Nathanio 35 Posted March 23, 2017 Posted March 23, 2017 (edited) Hi Guys, just tried the latest version with the seeking of live tv and the starting has been a little hit and miss. I tried to start BBC1HD and I got the spinning pizza of doom (as my wife calls it). See the server log: http://172.0.0.1:8096/emby/videos/cd85eb06191c3f035679be4fc307a8dc/live.m3u8?DeviceId=d9817f6026fe3234&MediaSourceId=c806591b13c54635a9550b9a3b747604_native_8504716b6ef9696a685111ba10c1b306&VideoCodec=h264,mpeg2video&AudioCodec=ac3,eac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=71796451&AudioBitrate=384000&MaxAudioChannels=8&PlaySessionId=618bb3d3fdad4150a761175e8b08ffd2&api_key=401cebda0c17436b962d90b302c89d1c&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_c806591b13c54635a9550b9a3b747604_native_8504716b6ef9696a685111ba10c1b306&CopyTimestamps=false&EnableSubtitlesInManifest=false&RequireAvc=false&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts {"Protocol":"Http","Id":"c806591b13c54635a9550b9a3b747604_native_8504716b6ef9696a685111ba10c1b306","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/040656c66bd14d0f91612a944fa19f1a/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"SupportsProbing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_c806591b13c54635a9550b9a3b747604_native_8504716b6ef9696a685111ba10c1b306","BufferMs":0,"MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"BitRate":8000000,"BitDepth":8,"RefFrames":4,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"aac_latm","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC_LATM 5.1","IsInterlaced":false,"ChannelLayout":"5.1","Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dvbsub","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/90000","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":8000000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":2000,"DefaultAudioStreamIndex":1} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -analyzeduration 2000000 -f mpegts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/040656c66bd14d0f91612a944fa19f1a/stream.ts" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -flags -global_header -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -codec:a:0 ac3 -ac 6 -ab 384000 -af "adelay=1,aresample=async=1" -hls_time 3 -individual_header_trailer 0 -start_number 0 -hls_list_size 0 -hls_base_url "hls/2ffdf9afbad01106efc821110c41ad52/" -y "S:\Transcode\transcoding-temp\2ffdf9afbad01106efc821110c41ad52.m3u8" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 2 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 2 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 2 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 2 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 2 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000003ae680] decode_slice_header error [h264 @ 00000000003ae680] no frame! [h264 @ 00000000003ae680] mmco: unref short failure Last message repeated 2 times [h264 @ 00000000003ae680] Increasing reorder buffer to 2 [h264 @ 00000000003ae680] Increasing reorder buffer to 3 [h264 @ 00000000003ae680] mmco: unref short failure Last message repeated 1 times [h264 @ 00000000003ae680] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one [mpegts @ 00000000003a9fc0] Could not find codec parameters for stream 2 (Unknown: none ([17][0][0][0] / 0x0011)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000003a9fc0] Could not find codec parameters for stream 4 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000003a9fc0] Could not find codec parameters for stream 5 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000003a9fc0] Could not find codec parameters for stream 6 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000003a9fc0] Could not find codec parameters for stream 7 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/040656c66bd14d0f91612a944fa19f1a/stream.ts': Duration: N/A, start: 94710.711711, bitrate: N/A Program 17540 Stream #0:0[0x19c9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x19ca](eng): Audio: aac_latm (LC) ([17][0][0][0] / 0x0011), 48000 Hz, 5.1, fltp Stream #0:2[0x19ce](eng): Unknown: none ([17][0][0][0] / 0x0011) (visual impaired) Stream #0:3[0x19cd](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x19fa]: Unknown: none ([5][0][0][0] / 0x0005) Stream #0:5[0x1c86]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:6[0x1c97]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:7[0x1c66]: Unknown: none ([5][0][0][0] / 0x0005) Output #0, hls, to 'S:\Transcode\transcoding-temp\2ffdf9afbad01106efc821110c41ad52.m3u8': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 90k tbn, 25 tbc Stream #0:1: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s Metadata: encoder : Lavc57.34.100 ac3 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (aac_latm (native) -> ac3 (native)) Press [q] to stop, [?] for help [hls @ 00000000046c0840] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [hls @ 00000000046c0840] Non-monotonous DTS in output stream 0:0; previous: 105073, current: 105073; changing to 105074. This may result in incorrect timestamps in the output file. [mpegts @ 0000000002dfbbe0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly frame= 104 fps=0.0 q=-1.0 size=N/A time=00:00:03.28 bitrate=N/A speed=5.85x frame= 117 fps=104 q=-1.0 size=N/A time=00:00:03.80 bitrate=N/A speed=3.39x frame= 129 fps= 77 q=-1.0 size=N/A time=00:00:04.28 bitrate=N/A speed=2.54x frame= 147 fps= 65 q=-1.0 size=N/A time=00:00:05.00 bitrate=N/A speed=2.23x frame= 162 fps= 57 q=-1.0 size=N/A time=00:00:05.60 bitrate=N/A speed=1.98x frame= 176 fps= 52 q=-1.0 size=N/A time=00:00:06.16 bitrate=N/A speed=1.81x frame= 203 fps= 51 q=-1.0 size=N/A time=00:00:06.92 bitrate=N/A speed=1.75x frame= 218 fps= 48 q=-1.0 size=N/A time=00:00:07.40 bitrate=N/A speed=1.64x frame= 233 fps= 46 q=-1.0 size=N/A time=00:00:08.00 bitrate=N/A speed=1.57x frame= 260 fps= 46 q=-1.0 size=N/A time=00:00:08.54 bitrate=N/A speed=1.51x frame= 285 fps= 45 q=-1.0 size=N/A time=00:00:09.04 bitrate=N/A speed=1.44x frame= 315 fps= 46 q=-1.0 size=N/A time=00:00:09.64 bitrate=N/A speed=1.41x frame= 338 fps= 46 q=-1.0 size=N/A time=00:00:10.10 bitrate=N/A speed=1.37x frame= 373 fps= 47 q=-1.0 size=N/A time=00:00:10.80 bitrate=N/A speed=1.36x frame= 408 fps= 48 q=-1.0 size=N/A time=00:00:11.50 bitrate=N/A speed=1.35x frame= 435 fps= 48 q=-1.0 size=N/A time=00:00:12.04 bitrate=N/A speed=1.33x frame= 457 fps= 47 q=-1.0 size=N/A time=00:00:12.48 bitrate=N/A speed= 1.3x frame= 483 fps= 47 q=-1.0 size=N/A time=00:00:13.04 bitrate=N/A speed=1.28x frame= 507 fps= 47 q=-1.0 size=N/A time=00:00:13.58 bitrate=N/A speed=1.26x frame= 531 fps= 47 q=-1.0 size=N/A time=00:00:14.08 bitrate=N/A speed=1.24x frame= 559 fps= 47 q=-1.0 size=N/A time=00:00:14.72 bitrate=N/A speed=1.24x frame= 580 fps= 47 q=-1.0 size=N/A time=00:00:15.14 bitrate=N/A speed=1.22x frame= 601 fps= 46 q=-1.0 size=N/A time=00:00:15.64 bitrate=N/A speed= 1.2x frame= 611 fps= 45 q=-1.0 size=N/A time=00:00:16.04 bitrate=N/A speed=1.18x frame= 631 fps= 45 q=-1.0 size=N/A time=00:00:16.76 bitrate=N/A speed=1.19x frame= 668 fps= 45 q=-1.0 size=N/A time=00:00:17.56 bitrate=N/A speed= 1.2x frame= 698 fps= 46 q=-1.0 size=N/A time=00:00:18.16 bitrate=N/A speed=1.19x frame= 725 fps= 46 q=-1.0 size=N/A time=00:00:18.70 bitrate=N/A speed=1.18x frame= 738 fps= 45 q=-1.0 size=N/A time=00:00:19.00 bitrate=N/A speed=1.16x frame= 753 fps= 45 q=-1.0 size=N/A time=00:00:19.60 bitrate=N/A speed=1.16x frame= 763 fps= 44 q=-1.0 size=N/A time=00:00:20.00 bitrate=N/A speed=1.15x frame= 781 fps= 43 q=-1.0 size=N/A time=00:00:20.68 bitrate=N/A speed=1.15x frame= 813 fps= 44 q=-1.0 size=N/A time=00:00:21.36 bitrate=N/A speed=1.15x frame= 832 fps= 43 q=-1.0 size=N/A time=00:00:21.76 bitrate=N/A speed=1.14x frame= 848 fps= 43 q=-1.0 size=N/A time=00:00:22.32 bitrate=N/A speed=1.13x frame= 879 fps= 43 q=-1.0 size=N/A time=00:00:23.10 bitrate=N/A speed=1.14x frame= 911 fps= 44 q=-1.0 size=N/A time=00:00:23.74 bitrate=N/A speed=1.14x frame= 942 fps= 44 q=-1.0 size=N/A time=00:00:24.36 bitrate=N/A speed=1.14x frame= 959 fps= 44 q=-1.0 size=N/A time=00:00:24.70 bitrate=N/A speed=1.13x frame= 972 fps= 43 q=-1.0 size=N/A time=00:00:25.20 bitrate=N/A speed=1.12x frame= 988 fps= 43 q=-1.0 size=N/A time=00:00:25.84 bitrate=N/A speed=1.12x frame= 1007 fps= 43 q=-1.0 size=N/A time=00:00:26.60 bitrate=N/A speed=1.13x frame= 1021 fps= 42 q=-1.0 size=N/A time=00:00:27.16 bitrate=N/A speed=1.12x frame= 1032 fps= 42 q=-1.0 size=N/A time=00:00:27.60 bitrate=N/A speed=1.12x frame= 1048 fps= 41 q=-1.0 size=N/A time=00:00:28.24 bitrate=N/A speed=1.12x frame= 1059 fps= 41 q=-1.0 size=N/A time=00:00:28.56 bitrate=N/A speed=1.11x frame= 1079 fps= 41 q=-1.0 size=N/A time=00:00:29.16 bitrate=N/A speed=1.11x frame= 1094 fps= 41 q=-1.0 size=N/A time=00:00:29.76 bitrate=N/A speed=1.11x frame= 1105 fps= 40 q=-1.0 size=N/A time=00:00:30.08 bitrate=N/A speed= 1.1x frame= 1139 fps= 41 q=-1.0 size=N/A time=00:00:30.76 bitrate=N/A speed= 1.1x frame= 1169 fps= 41 q=-1.0 size=N/A time=00:00:31.36 bitrate=N/A speed= 1.1x frame= 1200 fps= 41 q=-1.0 size=N/A time=00:00:31.98 bitrate=N/A speed= 1.1x frame= 1231 fps= 41 q=-1.0 size=N/A time=00:00:32.60 bitrate=N/A speed= 1.1x frame= 1257 fps= 42 q=-1.0 size=N/A time=00:00:33.12 bitrate=N/A speed=1.09x frame= 1285 fps= 42 q=-1.0 size=N/A time=00:00:33.68 bitrate=N/A speed=1.09x frame= 1312 fps= 42 q=-1.0 size=N/A time=00:00:34.22 bitrate=N/A speed=1.09x frame= 1342 fps= 42 q=-1.0 size=N/A time=00:00:34.82 bitrate=N/A speed=1.09x frame= 1370 fps= 42 q=-1.0 size=N/A time=00:00:35.38 bitrate=N/A speed=1.09x frame= 1405 fps= 42 q=-1.0 size=N/A time=00:00:36.08 bitrate=N/A speed=1.09x frame= 1431 fps= 43 q=-1.0 size=N/A time=00:00:36.60 bitrate=N/A speed=1.09x frame= 1459 fps= 43 q=-1.0 size=N/A time=00:00:37.16 bitrate=N/A speed=1.09x frame= 1479 fps= 43 q=-1.0 size=N/A time=00:00:37.56 bitrate=N/A speed=1.08x frame= 1495 fps= 42 q=-1.0 size=N/A time=00:00:37.88 bitrate=N/A speed=1.07x frame= 1521 fps= 42 q=-1.0 size=N/A time=00:00:38.40 bitrate=N/A speed=1.07x frame= 1536 fps= 42 q=-1.0 size=N/A time=00:00:38.70 bitrate=N/A speed=1.06x frame= 1575 fps= 43 q=-1.0 size=N/A time=00:00:39.48 bitrate=N/A speed=1.07x frame= 1609 fps= 43 q=-1.0 size=N/A time=00:00:40.16 bitrate=N/A speed=1.07x frame= 1640 fps= 43 q=-1.0 size=N/A time=00:00:40.78 bitrate=N/A speed=1.07x frame= 1664 fps= 43 q=-1.0 size=N/A time=00:00:41.44 bitrate=N/A speed=1.07x frame= 1696 fps= 43 q=-1.0 size=N/A time=00:00:42.08 bitrate=N/A speed=1.07x frame= 1724 fps= 43 q=-1.0 size=N/A time=00:00:42.64 bitrate=N/A speed=1.07x frame= 1754 fps= 44 q=-1.0 size=N/A time=00:00:43.26 bitrate=N/A speed=1.07x So I tried the problem with the playback option in the pop up menu and it eventually started a stream: http://172.0.0.1:8096/emby/videos/cd85eb06191c3f035679be4fc307a8dc/live.m3u8?DeviceId=d9817f6026fe3234&MediaSourceId=7b880944b9d840849d493d332d6b70d6_native_8504716b6ef9696a685111ba10c1b306&VideoCodec=h264,mpeg2video&AudioCodec=ac3,eac3,aac,mp3&AudioStreamIndex=1&VideoBitrate=71796451&AudioBitrate=384000&MaxAudioChannels=8&PlaySessionId=1241f047999446b4bd09a58b224caaba&api_key=401cebda0c17436b962d90b302c89d1c&LiveStreamId=a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_7b880944b9d840849d493d332d6b70d6_native_8504716b6ef9696a685111ba10c1b306&CopyTimestamps=false&EnableSubtitlesInManifest=false&RequireAvc=false&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts {"Protocol":"Http","Id":"7b880944b9d840849d493d332d6b70d6_native_8504716b6ef9696a685111ba10c1b306","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/96ce443d03754cf19b0667edaaadf735/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"SupportsProbing":true,"LiveStreamId":"a17c75760a04e99b68cf766e11316e1c_09efa0d56b934a82adec00a87b837fb0_7b880944b9d840849d493d332d6b70d6_native_8504716b6ef9696a685111ba10c1b306","BufferMs":0,"MediaStreams":[{"Codec":"h264","TimeBase":"1/90000","CodecTimeBase":"1/50","NalLengthSize":"0","IsInterlaced":false,"BitRate":8000000,"BitDepth":8,"RefFrames":4,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"aac_latm","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Eng AAC_LATM 5.1","IsInterlaced":false,"ChannelLayout":"5.1","Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"dvbsub","Language":"eng","TimeBase":"1/90000","CodecTimeBase":"1/90000","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":8000000,"RequiredHttpHeaders":{},"AnalyzeDurationMs":2000,"DefaultAudioStreamIndex":1} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -analyzeduration 2000000 -f mpegts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/96ce443d03754cf19b0667edaaadf735/stream.ts" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -flags -global_header -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -codec:a:0 ac3 -ac 6 -ab 384000 -af "adelay=1,aresample=async=1" -hls_time 3 -individual_header_trailer 0 -start_number 0 -hls_list_size 0 -hls_base_url "hls/18a8e79e9c1cb8e6087f6fb85546b9d2/" -y "S:\Transcode\transcoding-temp\18a8e79e9c1cb8e6087f6fb85546b9d2.m3u8" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [h264 @ 00000000004de680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000004de680] decode_slice_header error [h264 @ 00000000004de680] no frame! [h264 @ 00000000004de680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000004de680] decode_slice_header error [h264 @ 00000000004de680] no frame! [h264 @ 00000000004de680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000004de680] decode_slice_header error [h264 @ 00000000004de680] no frame! [h264 @ 00000000004de680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000004de680] decode_slice_header error [h264 @ 00000000004de680] no frame! [h264 @ 00000000004de680] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 00000000004de680] decode_slice_header error [h264 @ 00000000004de680] no frame! [h264 @ 00000000004de680] mmco: unref short failure Last message repeated 2 times [h264 @ 00000000004de680] Increasing reorder buffer to 2 [h264 @ 00000000004de680] mmco: unref short failure [h264 @ 00000000004de680] Increasing reorder buffer to 3 [mpegts @ 00000000004d9fc0] Could not find codec parameters for stream 2 (Unknown: none ([17][0][0][0] / 0x0011)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004d9fc0] Could not find codec parameters for stream 4 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004d9fc0] Could not find codec parameters for stream 5 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004d9fc0] Could not find codec parameters for stream 6 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options [mpegts @ 00000000004d9fc0] Could not find codec parameters for stream 7 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/96ce443d03754cf19b0667edaaadf735/stream.ts': Duration: N/A, start: 94786.402378, bitrate: N/A Program 17540 Stream #0:0[0x19c9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 24.75 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1[0x19ca](eng): Audio: aac_latm (LC) ([17][0][0][0] / 0x0011), 48000 Hz, 5.1, fltp Stream #0:2[0x19ce](eng): Unknown: none ([17][0][0][0] / 0x0011) (visual impaired) Stream #0:3[0x19cd](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006) Stream #0:4[0x19fa]: Unknown: none ([5][0][0][0] / 0x0005) Stream #0:5[0x1c86]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:6[0x1c97]: Unknown: none ([11][0][0][0] / 0x000B) Stream #0:7[0x1c66]: Unknown: none ([5][0][0][0] / 0x0005) Output #0, hls, to 'S:\Transcode\transcoding-temp\18a8e79e9c1cb8e6087f6fb85546b9d2.m3u8': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 24.75 fps, 25 tbr, 90k tbn, 25 tbc Stream #0:1: Audio: ac3, 48000 Hz, 5.1, fltp, 384 kb/s Metadata: encoder : Lavc57.34.100 ac3 Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (aac_latm (native) -> ac3 (native)) Press [q] to stop, [?] for help [hls @ 0000000003dd0020] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [hls @ 0000000003dd0020] Non-monotonous DTS in output stream 0:0; previous: 100513, current: 100513; changing to 100514. This may result in incorrect timestamps in the output file. [mpegts @ 000000000314f260] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [aac_latm @ 00000000049ae000] audio config changed [aac_latm @ 00000000049ae000] Number of bands (27) exceeds limit (10). Error while decoding stream #0:1: Invalid data found when processing input [aac_latm @ 00000000049ae000] audio config changed Input stream #0:1 frame changed from rate:48000 fmt:fltp ch:6 chl:5.1 to rate:48000 fmt:fltp ch:2 chl:stereo frame= 53 fps=0.0 q=-1.0 size=N/A time=00:00:02.95 bitrate=N/A speed=5.26x frame= 77 fps= 69 q=-1.0 size=N/A time=00:00:03.91 bitrate=N/A speed=3.49x frame= 77 fps= 46 q=-1.0 size=N/A time=00:00:03.91 bitrate=N/A speed=2.32x frame= 101 fps= 45 q=-1.0 size=N/A time=00:00:04.87 bitrate=N/A speed=2.17x frame= 109 fps= 39 q=-1.0 size=N/A time=00:00:05.19 bitrate=N/A speed=1.85x frame= 125 fps= 37 q=-1.0 size=N/A time=00:00:05.83 bitrate=N/A speed=1.73x frame= 141 fps= 36 q=-1.0 size=N/A time=00:00:06.47 bitrate=N/A speed=1.64x frame= 149 fps= 33 q=-1.0 size=N/A time=00:00:06.79 bitrate=N/A speed=1.51x frame= 173 fps= 34 q=-1.0 size=N/A time=00:00:07.75 bitrate=N/A speed=1.53x frame= 177 fps= 31 q=-1.0 size=N/A time=00:00:07.91 bitrate=N/A speed=1.41x frame= 197 fps= 32 q=-1.0 size=N/A time=00:00:08.71 bitrate=N/A speed=1.41x frame= 222 fps= 33 q=-1.0 size=N/A time=00:00:09.71 bitrate=N/A speed=1.44x frame= 227 fps= 31 q=-1.0 size=N/A time=00:00:09.91 bitrate=N/A speed=1.36x frame= 228 fps= 29 q=-1.0 size=N/A time=00:00:09.95 bitrate=N/A speed=1.27x frame= 243 fps= 29 q=-1.0 size=N/A time=00:00:10.55 bitrate=N/A speed=1.26x frame= 261 fps= 29 q=-1.0 size=N/A time=00:00:11.27 bitrate=N/A speed=1.26x frame= 279 fps= 29 q=-1.0 size=N/A time=00:00:11.99 bitrate=N/A speed=1.26x frame= 296 fps= 30 q=-1.0 size=N/A time=00:00:12.67 bitrate=N/A speed=1.26x frame= 315 fps= 30 q=-1.0 size=N/A time=00:00:13.43 bitrate=N/A speed=1.27x frame= 332 fps= 30 q=-1.0 size=N/A time=00:00:14.11 bitrate=N/A speed=1.27x frame= 346 fps= 30 q=-1.0 size=N/A time=00:00:14.67 bitrate=N/A speed=1.26x frame= 358 fps= 29 q=-1.0 size=N/A time=00:00:15.15 bitrate=N/A speed=1.24x frame= 368 fps= 29 q=-1.0 size=N/A time=00:00:15.55 bitrate=N/A speed=1.22x frame= 379 fps= 28 q=-1.0 size=N/A time=00:00:15.99 bitrate=N/A speed= 1.2x frame= 384 fps= 28 q=-1.0 size=N/A time=00:00:16.19 bitrate=N/A speed=1.17x frame= 408 fps= 28 q=-1.0 size=N/A time=00:00:17.15 bitrate=N/A speed=1.19x frame= 424 fps= 28 q=-1.0 size=N/A time=00:00:17.79 bitrate=N/A speed=1.19x frame= 436 fps= 28 q=-1.0 size=N/A time=00:00:18.27 bitrate=N/A speed=1.18x frame= 448 fps= 28 q=-1.0 size=N/A time=00:00:18.75 bitrate=N/A speed=1.17x frame= 457 fps= 27 q=-1.0 size=N/A time=00:00:19.11 bitrate=N/A speed=1.15x frame= 468 fps= 27 q=-1.0 size=N/A time=00:00:19.55 bitrate=N/A speed=1.14x frame= 484 fps= 27 q=-1.0 size=N/A time=00:00:20.19 bitrate=N/A speed=1.14x frame= 502 fps= 27 q=-1.0 size=N/A time=00:00:20.91 bitrate=N/A speed=1.14x frame= 521 fps= 28 q=-1.0 size=N/A time=00:00:21.67 bitrate=N/A speed=1.15x frame= 536 fps= 28 q=-1.0 size=N/A time=00:00:22.27 bitrate=N/A speed=1.15x frame= 542 fps= 27 q=-1.0 size=N/A time=00:00:22.51 bitrate=N/A speed=1.13x frame= 556 fps= 27 q=-1.0 size=N/A time=00:00:23.07 bitrate=N/A speed=1.12x frame= 577 fps= 27 q=-1.0 size=N/A time=00:00:23.91 bitrate=N/A speed=1.13x frame= 595 fps= 27 q=-1.0 size=N/A time=00:00:24.63 bitrate=N/A speed=1.14x frame= 606 fps= 27 q=-1.0 size=N/A time=00:00:25.07 bitrate=N/A speed=1.13x frame= 621 fps= 27 q=-1.0 size=N/A time=00:00:25.67 bitrate=N/A speed=1.13x frame= 630 fps= 27 q=-1.0 size=N/A time=00:00:26.03 bitrate=N/A speed=1.11x frame= 640 fps= 27 q=-1.0 size=N/A time=00:00:26.43 bitrate=N/A speed=1.11x frame= 662 fps= 27 q=-1.0 size=N/A time=00:00:27.31 bitrate=N/A speed=1.12x frame= 679 fps= 27 q=-1.0 size=N/A time=00:00:27.99 bitrate=N/A speed=1.12x frame= 692 fps= 27 q=-1.0 size=N/A time=00:00:28.51 bitrate=N/A speed=1.12x frame= 700 fps= 27 q=-1.0 size=N/A time=00:00:28.83 bitrate=N/A speed= 1.1x frame= 716 fps= 27 q=-1.0 size=N/A time=00:00:29.47 bitrate=N/A speed=1.11x frame= 725 fps= 27 q=-1.0 size=N/A time=00:00:29.83 bitrate=N/A speed= 1.1x frame= 740 fps= 27 q=-1.0 size=N/A time=00:00:30.43 bitrate=N/A speed= 1.1x frame= 757 fps= 27 q=-1.0 size=N/A time=00:00:31.11 bitrate=N/A speed= 1.1x frame= 764 fps= 26 q=-1.0 size=N/A time=00:00:31.39 bitrate=N/A speed=1.09x frame= 788 fps= 27 q=-1.0 size=N/A time=00:00:32.35 bitrate=N/A speed= 1.1x frame= 792 fps= 26 q=-1.0 size=N/A time=00:00:32.51 bitrate=N/A speed=1.08x frame= 813 fps= 27 q=-1.0 size=N/A time=00:00:33.31 bitrate=N/A speed=1.09x frame= 817 fps= 26 q=-1.0 size=N/A time=00:00:33.47 bitrate=N/A speed=1.07x frame= 829 fps= 26 q=-1.0 size=N/A time=00:00:33.95 bitrate=N/A speed=1.07x frame= 844 fps= 26 q=-1.0 size=N/A time=00:00:34.55 bitrate=N/A speed=1.07x frame= 861 fps= 26 q=-1.0 size=N/A time=00:00:35.23 bitrate=N/A speed=1.07x frame= 878 fps= 26 q=-1.0 size=N/A time=00:00:35.91 bitrate=N/A speed=1.08x frame= 898 fps= 26 q=-1.0 size=N/A time=00:00:36.71 bitrate=N/A speed=1.08x frame= 916 fps= 27 q=-1.0 size=N/A time=00:00:37.43 bitrate=N/A speed=1.09x frame= 926 fps= 26 q=-1.0 size=N/A time=00:00:37.83 bitrate=N/A speed=1.08x frame= 939 fps= 26 q=-1.0 size=N/A time=00:00:38.35 bitrate=N/A speed=1.08x frame= 952 fps= 26 q=-1.0 size=N/A time=00:00:38.87 bitrate=N/A speed=1.08x frame= 965 fps= 26 q=-1.0 size=N/A time=00:00:39.39 bitrate=N/A speed=1.08x frame= 981 fps= 26 q=-1.0 size=N/A time=00:00:40.03 bitrate=N/A speed=1.08x frame= 992 fps= 26 q=-1.0 size=N/A time=00:00:40.47 bitrate=N/A speed=1.07x frame= 1000 fps= 26 q=-1.0 size=N/A time=00:00:40.79 bitrate=N/A speed=1.07x frame= 1013 fps= 26 q=-1.0 size=N/A time=00:00:41.31 bitrate=N/A speed=1.06x frame= 1029 fps= 26 q=-1.0 size=N/A time=00:00:41.95 bitrate=N/A speed=1.07x frame= 1046 fps= 26 q=-1.0 size=N/A time=00:00:42.63 bitrate=N/A speed=1.07x frame= 1062 fps= 26 q=-1.0 size=N/A time=00:00:43.27 bitrate=N/A speed=1.07x frame= 1080 fps= 26 q=-1.0 size=N/A time=00:00:43.99 bitrate=N/A speed=1.07x frame= 1095 fps= 26 q=-1.0 size=N/A time=00:00:44.59 bitrate=N/A speed=1.07x frame= 1109 fps= 26 q=-1.0 size=N/A time=00:00:45.15 bitrate=N/A speed=1.07x frame= 1122 fps= 26 q=-1.0 size=N/A time=00:00:45.67 bitrate=N/A speed=1.07x frame= 1132 fps= 26 q=-1.0 size=N/A time=00:00:46.07 bitrate=N/A speed=1.06x frame= 1144 fps= 26 q=-1.0 size=N/A time=00:00:46.55 bitrate=N/A speed=1.06x frame= 1162 fps= 26 q=-1.0 size=N/A time=00:00:47.27 bitrate=N/A speed=1.06x frame= 1171 fps= 26 q=-1.0 size=N/A time=00:00:47.63 bitrate=N/A speed=1.06x frame= 1178 fps= 26 q=-1.0 size=N/A time=00:00:47.91 bitrate=N/A speed=1.05x frame= 1187 fps= 26 q=-1.0 size=N/A time=00:00:48.15 bitrate=N/A speed=1.05x frame= 1204 fps= 26 q=-1.0 size=N/A time=00:00:48.83 bitrate=N/A speed=1.05x frame= 1227 fps= 26 q=-1.0 size=N/A time=00:00:49.75 bitrate=N/A speed=1.05x frame= 1242 fps= 26 q=-1.0 size=N/A time=00:00:50.35 bitrate=N/A speed=1.05x frame= 1257 fps= 26 q=-1.0 size=N/A time=00:00:50.95 bitrate=N/A speed=1.05x frame= 1274 fps= 26 q=-1.0 size=N/A time=00:00:51.63 bitrate=N/A speed=1.06x frame= 1285 fps= 26 q=-1.0 size=N/A time=00:00:52.07 bitrate=N/A speed=1.05x frame= 1300 fps= 26 q=-1.0 size=N/A time=00:00:52.67 bitrate=N/A speed=1.05x frame= 1318 fps= 26 q=-1.0 size=N/A time=00:00:53.39 bitrate=N/A speed=1.06x frame= 1332 fps= 26 q=-1.0 size=N/A time=00:00:53.95 bitrate=N/A speed=1.06x frame= 1348 fps= 26 q=-1.0 size=N/A time=00:00:54.59 bitrate=N/A speed=1.06x frame= 1361 fps= 26 q=-1.0 size=N/A time=00:00:55.11 bitrate=N/A speed=1.05x frame= 1373 fps= 26 q=-1.0 size=N/A time=00:00:55.59 bitrate=N/A speed=1.05x frame= 1390 fps= 26 q=-1.0 size=N/A time=00:00:56.27 bitrate=N/A speed=1.05x frame= 1404 fps= 26 q=-1.0 size=N/A time=00:00:56.83 bitrate=N/A speed=1.05x frame= 1420 fps= 26 q=-1.0 size=N/A time=00:00:57.47 bitrate=N/A speed=1.05x frame= 1428 fps= 26 q=-1.0 size=N/A time=00:00:57.79 bitrate=N/A speed=1.05x frame= 1438 fps= 26 q=-1.0 size=N/A time=00:00:58.19 bitrate=N/A speed=1.05x frame= 1451 fps= 26 q=-1.0 size=N/A time=00:00:58.71 bitrate=N/A speed=1.05x frame= 1466 fps= 26 q=-1.0 size=N/A time=00:00:59.31 bitrate=N/A speed=1.05x frame= 1477 fps= 26 q=-1.0 size=N/A time=00:00:59.75 bitrate=N/A speed=1.04x frame= 1492 fps= 26 q=-1.0 size=N/A time=00:01:00.35 bitrate=N/A speed=1.04x frame= 1509 fps= 26 q=-1.0 size=N/A time=00:01:01.03 bitrate=N/A speed=1.05x frame= 1524 fps= 26 q=-1.0 size=N/A time=00:01:01.63 bitrate=N/A speed=1.05x frame= 1540 fps= 26 q=-1.0 size=N/A time=00:01:02.27 bitrate=N/A speed=1.05x frame= 1554 fps= 26 q=-1.0 size=N/A time=00:01:02.83 bitrate=N/A speed=1.05x frame= 1567 fps= 26 q=-1.0 size=N/A time=00:01:03.35 bitrate=N/A speed=1.05x frame= 1581 fps= 26 q=-1.0 size=N/A time=00:01:03.91 bitrate=N/A speed=1.04x frame= 1588 fps= 26 q=-1.0 size=N/A time=00:01:04.19 bitrate=N/A speed=1.04x frame= 1599 fps= 26 q=-1.0 size=N/A time=00:01:04.63 bitrate=N/A speed=1.04x frame= 1618 fps= 26 q=-1.0 size=N/A time=00:01:05.39 bitrate=N/A speed=1.04x frame= 1635 fps= 26 q=-1.0 size=N/A time=00:01:06.07 bitrate=N/A speed=1.04x frame= 1654 fps= 26 q=-1.0 size=N/A time=00:01:06.83 bitrate=N/A speed=1.05x frame= 1667 fps= 26 q=-1.0 size=N/A time=00:01:07.35 bitrate=N/A speed=1.05x frame= 1672 fps= 26 q=-1.0 size=N/A time=00:01:07.55 bitrate=N/A speed=1.04x frame= 1691 fps= 26 q=-1.0 size=N/A time=00:01:08.31 bitrate=N/A speed=1.04x frame= 1708 fps= 26 q=-1.0 size=N/A time=00:01:08.99 bitrate=N/A speed=1.04x frame= 1721 fps= 26 q=-1.0 size=N/A time=00:01:09.51 bitrate=N/A speed=1.04x frame= 1730 fps= 26 q=-1.0 size=N/A time=00:01:09.87 bitrate=N/A speed=1.04x frame= 1741 fps= 26 q=-1.0 size=N/A time=00:01:10.31 bitrate=N/A speed=1.04x frame= 1754 fps= 26 q=-1.0 size=N/A time=00:01:10.83 bitrate=N/A speed=1.04x frame= 1771 fps= 26 q=-1.0 size=N/A time=00:01:11.51 bitrate=N/A speed=1.04x frame= 1788 fps= 26 q=-1.0 size=N/A time=00:01:12.19 bitrate=N/A speed=1.04x frame= 1802 fps= 26 q=-1.0 size=N/A time=00:01:12.75 bitrate=N/A speed=1.04x frame= 1818 fps= 26 q=-1.0 size=N/A time=00:01:13.39 bitrate=N/A speed=1.04x frame= 1828 fps= 26 q=-1.0 size=N/A time=00:01:13.79 bitrate=N/A speed=1.04x frame= 1844 fps= 26 q=-1.0 size=N/A time=00:01:14.43 bitrate=N/A speed=1.04x frame= 1854 fps= 26 q=-1.0 size=N/A time=00:01:14.83 bitrate=N/A speed=1.04x It ended playing back video fine but the audio sounded like it was in a submarine or through a wall. SD channels are playing fine. I have sent the logs from AFTVbox. When it worked though it was awesome and I could fast forward and rewind happily Edited March 24, 2017 by Nathanio
maegibbons 1287 Posted March 23, 2017 Posted March 23, 2017 Hi I can confirm I see the same from HDHR Connect. Is yours from HDHomerun? Again SD is absolutely fine. HD is also fine from IPTV. TBH I do not use the HD from the Homeruns as I just find it jitters a lot and just not smooth anyway - so no big loss for me. Krs Mark
Nathanio 35 Posted March 24, 2017 Author Posted March 24, 2017 Hi Mark, HDHomeRun connect HDHR4-2DT. Records just fine on HD and used to playback HD ok. Once it gets going it works a treat.
