/emby/media/series/Big Brother (CA)/Season 5/Big Brother Canada - 5x04 - Veto #2.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 1690353 -bufsize 3380706 -vsync -1 -profile:v high -level 4.1 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -flags -global_header -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -codec:a:0 libmp3lame -ac 2 -ab 192000 -af "adelay=1,aresample=async=1" -hls_time 3 -individual_header_trailer 0 -start_number 0 -hls_list_size 0 -hls_base_url "hls/0f4dd00fad9c020092f5cdb758600e61/" -y "/emby/temp/transcoding-temp/0f4dd00fad9c020092f5cdb758600e61.m3u8" ffmpeg version N-52954-g295de3e-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.1 (Debian 5.3.1-8) 20160205 configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --enable-librtmp --enable-libmfx --cc=gcc libavutil 55. 17.103 / 55. 17.103 libavcodec 57. 24.102 / 57. 24.102 libavformat 57. 25.100 / 57. 25.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 31.100 / 6. 31.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:/emby/media/series/Big Brother (CA)/Season 5/Big Brother Canada - 5x04 - Veto #2.mkv': Metadata: encoder : libebml v1.3.4 + libmatroska v1.4.5 creation_time : 2017-03-23 06:47:55 Duration: 00:44:02.34, start: 0.000000, bitrate: 3964 kb/s Stream #0:0: Video: h264 (High), yuv420p(tv, bt709/unknown/unknown), 1280x720, SAR 1:1 DAR 16:9, 59.94 fps, 59.94 tbr, 1k tbn, 119.88 tbc (default) Metadata: BPS : 3577013 BPS-eng : 3577013 DURATION : 00:44:02.340000000 DURATION-eng : 00:44:02.340000000 NUMBER_OF_FRAMES: 158382 NUMBER_OF_FRAMES-eng: 158382 NUMBER_OF_BYTES : 1181460626 NUMBER_OF_BYTES-eng: 1181460626 _STATISTICS_WRITING_APP: mkvmerge v9.8.0 ('Kuglblids') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.8.0 ('Kuglblids') 64bit _STATISTICS_WRITING_DATE_UTC: 2017-03-23 06:47:55 _STATISTICS_WRITING_DATE_UTC-eng: 2017-03-23 06:47:55 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) Metadata: BPS : 384000 BPS-eng : 384000 DURATION : 00:44:02.272000000 DURATION-eng : 00:44:02.272000000 NUMBER_OF_FRAMES: 82571 NUMBER_OF_FRAMES-eng: 82571 NUMBER_OF_BYTES : 126829056 NUMBER_OF_BYTES-eng: 126829056 _STATISTICS_WRITING_APP: mkvmerge v9.8.0 ('Kuglblids') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v9.8.0 ('Kuglblids') 64bit _STATISTICS_WRITING_DATE_UTC: 2017-03-23 06:47:55 _STATISTICS_WRITING_DATE_UTC-eng: 2017-03-23 06:47:55 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [libx264 @ 0x43398a0] using SAR=1/1 [libx264 @ 0x43398a0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2 [libx264 @ 0x43398a0] profile Main, level 4.1 Output #0, hls, to '/emby/temp/transcoding-temp/0f4dd00fad9c020092f5cdb758600e61.m3u8': Metadata: encoder : Lavf57.25.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, max. 1690 kb/s, 59.94 fps, 90k tbn, 59.94 tbc (default) Metadata: encoder : Lavc57.24.102 libx264 Side data: unknown side data type 10 (24 bytes) Stream #0:1: Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: encoder : Lavc57.24.102 libmp3lame Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> mp3 (libmp3lame)) Press [q] to stop, [?] for help frame= 134 fps=0.0 q=31.0 size=N/A time=00:00:02.31 bitrate=N/A speed=3.79x frame= 253 fps=227 q=42.0 size=N/A time=00:00:04.37 bitrate=N/A speed=3.92x frame= 365 fps=224 q=37.0 size=N/A time=00:00:06.12 bitrate=N/A speed=3.77x frame= 481 fps=226 q=35.0 size=N/A time=00:00:08.11 bitrate=N/A speed=3.82x frame= 564 fps=214 q=31.0 size=N/A time=00:00:09.46 bitrate=N/A speed= 3.6x frame= 635 fps=202 q=36.0 size=N/A time=00:00:10.63 bitrate=N/A speed=3.39x frame= 707 fps=194 q=33.0 size=N/A time=00:00:11.91 bitrate=N/A speed=3.27x frame= 783 fps=189 q=38.0 size=N/A time=00:00:13.13 bitrate=N/A speed=3.17x frame= 860 fps=185 q=33.0 size=N/A time=00:00:14.40 bitrate=N/A speed= 3.1x frame= 934 fps=181 q=35.0 size=N/A time=00:00:15.65 bitrate=N/A speed=3.04x frame= 1008 fps=178 q=32.0 size=N/A time=00:00:16.97 bitrate=N/A speed= 3x frame= 1082 fps=176 q=35.0 size=N/A time=00:00:18.05 bitrate=N/A speed=2.93x frame= 1157 fps=174 q=34.0 size=N/A time=00:00:19.37 bitrate=N/A speed=2.91x frame= 1227 fps=171 q=43.0 size=N/A time=00:00:20.59 bitrate=N/A speed=2.88x frame= 1303 fps=170 q=43.0 size=N/A time=00:00:21.75 bitrate=N/A speed=2.84x frame= 1370 fps=168 q=35.0 size=N/A time=00:00:22.99 bitrate=N/A speed=2.81x frame= 1443 fps=166 q=35.0 size=N/A time=00:00:24.19 bitrate=N/A speed=2.79x frame= 1531 fps=167 q=31.0 size=N/A time=00:00:25.54 bitrate=N/A speed=2.78x frame= 1601 fps=165 q=40.0 size=N/A time=00:00:26.93 bitrate=N/A speed=2.78x frame= 1673 fps=164 q=35.0 size=N/A time=00:00:27.99 bitrate=N/A speed=2.75x frame= 1746 fps=163 q=33.0 size=N/A time=00:00:29.35 bitrate=N/A speed=2.74x frame= 1821 fps=163 q=37.0 size=N/A time=00:00:30.41 bitrate=N/A speed=2.72x frame= 1896 fps=162 q=41.0 size=N/A time=00:00:31.68 bitrate=N/A speed=2.71x frame= 1972 fps=162 q=35.0 size=N/A time=00:00:33.10 bitrate=N/A speed=2.71x frame= 2049 fps=161 q=31.0 size=N/A time=00:00:34.35 bitrate=N/A speed= 2.7x frame= 2128 fps=161 q=32.0 size=N/A time=00:00:35.69 bitrate=N/A speed= 2.7x frame= 2205 fps=161 q=38.0 size=N/A time=00:00:36.84 bitrate=N/A speed=2.68x frame= 2279 fps=160 q=34.0 size=N/A time=00:00:38.09 bitrate=N/A speed=2.68x frame= 2364 fps=160 q=32.0 size=N/A time=00:00:39.51 bitrate=N/A speed=2.68x frame= 2439 fps=160 q=35.0 size=N/A time=00:00:40.75 bitrate=N/A speed=2.67x frame= 2512 fps=160 q=37.0 size=N/A time=00:00:41.95 bitrate=N/A speed=2.66x frame= 2588 fps=159 q=32.0 size=N/A time=00:00:43.35 bitrate=N/A speed=2.67x frame= 2662 fps=159 q=40.0 size=N/A time=00:00:44.45 bitrate=N/A speed=2.65x frame= 2734 fps=158 q=38.0 size=N/A time=00:00:45.75 bitrate=N/A speed=2.65x frame= 2804 fps=158 q=36.0 size=N/A time=00:00:46.99 bitrate=N/A speed=2.65x frame= 2884 fps=158 q=33.0 size=N/A time=00:00:48.19 bitrate=N/A speed=2.64x frame= 2961 fps=158 q=38.0 size=N/A time=00:00:49.59 bitrate=N/A speed=2.64x frame= 3031 fps=157 q=38.0 size=N/A time=00:00:50.64 bitrate=N/A speed=2.63x frame= 3104 fps=157 q=32.0 size=N/A time=00:00:51.94 bitrate=N/A speed=2.62x frame= 3180 fps=157 q=31.0 size=N/A time=00:00:53.19 bitrate=N/A speed=2.62x frame= 3255 fps=157 q=34.0 size=N/A time=00:00:54.48 bitrate=N/A speed=2.62x frame= 3329 fps=156 q=31.0 size=N/A time=00:00:55.83 bitrate=N/A speed=2.62x frame= 3407 fps=156 q=31.0 size=N/A time=00:00:57.12 bitrate=N/A speed=2.62x frame= 3480 fps=156 q=36.0 size=N/A time=00:00:58.23 bitrate=N/A speed=2.61x frame= 3549 fps=156 q=33.0 size=N/A time=00:00:59.40 bitrate=N/A speed=2.61x frame= 3624 fps=156 q=36.0 size=N/A time=00:01:00.55 bitrate=N/A speed= 2.6x frame= 3699 fps=155 q=31.0 size=N/A time=00:01:01.83 bitrate=N/A speed= 2.6x frame= 3773 fps=155 q=36.0 size=N/A time=00:01:03.05 bitrate=N/A speed=2.59x frame= 3848 fps=155 q=35.0 size=N/A time=00:01:04.32 bitrate=N/A speed=2.59x frame= 3927 fps=155 q=37.0 size=N/A time=00:01:05.67 bitrate=N/A speed=2.59x frame= 4008 fps=155 q=31.0 size=N/A time=00:01:06.99 bitrate=N/A speed=2.59x frame= 4089 fps=155 q=31.0 size=N/A time=00:01:08.35 bitrate=N/A speed= 2.6x frame= 4166 fps=155 q=31.0 size=N/A time=00:01:09.55 bitrate=N/A speed=2.59x frame= 4245 fps=155 q=32.0 size=N/A time=00:01:10.90 bitrate=N/A speed=2.59x frame= 4326 fps=155 q=32.0 size=N/A time=00:01:12.36 bitrate=N/A speed= 2.6x frame= 4405 fps=155 q=31.0 size=N/A time=00:01:13.63 bitrate=N/A speed= 2.6x frame= 4481 fps=155 q=31.0 size=N/A time=00:01:14.86 bitrate=N/A speed= 2.6x frame= 4555 fps=155 q=35.0 size=N/A time=00:01:16.11 bitrate=N/A speed=2.59x frame= 4627 fps=155 q=31.0 size=N/A time=00:01:17.33 bitrate=N/A speed=2.59x frame= 4704 fps=155 q=33.0 size=N/A time=00:01:18.70 bitrate=N/A speed=2.59x frame= 4779 fps=155 q=32.0 size=N/A time=00:01:19.78 bitrate=N/A speed=2.58x frame= 4859 fps=155 q=31.0 size=N/A time=00:01:21.10 bitrate=N/A speed=2.58x frame= 4939 fps=155 q=34.0 size=N/A time=00:01:22.42 bitrate=N/A speed=2.58x frame= 5014 fps=155 q=37.0 size=N/A time=00:01:23.76 bitrate=N/A speed=2.59x frame= 5087 fps=155 q=33.0 size=N/A time=00:01:25.01 bitrate=N/A speed=2.58x frame= 5165 fps=155 q=32.0 size=N/A time=00:01:26.31 bitrate=N/A speed=2.58x frame= 5235 fps=154 q=37.0 size=N/A time=00:01:27.53 bitrate=N/A speed=2.58x frame= 5306 fps=154 q=37.0 size=N/A time=00:01:28.61 bitrate=N/A speed=2.57x frame= 5382 fps=154 q=35.0 size=N/A time=00:01:29.83 bitrate=N/A speed=2.57x frame= 5458 fps=154 q=41.0 size=N/A time=00:01:31.30 bitrate=N/A speed=2.58x frame= 5536 fps=154 q=31.0 size=N/A time=00:01:32.62 bitrate=N/A speed=2.58x frame= 5616 fps=154 q=31.0 size=N/A time=00:01:33.84 bitrate=N/A speed=2.58x frame= 5689 fps=154 q=32.0 size=N/A time=00:01:35.14 bitrate=N/A speed=2.58x frame= 5764 fps=154 q=35.0 size=N/A time=00:01:36.24 bitrate=N/A speed=2.57x frame= 5841 fps=154 q=37.0 size=N/A time=00:01:37.68 bitrate=N/A speed=2.57x frame= 5917 fps=154 q=38.0 size=N/A time=00:01:38.93 bitrate=N/A speed=2.57x frame= 5986 fps=154 q=40.0 size=N/A time=00:01:39.91 bitrate=N/A speed=2.56x frame= 6061 fps=154 q=33.0 size=N/A time=00:01:41.16 bitrate=N/A speed=2.56x frame= 6140 fps=154 q=32.0 size=N/A time=00:01:42.60 bitrate=N/A speed=2.57x frame= 6217 fps=154 q=44.0 size=N/A time=00:01:43.85 bitrate=N/A speed=2.57x frame= 6283 fps=153 q=48.0 size=N/A time=00:01:44.91 bitrate=N/A speed=2.56x frame= 6359 fps=153 q=37.0 size=N/A time=00:01:46.25 bitrate=N/A speed=2.56x frame= 6434 fps=153 q=34.0 size=N/A time=00:01:47.50 bitrate=N/A speed=2.56x frame= 6510 fps=153 q=41.0 size=N/A time=00:01:48.82 bitrate=N/A speed=2.56x frame= 6589 fps=153 q=37.0 size=N/A time=00:01:49.97 bitrate=N/A speed=2.56x frame= 6671 fps=153 q=40.0 size=N/A time=00:01:51.43 bitrate=N/A speed=2.56x frame= 6750 fps=153 q=37.0 size=N/A time=00:01:52.80 bitrate=N/A speed=2.56x frame= 6825 fps=153 q=38.0 size=N/A time=00:01:53.93 bitrate=N/A speed=2.56x frame= 6900 fps=153 q=31.0 size=N/A time=00:01:55.35 bitrate=N/A speed=2.56x frame= 6978 fps=153 q=31.0 size=N/A time=00:01:56.62 bitrate=N/A speed=2.56x frame= 7063 fps=153 q=31.0 size=N/A time=00:01:57.89 bitrate=N/A speed=2.56x frame= 7145 fps=154 q=31.0 size=N/A time=00:01:59.23 bitrate=N/A speed=2.56x frame= 7227 fps=154 q=31.0 size=N/A time=00:02:00.72 bitrate=N/A speed=2.57x frame= 7305 fps=154 q=31.0 size=N/A time=00:02:01.99 bitrate=N/A speed=2.57x frame= 7380 fps=154 q=39.0 size=N/A time=00:02:03.17 bitrate=N/A speed=2.56x frame= 7456 fps=154 q=38.0 size=N/A time=00:02:04.42 bitrate=N/A speed=2.56x frame= 7533 fps=154 q=31.0 size=N/A time=00:02:05.83 bitrate=N/A speed=2.56x frame= 7613 fps=154 q=32.0 size=N/A time=00:02:07.08 bitrate=N/A speed=2.56x frame= 7690 fps=154 q=34.0 size=N/A time=00:02:08.33 bitrate=N/A speed=2.56x frame= 7766 fps=154 q=38.0 size=N/A time=00:02:09.77 bitrate=N/A speed=2.57x frame= 7844 fps=154 q=32.0 size=N/A time=00:02:11.04 bitrate=N/A speed=2.56x frame= 7921 fps=154 q=37.0 size=N/A time=00:02:12.34 bitrate=N/A speed=2.56x frame= 8001 fps=154 q=39.0 size=N/A time=00:02:13.59 bitrate=N/A speed=2.56x frame= 8082 fps=154 q=33.0 size=N/A time=00:02:14.86 bitrate=N/A speed=2.56x frame= 8159 fps=154 q=33.0 size=N/A time=00:02:16.32 bitrate=N/A speed=2.57x frame= 8237 fps=154 q=36.0 size=N/A time=00:02:17.64 bitrate=N/A speed=2.57x frame= 8315 fps=154 q=37.0 size=N/A time=00:02:18.79 bitrate=N/A speed=2.56x frame= 8395 fps=154 q=36.0 size=N/A time=00:02:20.16 bitrate=N/A speed=2.57x frame= 8473 fps=154 q=35.0 size=N/A time=00:02:21.46 bitrate=N/A speed=2.57x frame= 8551 fps=154 q=40.0 size=N/A time=00:02:22.85 bitrate=N/A speed=2.57x frame= 8631 fps=154 q=36.0 size=N/A time=00:02:24.05 bitrate=N/A speed=2.57x frame= 8709 fps=154 q=36.0 size=N/A time=00:02:25.32 bitrate=N/A speed=2.57x frame= 8789 fps=154 q=34.0 size=N/A time=00:02:26.76 bitrate=N/A speed=2.57x frame= 8868 fps=154 q=37.0 size=N/A time=00:02:28.20 bitrate=N/A speed=2.57x frame= 8954 fps=154 q=35.0 size=N/A time=00:02:29.43 bitrate=N/A speed=2.57x frame= 9037 fps=154 q=34.0 size=N/A time=00:02:30.96 bitrate=N/A speed=2.57x frame= 9117 fps=154 q=37.0 size=N/A time=00:02:32.14 bitrate=N/A speed=2.57x frame= 9202 fps=154 q=32.0 size=N/A time=00:02:33.58 bitrate=N/A speed=2.57x frame= 9280 fps=154 q=33.0 size=N/A time=00:02:34.85 bitrate=N/A speed=2.57x frame= 9360 fps=154 q=45.0 size=N/A time=00:02:36.36 bitrate=N/A speed=2.58x frame= 9440 fps=154 q=36.0 size=N/A time=00:02:37.63 bitrate=N/A speed=2.58x frame= 9517 fps=154 q=35.0 size=N/A time=00:02:38.83 bitrate=N/A speed=2.58x frame= 9596 fps=154 q=40.0 size=N/A time=00:02:40.13 bitrate=N/A speed=2.58x frame= 9675 fps=154 q=46.0 size=N/A time=00:02:41.62 bitrate=N/A speed=2.58x frame= 9756 fps=154 q=31.0 size=N/A time=00:02:42.89 bitrate=N/A speed=2.58x frame= 9851 fps=155 q=31.0 size=N/A time=00:02:44.55 bitrate=N/A speed=2.58x frame= 9938 fps=155 q=31.0 size=N/A time=00:02:45.99 bitrate=N/A speed=2.58x frame=10016 fps=155 q=31.0 size=N/A time=00:02:47.23 bitrate=N/A speed=2.58x frame=10100 fps=155 q=31.0 size=N/A time=00:02:48.65 bitrate=N/A speed=2.59x frame=10189 fps=155 q=31.0 size=N/A time=00:02:50.07 bitrate=N/A speed=2.59x frame=10269 fps=155 q=31.0 size=N/A time=00:02:51.34 bitrate=N/A speed=2.59x frame=10359 fps=155 q=31.0 size=N/A time=00:02:52.95 bitrate=N/A speed=2.59x frame=10452 fps=155 q=31.0 size=N/A time=00:02:54.48 bitrate=N/A speed=2.59x frame=10546 fps=156 q=31.0 size=N/A time=00:02:55.97 bitrate=N/A speed= 2.6x frame=10641 fps=156 q=31.0 size=N/A time=00:02:57.65 bitrate=N/A speed= 2.6x frame=10737 fps=156 q=31.0 size=N/A time=00:02:59.19 bitrate=N/A speed=2.61x frame=10835 fps=156 q=31.0 size=N/A time=00:03:00.91 bitrate=N/A speed=2.61x frame=10926 fps=157 q=31.0 size=N/A time=00:03:02.47 bitrate=N/A speed=2.62x frame=11006 fps=157 q=31.0 size=N/A time=00:03:03.65 bitrate=N/A speed=2.61x frame=11104 fps=157 q=31.0 size=N/A time=00:03:05.43 bitrate=N/A speed=2.62x frame=11195 fps=157 q=31.0 size=N/A time=00:03:06.99 bitrate=N/A speed=2.62x frame=11262 fps=157 q=31.0 size=N/A time=00:03:08.02 bitrate=N/A speed=2.62x frame=11331 fps=157 q=37.0 size=N/A time=00:03:09.19 bitrate=N/A speed=2.62x frame=11405 fps=157 q=37.0 size=N/A time=00:03:10.35 bitrate=N/A speed=2.62x frame=11479 fps=157 q=34.0 size=N/A time=00:03:11.71 bitrate=N/A speed=2.62x frame=11556 fps=157 q=34.0 size=N/A time=00:03:12.87 bitrate=N/A speed=2.61x frame=11625 fps=156 q=37.0 size=N/A time=00:03:14.21 bitrate=N/A speed=2.61x frame=11688 fps=156 q=35.0 size=N/A time=00:03:15.17 bitrate=N/A speed=2.61x frame=11780 fps=156 q=31.0 size=N/A time=00:03:16.61 bitrate=N/A speed=2.61x frame=11861 fps=156 q=31.0 size=N/A time=00:03:17.93 bitrate=N/A speed=2.61x frame=11932 fps=156 q=36.0 size=N/A time=00:03:19.15 bitrate=N/A speed=2.61x frame=11996 fps=156 q=36.0 size=N/A time=00:03:20.23 bitrate=N/A speed=2.61x frame=12065 fps=156 q=39.0 size=N/A time=00:03:21.39 bitrate=N/A speed= 2.6x frame=12133 fps=156 q=41.0 size=N/A time=00:03:22.47 bitrate=N/A speed= 2.6x frame=12228 fps=156 q=31.0 size=N/A time=00:03:24.10 bitrate=N/A speed=2.61x frame=12326 fps=156 q=31.0 size=N/A time=00:03:25.80 bitrate=N/A speed=2.61x frame=12424 fps=157 q=29.0 size=N/A time=00:03:27.36 bitrate=N/A speed=2.61x frame=12488 fps=156 q=34.0 size=N/A time=00:03:28.39 bitrate=N/A speed=2.61x frame=12560 fps=156 q=35.0 size=N/A time=00:03:29.64 bitrate=N/A speed=2.61x frame=12632 fps=156 q=36.0 size=N/A time=00:03:30.91 bitrate=N/A speed=2.61x frame=12704 fps=156 q=34.0 size=N/A time=00:03:32.04 bitrate=N/A speed=2.61x frame=12778 fps=156 q=36.0 size=N/A time=00:03:33.22 bitrate=N/A speed= 2.6x frame=12848 fps=156 q=36.0 size=N/A time=00:03:34.35 bitrate=N/A speed= 2.6x frame=12919 fps=156 q=34.0 size=N/A time=00:03:35.62 bitrate=N/A speed= 2.6x frame=12990 fps=156 q=35.0 size=N/A time=00:03:36.82 bitrate=N/A speed= 2.6x frame=13064 fps=156 q=31.0 size=N/A time=00:03:38.09 bitrate=N/A speed= 2.6x frame=13162 fps=156 q=31.0 size=N/A time=00:03:39.63 bitrate=N/A speed= 2.6x frame=13261 fps=156 q=31.0 size=N/A time=00:03:41.33 bitrate=N/A speed=2.61x frame=13352 fps=156 q=31.0 size=N/A time=00:03:42.99 bitrate=N/A speed=2.61x frame=13440 fps=156 q=31.0 size=N/A time=00:03:44.43 bitrate=N/A speed=2.61x frame=13504 fps=156 q=33.0 size=N/A time=00:03:45.46 bitrate=N/A speed=2.61x frame=13573 fps=156 q=32.0 size=N/A time=00:03:46.51 bitrate=N/A speed=2.61x frame=13651 fps=156 q=31.0 size=N/A time=00:03:47.86 bitrate=N/A speed=2.61x frame=13727 fps=156 q=32.0 size=N/A time=00:03:49.06 bitrate=N/A speed= 2.6x frame=13818 fps=156 q=31.0 size=N/A time=00:03:50.59 bitrate=N/A speed=2.61x frame=13900 fps=156 q=35.0 size=N/A time=00:03:51.99 bitrate=N/A speed=2.61x frame=13967 fps=156 q=36.0 size=N/A time=00:03:53.14 bitrate=N/A speed=2.61x frame=14039 fps=156 q=37.0 size=N/A time=00:03:54.41 bitrate=N/A speed=2.61x frame=14112 fps=156 q=31.0 size=N/A time=00:03:55.63 bitrate=N/A speed=2.61x frame=14181 fps=156 q=35.0 size=N/A time=00:03:56.81 bitrate=N/A speed= 2.6x frame=14257 fps=156 q=32.0 size=N/A time=00:03:57.94 bitrate=N/A speed= 2.6x frame=14324 fps=156 q=33.0 size=N/A time=00:03:59.04 bitrate=N/A speed= 2.6x frame=14398 fps=156 q=40.0 size=N/A time=00:04:00.34 bitrate=N/A speed= 2.6x frame=14471 fps=156 q=36.0 size=N/A time=00:04:01.49 bitrate=N/A speed= 2.6x frame=14548 fps=156 q=35.0 size=N/A time=00:04:02.95 bitrate=N/A speed= 2.6x frame=14624 fps=156 q=35.0 size=N/A time=00:04:03.99 bitrate=N/A speed= 2.6x frame=14689 fps=155 q=37.0 size=N/A time=00:04:05.26 bitrate=N/A speed= 2.6x frame=14768 fps=155 q=36.0 size=N/A time=00:04:06.58 bitrate=N/A speed= 2.6x frame=14853 fps=156 q=35.0 size=N/A time=00:04:07.95 bitrate=N/A speed= 2.6x frame=14917 fps=155 q=39.0 size=N/A time=00:04:08.98 bitrate=N/A speed=2.59x frame=14986 fps=155 q=36.0 size=N/A time=00:04:10.18 bitrate=N/A speed=2.59x frame=15074 fps=155 q=31.0 size=N/A time=00:04:11.52 bitrate=N/A speed=2.59x frame=15161 fps=155 q=31.0 size=N/A time=00:04:13.06 bitrate=N/A speed=2.59x frame=15249 fps=156 q=31.0 size=N/A time=00:04:14.45 bitrate=N/A speed= 2.6x frame=15323 fps=155 q=34.0 size=N/A time=00:04:15.72 bitrate=N/A speed=2.59x frame=15385 fps=155 q=36.0 size=N/A time=00:04:16.75 bitrate=N/A speed=2.59x frame=15457 fps=155 q=35.0 size=N/A time=00:04:18.03 bitrate=N/A speed=2.59x frame=15525 fps=155 q=39.0 size=N/A time=00:04:19.11 bitrate=N/A speed=2.59x frame=15586 fps=155 q=35.0 size=N/A time=00:04:20.04 bitrate=N/A speed=2.59x frame=15653 fps=155 q=38.0 size=N/A time=00:04:21.31 bitrate=N/A speed=2.59x frame=15731 fps=155 q=31.0 size=N/A time=00:04:22.61 bitrate=N/A speed=2.59x frame=15815 fps=155 q=32.0 size=N/A time=00:04:24.00 bitrate=N/A speed=2.59x frame=15884 fps=155 q=36.0 size=N/A time=00:04:25.20 bitrate=N/A speed=2.59x frame=15960 fps=155 q=34.0 size=N/A time=00:04:26.28 bitrate=N/A speed=2.58x frame=16046 fps=155 q=31.0 size=N/A time=00:04:27.79 bitrate=N/A speed=2.59x frame=16140 fps=155 q=31.0 size=N/A time=00:04:29.33 bitrate=N/A speed=2.59x frame=16229 fps=155 q=31.0 size=N/A time=00:04:30.82 bitrate=N/A speed=2.59x frame=16293 fps=155 q=33.0 size=N/A time=00:04:31.85 bitrate=N/A speed=2.59x frame=16362 fps=155 q=33.0 size=N/A time=00:04:33.12 bitrate=N/A speed=2.59x frame=16439 fps=155 q=31.0 size=N/A time=00:04:34.32 bitrate=N/A speed=2.59x frame=16525 fps=155 q=31.0 size=N/A time=00:04:35.76 bitrate=N/A speed=2.59x frame=16624 fps=155 q=31.0 size=N/A time=00:04:37.54 bitrate=N/A speed=2.59x frame=16722 fps=155 q=31.0 size=N/A time=00:04:39.17 bitrate=N/A speed=2.59x frame=16810 fps=155 q=31.0 size=N/A time=00:04:40.49 bitrate=N/A speed=2.59x frame=16895 fps=156 q=31.0 size=N/A time=00:04:42.05 bitrate=N/A speed= 2.6x frame=16980 fps=156 q=31.0 size=N/A time=00:04:43.35 bitrate=N/A speed= 2.6x frame=17065 fps=156 q=31.0 size=N/A time=00:04:44.88 bitrate=N/A speed= 2.6x frame=17142 fps=156 q=31.0 size=N/A time=00:04:46.27 bitrate=N/A speed= 2.6x frame=17217 fps=156 q=33.0 size=N/A time=00:04:47.31 bitrate=N/A speed= 2.6x frame=17306 fps=156 q=31.0 size=N/A time=00:04:48.75 bitrate=N/A speed= 2.6x frame=17408 fps=156 q=31.0 size=N/A time=00:04:50.55 bitrate=N/A speed= 2.6x frame=17496 fps=156 q=31.0 size=N/A time=00:04:51.99 bitrate=N/A speed= 2.6x frame=17565 fps=156 q=32.0 size=N/A time=00:04:53.26 bitrate=N/A speed= 2.6x frame=17655 fps=156 q=31.0 size=N/A time=00:04:54.60 bitrate=N/A speed= 2.6x frame=17756 fps=156 q=31.0 size=N/A time=00:04:56.35 bitrate=N/A speed=2.61x frame=17830 fps=156 q=33.0 size=N/A time=00:04:57.51 bitrate=N/A speed=2.61x frame=17904 fps=156 q=31.0 size=N/A time=00:04:58.85 bitrate=N/A speed=2.61x frame=17978 fps=156 q=33.0 size=N/A time=00:05:00.00 bitrate=N/A speed= 2.6x frame=18046 fps=156 q=36.0 size=N/A time=00:05:01.30 bitrate=N/A speed= 2.6x frame=18119 fps=156 q=31.0 size=N/A time=00:05:02.35 bitrate=N/A speed= 2.6x frame=18193 fps=156 q=35.0 size=N/A time=00:05:03.82 bitrate=N/A speed= 2.6x frame=18263 fps=156 q=35.0 size=N/A time=00:05:04.78 bitrate=N/A speed= 2.6x frame=18341 fps=156 q=34.0 size=N/A time=00:05:06.05 bitrate=N/A speed= 2.6x frame=18419 fps=156 q=32.0 size=N/A time=00:05:07.35 bitrate=N/A speed= 2.6x frame=18500 fps=156 q=35.0 size=N/A time=00:05:08.71 bitrate=N/A speed= 2.6x frame=18572 fps=156 q=34.0 size=N/A time=00:05:09.99 bitrate=N/A speed= 2.6x frame=18651 fps=156 q=31.0 size=N/A time=00:05:11.38 bitrate=N/A speed= 2.6x frame=18754 fps=156 q=31.0 size=N/A time=00:05:12.94 bitrate=N/A speed= 2.6x frame=18832 fps=156 q=31.0 size=N/A time=00:05:14.26 bitrate=N/A speed= 2.6x frame=18920 fps=156 q=31.0 size=N/A time=00:05:15.84 bitrate=N/A speed=2.61x frame=19006 fps=156 q=31.0 size=N/A time=00:05:17.23 bitrate=N/A speed=2.61x frame=19097 fps=156 q=31.0 size=N/A time=00:05:18.67 bitrate=N/A speed=2.61x frame=19185 fps=156 q=31.0 size=N/A time=00:05:20.31 bitrate=N/A speed=2.61x frame=19294 fps=157 q=31.0 size=N/A time=00:05:22.06 bitrate=N/A speed=2.61x frame=19378 fps=157 q=31.0 size=N/A time=00:05:23.33 bitrate=N/A speed=2.61x frame=19450 fps=157 q=31.0 size=N/A time=00:05:24.72 bitrate=N/A speed=2.61x frame=19541 fps=157 q=31.0 size=N/A time=00:05:26.09 bitrate=N/A speed=2.61x frame=19636 fps=157 q=31.0 size=N/A time=00:05:27.72 bitrate=N/A speed=2.62x frame=19720 fps=157 q=31.0 size=N/A time=00:05:29.07 bitrate=N/A speed=2.62x frame=19809 fps=157 q=31.0 size=N/A time=00:05:30.58 bitrate=N/A speed=2.62x frame=19890 fps=157 q=31.0 size=N/A time=00:05:31.87 bitrate=N/A speed=2.62x frame=19970 fps=157 q=31.0 size=N/A time=00:05:33.19 bitrate=N/A speed=2.62x frame=20050 fps=157 q=32.0 size=N/A time=00:05:34.73 bitrate=N/A speed=2.62x frame=20128 fps=157 q=32.0 size=N/A time=00:05:35.91 bitrate=N/A speed=2.62x frame=20215 fps=157 q=31.0 size=N/A time=00:05:37.32 bitrate=N/A speed=2.62x frame=20305 fps=157 q=31.0 size=N/A time=00:05:38.86 bitrate=N/A speed=2.62x frame=20396 fps=157 q=31.0 size=N/A time=00:05:40.49 bitrate=N/A speed=2.62x frame=20482 fps=157 q=31.0 size=N/A time=00:05:41.83 bitrate=N/A speed=2.62x frame=20565 fps=157 q=31.0 size=N/A time=00:05:43.11 bitrate=N/A speed=2.62x frame=20654 fps=157 q=31.0 size=N/A time=00:05:44.64 bitrate=N/A speed=2.63x frame=20744 fps=157 q=31.0 size=N/A time=00:05:46.08 bitrate=N/A speed=2.63x frame=20817 fps=157 q=31.0 size=N/A time=00:05:47.38 bitrate=N/A speed=2.63x frame=20886 fps=157 q=31.0 size=N/A time=00:05:48.65 bitrate=N/A speed=2.63x frame=20955 fps=157 q=35.0 size=N/A time=00:05:49.80 bitrate=N/A speed=2.62x frame=21023 fps=157 q=34.0 size=N/A time=00:05:50.83 bitrate=N/A speed=2.62x frame=21099 fps=157 q=31.0 size=N/A time=00:05:52.20 bitrate=N/A speed=2.62x frame=21196 fps=157 q=31.0 size=N/A time=00:05:53.81 bitrate=N/A speed=2.62x frame=21285 fps=157 q=32.0 size=N/A time=00:05:55.18 bitrate=N/A speed=2.62x frame=21368 fps=157 q=36.0 size=N/A time=00:05:56.64 bitrate=N/A speed=2.63x frame=21458 fps=157 q=31.0 size=N/A time=00:05:58.03 bitrate=N/A speed=2.63x frame=21550 fps=157 q=31.0 size=N/A time=00:05:59.57 bitrate=N/A speed=2.63x frame=21641 fps=158 q=31.0 size=N/A time=00:06:01.15 bitrate=N/A speed=2.63x frame=21731 fps=158 q=31.0 size=N/A time=00:06:02.69 bitrate=N/A speed=2.63x frame=21822 fps=158 q=31.0 size=N/A time=00:06:04.11 bitrate=N/A speed=2.63x frame=21916 fps=158 q=31.0 size=N/A time=00:06:05.74 bitrate=N/A speed=2.63x frame=22012 fps=158 q=31.0 size=N/A time=00:06:07.27 bitrate=N/A speed=2.64x frame=22104 fps=158 q=31.0 size=N/A time=00:06:08.79 bitrate=N/A speed=2.64x frame=22192 fps=158 q=31.0 size=N/A time=00:06:10.37 bitrate=N/A speed=2.64x frame=22284 fps=158 q=31.0 size=N/A time=00:06:11.91 bitrate=N/A speed=2.64x frame=22370 fps=158 q=31.0 size=N/A time=00:06:13.30 bitrate=N/A speed=2.64x frame=22462 fps=158 q=31.0 size=N/A time=00:06:14.79 bitrate=N/A speed=2.64x frame=22559 fps=158 q=31.0 size=N/A time=00:06:16.47 bitrate=N/A speed=2.64x frame=22655 fps=159 q=31.0 size=N/A time=00:06:18.00 bitrate=N/A speed=2.65x frame=22742 fps=159 q=31.0 size=N/A time=00:06:19.59 bitrate=N/A speed=2.65x frame=22826 fps=159 q=31.0 size=N/A time=00:06:21.00 bitrate=N/A speed=2.65x frame=22911 fps=159 q=31.0 size=N/A time=00:06:22.44 bitrate=N/A speed=2.65x frame=23001 fps=159 q=31.0 size=N/A time=00:06:23.88 bitrate=N/A speed=2.65x frame=23096 fps=159 q=31.0 size=N/A time=00:06:25.42 bitrate=N/A speed=2.65x frame=23183 fps=159 q=31.0 size=N/A time=00:06:26.83 bitrate=N/A speed=2.65x frame=23271 fps=159 q=31.0 size=N/A time=00:06:28.37 bitrate=N/A speed=2.65x frame=23362 fps=159 q=31.0 size=N/A time=00:06:29.91 bitrate=N/A speed=2.65x frame=23457 fps=159 q=31.0 size=N/A time=00:06:31.44 bitrate=N/A speed=2.66x frame=23547 fps=159 q=31.0 size=N/A time=00:06:33.10 bitrate=N/A speed=2.66x frame=23632 fps=159 q=31.0 size=N/A time=00:06:34.47 bitrate=N/A speed=2.66x frame=23719 fps=159 q=31.0 size=N/A time=00:06:35.88 bitrate=N/A speed=2.66x frame=23806 fps=159 q=31.0 size=N/A time=00:06:37.15 bitrate=N/A speed=2.66x frame=23895 fps=159 q=35.0 size=N/A time=00:06:38.83 bitrate=N/A speed=2.66x frame=23992 fps=159 q=31.0 size=N/A time=00:06:40.27 bitrate=N/A speed=2.66x frame=24080 fps=160 q=31.0 size=N/A time=00:06:41.81 bitrate=N/A speed=2.66x frame=24172 fps=160 q=31.0 size=N/A time=00:06:43.44 bitrate=N/A speed=2.66x frame=24255 fps=160 q=31.0 size=N/A time=00:06:44.83 bitrate=N/A speed=2.66x frame=24328 fps=160 q=33.0 size=N/A time=00:06:46.15 bitrate=N/A speed=2.66x frame=24401 fps=160 q=31.0 size=N/A time=00:06:47.19 bitrate=N/A speed=2.66x frame=24476 fps=159 q=31.0 size=N/A time=00:06:48.53 bitrate=N/A speed=2.66x frame=24578 fps=160 q=31.0 size=N/A time=00:06:50.26 bitrate=N/A speed=2.66x frame=24647 fps=160 q=31.0 size=N/A time=00:06:51.27 bitrate=N/A speed=2.66x frame=24713 fps=159 q=38.0 size=N/A time=00:06:52.49 bitrate=N/A speed=2.66x frame=24781 fps=159 q=34.0 size=N/A time=00:06:53.45 bitrate=N/A speed=2.66x frame=24878 fps=159 q=31.0 size=N/A time=00:06:55.18 bitrate=N/A speed=2.66x frame=24973 fps=160 q=31.0 size=N/A time=00:06:56.71 bitrate=N/A speed=2.66x frame=25065 fps=160 q=31.0 size=N/A time=00:06:58.23 bitrate=N/A speed=2.66x frame=25153 fps=160 q=31.0 size=N/A time=00:06:59.76 bitrate=N/A speed=2.66x frame=25245 fps=160 q=31.0 size=N/A time=00:07:01.30 bitrate=N/A speed=2.67x frame=25336 fps=160 q=31.0 size=N/A time=00:07:02.83 bitrate=N/A speed=2.67x frame=25433 fps=160 q=31.0 size=N/A time=00:07:04.39 bitrate=N/A speed=2.67x frame=25530 fps=160 q=31.0 size=N/A time=00:07:05.95 bitrate=N/A speed=2.67x frame=25616 fps=160 q=31.0 size=N/A time=00:07:07.47 bitrate=N/A speed=2.67x frame=25699 fps=160 q=31.0 size=N/A time=00:07:08.93 bitrate=N/A speed=2.67x frame=25796 fps=160 q=31.0 size=N/A time=00:07:10.47 bitrate=N/A speed=2.67x frame=25897 fps=160 q=31.0 size=N/A time=00:07:12.24 bitrate=N/A speed=2.68x frame=25998 fps=160 q=31.0 size=N/A time=00:07:13.78 bitrate=N/A speed=2.68x frame=26106 fps=161 q=31.0 size=N/A time=00:07:15.63 bitrate=N/A speed=2.68x frame=26207 fps=161 q=31.0 size=N/A time=00:07:17.26 bitrate=N/A speed=2.68x frame=26309 fps=161 q=31.0 size=N/A time=00:07:19.08 bitrate=N/A speed=2.68x frame=26387 fps=161 q=36.0 size=N/A time=00:07:20.35 bitrate=N/A speed=2.68x frame=26473 fps=161 q=33.0 size=N/A time=00:07:21.84 bitrate=N/A speed=2.68x frame=26572 fps=161 q=31.0 size=N/A time=00:07:23.38 bitrate=N/A speed=2.69x frame=26655 fps=161 q=32.0 size=N/A time=00:07:24.87 bitrate=N/A speed=2.69x frame=26751 fps=161 q=31.0 size=N/A time=00:07:26.45 bitrate=N/A speed=2.69x frame=26831 fps=161 q=34.0 size=N/A time=00:07:27.72 bitrate=N/A speed=2.69x frame=26902 fps=161 q=37.0 size=N/A time=00:07:29.09 bitrate=N/A speed=2.69x frame=26975 fps=161 q=36.0 size=N/A time=00:07:30.12 bitrate=N/A speed=2.69x frame=27046 fps=161 q=36.0 size=N/A time=00:07:31.39 bitrate=N/A speed=2.69x frame=27141 fps=161 q=31.0 size=N/A time=00:07:32.93 bitrate=N/A speed=2.69x frame=27220 fps=161 q=35.0 size=N/A time=00:07:34.25 bitrate=N/A speed=2.69x frame=27291 fps=161 q=37.0 size=N/A time=00:07:35.38 bitrate=N/A speed=2.68x frame=27360 fps=161 q=35.0 size=N/A time=00:07:36.48 bitrate=N/A speed=2.68x frame=27424 fps=161 q=37.0 size=N/A time=00:07:37.78 bitrate=N/A speed=2.68x frame=27489 fps=161 q=36.0 size=N/A time=00:07:38.86 bitrate=N/A speed=2.68x frame=27564 fps=161 q=32.0 size=N/A time=00:07:40.01 bitrate=N/A speed=2.68x frame=27639 fps=161 q=31.0 size=N/A time=00:07:41.16 bitrate=N/A speed=2.68x frame=27717 fps=161 q=32.0 size=N/A time=00:07:42.60 bitrate=N/A speed=2.68x frame=27793 fps=161 q=32.0 size=N/A time=00:07:43.78 bitrate=N/A speed=2.68x frame=27881 fps=161 q=32.0 size=N/A time=00:07:45.22 bitrate=N/A speed=2.68x frame=27975 fps=161 q=33.0 size=N/A time=00:07:46.95 bitrate=N/A speed=2.68x frame=28074 fps=161 q=32.0 size=N/A time=00:07:48.48 bitrate=N/A speed=2.68x frame=28168 fps=161 q=31.0 size=N/A time=00:07:50.07 bitrate=N/A speed=2.68x frame=28235 fps=161 q=35.0 size=N/A time=00:07:51.12 bitrate=N/A speed=2.68x frame=28310 fps=161 q=34.0 size=N/A time=00:07:52.47 bitrate=N/A speed=2.68x frame=28405 fps=161 q=31.0 size=N/A time=00:07:54.10 bitrate=N/A speed=2.68x frame=28497 fps=161 q=31.0 size=N/A time=00:07:55.63 bitrate=N/A speed=2.68x frame=28587 fps=161 q=31.0 size=N/A time=00:07:57.10 bitrate=N/A speed=2.68x frame=28679 fps=161 q=31.0 size=N/A time=00:07:58.75 bitrate=N/A speed=2.69x frame=28782 fps=161 q=31.0 size=N/A time=00:08:00.36 bitrate=N/A speed=2.69x frame=28871 fps=161 q=31.0 size=N/A time=00:08:01.73 bitrate=N/A speed=2.69x frame=28940 fps=161 q=31.0 size=N/A time=00:08:03.03 bitrate=N/A speed=2.69x frame=29006 fps=161 q=32.0 size=N/A time=00:08:04.01 bitrate=N/A speed=2.69x frame=29072 fps=161 q=39.0 size=N/A time=00:08:05.28 bitrate=N/A speed=2.69x frame=29172 fps=161 q=32.0 size=N/A time=00:08:06.79 bitrate=N/A speed=2.69x frame=29258 fps=161 q=31.0 size=N/A time=00:08:08.26 bitrate=N/A speed=2.69x frame=29332 fps=161 q=31.0 size=N/A time=00:08:09.55 bitrate=N/A speed=2.69x frame=29414 fps=161 q=31.0 size=N/A time=00:08:10.85 bitrate=N/A speed=2.69x frame=29515 fps=161 q=31.0 size=N/A time=00:08:12.46 bitrate=N/A speed=2.69x frame=29602 fps=161 q=31.0 size=N/A time=00:08:14.07 bitrate=N/A speed=2.69x frame=29678 fps=161 q=31.0 size=N/A time=00:08:15.15 bitrate=N/A speed=2.69x frame=29753 fps=161 q=32.0 size=N/A time=00:08:16.49 bitrate=N/A speed=2.69x frame=29825 fps=161 q=36.0 size=N/A time=00:08:17.74 bitrate=N/A speed=2.69x frame=29904 fps=161 q=35.0 size=N/A time=00:08:18.96 bitrate=N/A speed=2.69x frame=29984 fps=161 q=35.0 size=N/A time=00:08:20.45 bitrate=N/A speed=2.69x frame=30062 fps=161 q=37.0 size=N/A time=00:08:21.58 bitrate=N/A speed=2.69x frame=30133 fps=161 q=31.0 size=N/A time=00:08:22.83 bitrate=N/A speed=2.68x frame=30200 fps=161 q=32.0 size=N/A time=00:08:24.10 bitrate=N/A speed=2.68x frame=30275 fps=161 q=31.0 size=N/A time=00:08:25.13 bitrate=N/A speed=2.68x frame=30358 fps=161 q=35.0 size=N/A time=00:08:26.67 bitrate=N/A speed=2.68x frame=30438 fps=161 q=33.0 size=N/A time=00:08:27.84 bitrate=N/A speed=2.68x frame=30512 fps=161 q=35.0 size=N/A time=00:08:29.23 bitrate=N/A speed=2.68x frame=30598 fps=161 q=35.0 size=N/A time=00:08:30.72 bitrate=N/A speed=2.68x frame=30670 fps=161 q=33.0 size=N/A time=00:08:31.75 bitrate=N/A speed=2.68x frame=30738 fps=161 q=35.0 size=N/A time=00:08:32.93 bitrate=N/A speed=2.68x frame=30808 fps=161 q=33.0 size=N/A time=00:08:34.25 bitrate=N/A speed=2.68x frame=30888 fps=161 q=32.0 size=N/A time=00:08:35.50 bitrate=N/A speed=2.68x frame=30981 fps=161 q=31.0 size=N/A time=00:08:36.94 bitrate=N/A speed=2.68x frame=31068 fps=161 q=31.0 size=N/A time=00:08:38.55 bitrate=N/A speed=2.68x frame=31155 fps=161 q=31.0 size=N/A time=00:08:39.91 bitrate=N/A speed=2.68x frame=31244 fps=161 q=31.0 size=N/A time=00:08:41.45 bitrate=N/A speed=2.68x frame=31348 fps=161 q=31.0 size=N/A time=00:08:43.25 bitrate=N/A speed=2.69x frame=31457 fps=161 q=31.0 size=N/A time=00:08:44.83 bitrate=N/A speed=2.69x frame=31549 fps=161 q=31.0 size=N/A time=00:08:46.54 bitrate=N/A speed=2.69x frame=31639 fps=161 q=31.0 size=N/A time=00:08:48.00 bitrate=N/A speed=2.69x frame=31733 fps=161 q=31.0 size=N/A time=00:08:49.49 bitrate=N/A speed=2.69x frame=31825 fps=161 q=31.0 size=N/A time=00:08:50.98 bitrate=N/A speed=2.69x frame=31924 fps=161 q=31.0 size=N/A time=00:08:52.75 bitrate=N/A speed=2.69x frame=32014 fps=161 q=31.0 size=N/A time=00:08:54.19 bitrate=N/A speed=2.69x frame=32086 fps=161 q=36.0 size=N/A time=00:08:55.47 bitrate=N/A speed=2.69x frame=32154 fps=161 q=35.0 size=N/A time=00:08:56.69 bitrate=N/A speed=2.69x frame=32221 fps=161 q=37.0 size=N/A time=00:08:57.70 bitrate=N/A speed=2.69x frame=32288 fps=161 q=32.0 size=N/A time=00:08:58.92 bitrate=N/A speed=2.69x frame=32366 fps=161 q=36.0 size=N/A time=00:09:00.17 bitrate=N/A speed=2.69x frame=32441 fps=161 q=33.0 size=N/A time=00:09:01.30 bitrate=N/A speed=2.69x frame=32531 fps=161 q=31.0 size=N/A time=00:09:02.83 bitrate=N/A speed=2.69x frame=32621 fps=161 q=31.0 size=N/A time=00:09:04.27 bitrate=N/A speed=2.69x frame=32710 fps=161 q=34.0 size=N/A time=00:09:05.83 bitrate=N/A speed=2.69x frame=32797 fps=161 q=31.0 size=N/A time=00:09:07.27 bitrate=N/A speed=2.69x frame=32860 fps=161 q=37.0 size=N/A time=00:09:08.31 bitrate=N/A speed=2.69x frame=32929 fps=161 q=41.0 size=N/A time=00:09:09.39 bitrate=N/A speed=2.69x frame=33004 fps=161 q=35.0 size=N/A time=00:09:10.90 bitrate=N/A speed=2.69x frame=33071 fps=161 q=38.0 size=N/A time=00:09:11.91 bitrate=N/A speed=2.69x frame=33138 fps=161 q=36.0 size=N/A time=00:09:13.03 bitrate=N/A speed=2.69x frame=33209 fps=161 q=36.0 size=N/A time=00:09:14.07 bitrate=N/A speed=2.68x frame=33277 fps=161 q=37.0 size=N/A time=00:09:15.27 bitrate=N/A speed=2.68x frame=33350 fps=161 q=31.0 size=N/A time=00:09:16.56 bitrate=N/A speed=2.68x frame=33429 fps=161 q=31.0 size=N/A time=00:09:17.76 bitrate=N/A speed=2.68x frame=33536 fps=161 q=31.0 size=N/A time=00:09:19.56 bitrate=N/A speed=2.68x frame=33638 fps=161 q=31.0 size=N/A time=00:09:21.29 bitrate=N/A speed=2.69x frame=33748 fps=161 q=31.0 size=N/A time=00:09:23.21 bitrate=N/A speed=2.69x frame=33859 fps=161 q=31.0 size=N/A time=00:09:25.11 bitrate=N/A speed=2.69x frame=33968 fps=161 q=31.0 size=N/A time=00:09:26.86 bitrate=N/A speed=2.69x frame=34062 fps=161 q=31.0 size=N/A time=00:09:28.32 bitrate=N/A speed=2.69x frame=34164 fps=162 q=31.0 size=N/A time=00:09:30.12 bitrate=N/A speed= 2.7x frame=34268 fps=162 q=31.0 size=N/A time=00:09:31.92 bitrate=N/A speed= 2.7x frame=34374 fps=162 q=31.0 size=N/A time=00:09:33.67 bitrate=N/A speed= 2.7x frame=34481 fps=162 q=31.0 size=N/A time=00:09:35.33 bitrate=N/A speed= 2.7x frame=34588 fps=162 q=31.0 size=N/A time=00:09:37.13 bitrate=N/A speed= 2.7x frame=34693 fps=162 q=31.0 size=N/A time=00:09:38.98 bitrate=N/A speed=2.71x frame=34804 fps=162 q=31.0 size=N/A time=00:09:40.78 bitrate=N/A speed=2.71x frame=34908 fps=162 q=31.0 size=N/A time=00:09:42.63 bitrate=N/A speed=2.71x frame=35008 fps=162 q=31.0 size=N/A time=00:09:44.23 bitrate=N/A speed=2.71x frame=35104 fps=162 q=31.0 size=N/A time=00:09:45.84 bitrate=N/A speed=2.71x frame=35208 fps=163 q=31.0 size=N/A time=00:09:47.50 bitrate=N/A speed=2.71x frame=35318 fps=163 q=31.0 size=N/A time=00:09:49.35 bitrate=N/A speed=2.72x frame=35416 fps=163 q=31.0 size=N/A time=00:09:50.86 bitrate=N/A speed=2.72x frame=35518 fps=163 q=31.0 size=N/A time=00:09:52.66 bitrate=N/A speed=2.72x frame=35617 fps=163 q=31.0 size=N/A time=00:09:54.43 bitrate=N/A speed=2.72x frame=35718 fps=163 q=31.0 size=N/A time=00:09:55.95 bitrate=N/A speed=2.72x frame=35825 fps=163 q=31.0 size=N/A time=00:09:57.75 bitrate=N/A speed=2.72x frame=35931 fps=163 q=31.0 size=N/A time=00:09:59.59 bitrate=N/A speed=2.72x frame=36039 fps=163 q=31.0 size=N/A time=00:10:01.39 bitrate=N/A speed=2.73x frame=36144 fps=163 q=31.0 size=N/A time=00:10:03.07 bitrate=N/A speed=2.73x frame=36246 fps=164 q=31.0 size=N/A time=00:10:04.87 bitrate=N/A speed=2.73x frame=36342 fps=164 q=31.0 size=N/A time=00:10:06.41 bitrate=N/A speed=2.73x frame=36439 fps=164 q=31.0 size=N/A time=00:10:08.07 bitrate=N/A speed=2.73x frame=36540 fps=164 q=31.0 size=N/A time=00:10:09.70 bitrate=N/A speed=2.73x frame=36632 fps=164 q=31.0 size=N/A time=00:10:11.23 bitrate=N/A speed=2.73x frame=36722 fps=164 q=31.0 size=N/A time=00:10:12.75 bitrate=N/A speed=2.73x frame=36826 fps=164 q=31.0 size=N/A time=00:10:14.57 bitrate=N/A speed=2.74x frame=36940 fps=164 q=31.0 size=N/A time=00:10:16.37 bitrate=N/A speed=2.74x frame=37043 fps=164 q=31.0 size=N/A time=00:10:18.10 bitrate=N/A speed=2.74x frame=37138 fps=164 q=31.0 size=N/A time=00:10:19.68 bitrate=N/A speed=2.74x frame=37235 fps=164 q=31.0 size=N/A time=00:10:21.41 bitrate=N/A speed=2.74x frame=37337 fps=164 q=31.0 size=N/A time=00:10:23.02 bitrate=N/A speed=2.74x frame=37443 fps=165 q=31.0 size=N/A time=00:10:24.82 bitrate=N/A speed=2.75x frame=37525 fps=164 q=35.0 size=N/A time=00:10:26.21 bitrate=N/A speed=2.75x frame=37590 fps=164 q=40.0 size=N/A time=00:10:27.36 bitrate=N/A speed=2.74x frame=37653 fps=164 q=38.0 size=N/A time=00:10:28.39 bitrate=N/A speed=2.74x frame=37724 fps=164 q=34.0 size=N/A time=00:10:29.43 bitrate=N/A speed=2.74x frame=37802 fps=164 q=31.0 size=N/A time=00:10:30.87 bitrate=N/A speed=2.74x frame=37920 fps=164 q=31.0 size=N/A time=00:10:32.79 bitrate=N/A speed=2.74x frame=38026 fps=165 q=31.0 size=N/A time=00:10:34.56 bitrate=N/A speed=2.75x frame=38126 fps=165 q=31.0 size=N/A time=00:10:36.17 bitrate=N/A speed=2.75x frame=38212 fps=165 q=31.0 size=N/A time=00:10:37.71 bitrate=N/A speed=2.75x frame=38292 fps=165 q=31.0 size=N/A time=00:10:38.95 bitrate=N/A speed=2.75x frame=38367 fps=165 q=31.0 size=N/A time=00:10:40.32 bitrate=N/A speed=2.75x frame=38467 fps=165 q=31.0 size=N/A time=00:10:41.91 bitrate=N/A speed=2.75x frame=38555 fps=165 q=31.0 size=N/A time=00:10:43.44 bitrate=N/A speed=2.75x frame=38650 fps=165 q=31.0 size=N/A time=00:10:44.83 bitrate=N/A speed=2.75x frame=38742 fps=165 q=31.0 size=N/A time=00:10:46.37 bitrate=N/A speed=2.75x frame=38840 fps=165 q=31.0 size=N/A time=00:10:48.00 bitrate=N/A speed=2.75x frame=38930 fps=165 q=31.0 size=N/A time=00:10:49.61 bitrate=N/A speed=2.75x frame=39036 fps=165 q=31.0 size=N/A time=00:10:51.53 bitrate=N/A speed=2.75x frame=39149 fps=165 q=31.0 size=N/A time=00:10:53.33 bitrate=N/A speed=2.75x frame=39267 fps=165 q=31.0 size=N/A time=00:10:55.20 bitrate=N/A speed=2.76x frame=39350 fps=165 q=31.0 size=N/A time=00:10:56.59 bitrate=N/A speed=2.76x frame=39442 fps=165 q=31.0 size=N/A time=00:10:58.15 bitrate=N/A speed=2.76x frame=39540 fps=165 q=31.0 size=N/A time=00:10:59.71 bitrate=N/A speed=2.76x frame=39650 fps=165 q=31.0 size=N/A time=00:11:01.51 bitrate=N/A speed=2.76x frame=39765 fps=166 q=31.0 size=N/A time=00:11:03.55 bitrate=N/A speed=2.76x frame=39881 fps=166 q=31.0 size=N/A time=00:11:05.43 bitrate=N/A speed=2.76x frame=39995 fps=166 q=31.0 size=N/A time=00:11:07.35 bitrate=N/A speed=2.77x frame=40092 fps=166 q=31.0 size=N/A time=00:11:08.91 bitrate=N/A speed=2.77x frame=40178 fps=166 q=31.0 size=N/A time=00:11:10.42 bitrate=N/A speed=2.77x frame=40266 fps=166 q=31.0 size=N/A time=00:11:11.79 bitrate=N/A speed=2.77x frame=40374 fps=166 q=31.0 size=N/A time=00:11:13.61 bitrate=N/A speed=2.77x frame=40438 fps=166 q=36.0 size=N/A time=00:11:14.76 bitrate=N/A speed=2.77x frame=40528 fps=166 q=31.0 size=N/A time=00:11:16.27 bitrate=N/A speed=2.77x
dcook 303 Posted March 24, 2017 Author Posted March 24, 2017 I also noticed that its not showing the transcode progress in the dashboard: Before it would be a Red bar which was the transcode, and the green bar was the stream. I also can not skip forward or fast forward at all.
pir8radio 1313 Posted March 24, 2017 Posted March 24, 2017 (edited) I have throttling enabled and I use process lasso to limit my ffmpeg to specific cores, you can also use it to limit to certain CPU % per instance. I found that with a busy server limiting it to specific threads, cores, virtualcores whatever you want to call them was the best balance between fast encoding for a busy server and keeping enough CPU open to keep the gui snappy. Another thread on this: https://emby.media/community/index.php?/topic/36352-how-many-user-can-i-use/?p=342824 I still get fast encode times at the start of a movie while process lasso limits ffmpeg's CPU usage, then throttling starts to tone down the FPS. EDIT: @@dcook I'm sorry buddy, I didn't look that this post was in linux... Shame on me... In an attempt to make up for my mistake I did find an alternative to process lasso for linux... https://www.cyberciti.biz/faq/cpu-usage-limiter-for-linux/ Press [q] to stop, [?] for help frame= 138 fps=0.0 q=26.0 size=N/A time=00:00:05.90 bitrate=N/A speed=11.8x frame= 273 fps=273 q=24.0 size=N/A time=00:00:11.43 bitrate=N/A speed=11.4x frame= 410 fps=273 q=24.0 size=N/A time=00:00:17.10 bitrate=N/A speed=11.4x frame= 528 fps=264 q=21.0 size=N/A time=00:00:22.16 bitrate=N/A speed=11.1x frame= 649 fps=260 q=18.0 size=N/A time=00:00:27.11 bitrate=N/A speed=10.8x frame= 726 fps=242 q=26.0 size=N/A time=00:00:30.44 bitrate=N/A speed=10.1x frame= 819 fps=234 q=25.0 size=N/A time=00:00:34.13 bitrate=N/A speed=9.75x frame= 926 fps=231 q=24.0 size=N/A time=00:00:38.59 bitrate=N/A speed=9.65x frame= 1000 fps=222 q=24.0 size=N/A time=00:00:41.85 bitrate=N/A speed= 9.3x frame= 1086 fps=217 q=24.0 size=N/A time=00:00:45.35 bitrate=N/A speed=9.07x frame= 1187 fps=216 q=24.0 size=N/A time=00:00:49.45 bitrate=N/A speed=8.99x frame= 1277 fps=213 q=25.0 size=N/A time=00:00:53.44 bitrate=N/A speed=8.91x frame= 1379 fps=212 q=31.0 size=N/A time=00:00:57.66 bitrate=N/A speed=8.87x frame= 1470 fps=210 q=31.0 size=N/A time=00:01:01.31 bitrate=N/A speed=8.76x frame= 1583 fps=211 q=27.0 size=N/A time=00:01:05.96 bitrate=N/A speed=8.79x frame= 1686 fps=211 q=26.0 size=N/A time=00:01:10.33 bitrate=N/A speed=8.79x frame= 1770 fps=208 q=30.0 size=N/A time=00:01:13.81 bitrate=N/A speed=8.68x frame= 1881 fps=209 q=26.0 size=N/A time=00:01:18.54 bitrate=N/A speed=8.73x frame= 2000 fps=211 q=26.0 size=N/A time=00:01:23.39 bitrate=N/A speed=8.78x frame= 2118 fps=212 q=26.0 size=N/A time=00:01:28.27 bitrate=N/A speed=8.83x frame= 2226 fps=212 q=29.0 size=N/A time=00:01:32.82 bitrate=N/A speed=8.84x frame= 2328 fps=212 q=25.0 size=N/A time=00:01:37.02 bitrate=N/A speed=8.82x frame= 2393 fps=208 q=23.0 size=N/A time=00:01:39.84 bitrate=N/A speed=8.68x frame= 2496 fps=208 q=24.0 size=N/A time=00:01:44.21 bitrate=N/A speed=8.68x frame= 2598 fps=208 q=22.0 size=N/A time=00:01:48.37 bitrate=N/A speed=8.67x frame= 2679 fps=206 q=23.0 size=N/A time=00:01:51.74 bitrate=N/A speed= 8.6x frame= 2752 fps=204 q=25.0 size=N/A time=00:01:54.98 bitrate=N/A speed=8.52x frame= 2837 fps=203 q=24.0 size=N/A time=00:01:58.40 bitrate=N/A speed=8.46x frame= 2935 fps=202 q=27.0 size=N/A time=00:02:02.36 bitrate=N/A speed=8.44x frame= 3041 fps=203 q=25.0 size=N/A time=00:02:06.80 bitrate=N/A speed=8.45x frame= 3124 fps=202 q=25.0 size=N/A time=00:02:10.47 bitrate=N/A speed=8.42x frame= 3232 fps=202 q=25.0 size=N/A time=00:02:14.76 bitrate=N/A speed=8.42x frame= 3327 fps=202 q=25.0 size=N/A time=00:02:18.81 bitrate=N/A speed=8.41x frame= 3449 fps=203 q=24.0 size=N/A time=00:02:23.78 bitrate=N/A speed=8.46x frame= 3536 fps=202 q=23.0 size=N/A time=00:02:27.56 bitrate=N/A speed=8.43x frame= 3661 fps=203 q=23.0 size=N/A time=00:02:32.68 bitrate=N/A speed=8.48x frame= 3772 fps=204 q=25.0 size=N/A time=00:02:37.46 bitrate=N/A speed=8.51x frame= 3864 fps=203 q=25.0 size=N/A time=00:02:41.28 bitrate=N/A speed=8.49x frame= 3956 fps=203 q=26.0 size=N/A time=00:02:44.99 bitrate=N/A speed=8.46x frame= 4040 fps=202 q=22.0 size=N/A time=00:02:48.51 bitrate=N/A speed=8.43x frame= 4161 fps=203 q=21.0 size=N/A time=00:02:53.61 bitrate=N/A speed=8.47x frame= 4267 fps=203 q=22.0 size=N/A time=00:02:58.02 bitrate=N/A speed=8.48x frame= 4382 fps=204 q=24.0 size=N/A time=00:03:02.84 bitrate=N/A speed= 8.5x Edited March 24, 2017 by pir8radio
Luke 42245 Posted March 24, 2017 Posted March 24, 2017 You should always be able to skip forward and back. If you can't, then please discuss a specific example and provide the information requested in how to report a media playback issue. Thanks !
dcook 303 Posted March 24, 2017 Author Posted March 24, 2017 @@Luke you could skip forward and back but only for few seconds. For example when the episode stopped playing, I clicked play again and I was going to just skip forward to the same spot, however when I pressed the skip forward button it would only go about 15 seconds. I attached screen capture of the dashboard, you can see there is no red or green progress bars Logs are attached. You should always be able to skip forward and back. If you can't, then please discuss a specific example and provide the information requested in how to report a media playback issue. Thanks ! log1.txt log2.txt server.txt
Luke 42245 Posted March 24, 2017 Posted March 24, 2017 The skip buttons only move 15 seconds, so this is by design. Emby Theater allows you to configure the skip length but that hasn't made it into other apps just yet. What were you expecting it to do?
dcook 303 Posted March 24, 2017 Author Posted March 24, 2017 (edited) I was expecting to be able to skip or fast forward right up to the spot where it stop playing but when I did, it did not show the entire episode length Here is example: This episode is 43 minutes long, but when I try to skip forward the most I can go is 1 min 24 seconds Its almost like Emby does not know that its 43 mins long and because I had watched about 38 minutes of it before it unexpectedly stopped playing I had no way to fast forward or skip forward to the 38 minute mark The skip buttons only move 15 seconds, so this is by design. Emby Theater allows you to configure the skip length but that hasn't made it into other apps just yet. What were you expecting it to do? Edited March 24, 2017 by dcook
dcook 303 Posted March 24, 2017 Author Posted March 24, 2017 That is the new Roku App I also tried the same with the Classic Roku App and same behavior, does not show the entire minutes of the episode Which Emby app is that?
Luke 42245 Posted March 24, 2017 Posted March 24, 2017 There is no media info for that item. that means either you just added it and the library scan hasn't finished yet, or something went wrong at the time that you added it (e.g. missing ffmpeg build). So without media info that explains that. Try refreshing it from the web app detail screen using the 3-dot menu, then try to play again from Roku.
dcook 303 Posted March 24, 2017 Author Posted March 24, 2017 @@Luke I will try via the web later tonight If that was the issue would it also cause the high CPU for ffmpeg? Should I install the latest ffmpeg build instead? I don't think 1 stream should need 374% of all 4 cores
Luke 42245 Posted March 24, 2017 Posted March 24, 2017 Refresh first then re-evaluate because the stream will be entirely different. thanks.
