ITGuyfromHELL 0 Posted February 9, 2014 Posted February 9, 2014 MB Server version Version 3.0.5135.31685 Just downloaded and installed MBC last night 2-8-2014. (sorry, wife is watching a movie right now so I can't look at the exact version) MBC running on a Core-2 Quad 4GB RAM I keep switching back and forth from MB Theater to MB Classic. I love the look of the themes, ROC, Breeze, Aztec, etc, but they all perform so poorly for me. I experience stuttering when scrolling through the titles in my movies, sometimes it locks up and I have to close MBC. Other times it will sit on one screen for an extended time, I cannot change screens or back out, and then it will just jump to a different screen all of a sudden. I don't see any other issues being posted here about this issue, so I am assuming it is just me. But I wanted to make sure before I ripped out the HDD and replace it with a faster one, it is the sole weak spot in my setup. My server is an actual server, 2x Xeon processors, 16GB RAM, 8x 1TB HDD drives with the C: using 250GB in a RAID 5 and the remaining 5.27TB in a RAID 50, running on a gigabit network. So, do I need an SSD in my endpoint or should MBC and Breeze, or ROC work fine running on the generic 7200RPM I am currently running on?
AgileHumor 123 Posted February 9, 2014 Posted February 9, 2014 (edited) I have an I7 with SSD and 16GB RAM. I got enough stuttering on Square that I switched it back to Chocolate for the WAF. It may be because I have a camera server that averages 5% cpu. No solutions, but I'm sure it will get better after a few months. MBC is only 6 months old. Edited February 9, 2014 by AgileHumor
ITGuyfromHELL 0 Posted February 9, 2014 Author Posted February 9, 2014 That was something I had considered, that MB3 is still so young and the bugs and kinks will get worked out. But I hadn't read of anyone else having similar issues, and the themes all talk about how smooth and quick they run. Did i fall for their advertising? ;-) So is it just a case of wait and the issue will resolve itself over time as the software matures? I am a fan of MB Theater, but I really love all the eye candy offered by some of the themes in MB Classic. Thanks for the reply.
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 First, test with Chocolate and, if it isn't a problem, then list the specific themes with which it is (the three you listed are all from the same dev with, I believe, a lot of the same core code at the center). But, my first guess would be your graphics card, not your hard drive.
