chef 3811 Posted March 22, 2017 Posted March 22, 2017 Say?! Guys there seems to be limit on how many USB devices that can be connected to my computer setup. If I add a USB hub then devices stop working. Do you think it is because of the power supply doesn't have enough amps to drive a bunch of devices? Or does a computer just stop allowing ports to be used after a certain amount? Would a powered USB hub help my situation? Thanks in advance
Luke 42237 Posted March 22, 2017 Posted March 22, 2017 yes usb has a power limit and a powered hub might resolve it. 1
PenkethBoy 2068 Posted March 22, 2017 Posted March 22, 2017 Not heard of a limit but i always go for a powered hub as it saves pulling power from the pc as its limited by what the ports will supply which off the m/b is not as much as a hub can provide and it depends what type of devices you want to run an unpowered hub is ok for a mouse/keyboard - but not a hdd or similar maybe you are pulling too much current and its dropping the power available to the usb bus and that would affect all of the usb devices or you have a bad hug etc etc 1
Guest asrequested Posted March 22, 2017 Posted March 22, 2017 Well, when they made the first USB port, they daisy chained something like 172 devices before the signal degraded. Do the devices you're using require powered ports? If so, that might be the issue...not enough juice. 1
dredd1963 17 Posted March 22, 2017 Posted March 22, 2017 Hi I use a 5 port usb expansion card with 3 external HDDs with no problems drawing power from my pc. These are not expensive items to buy these days i paid £15.00 off eBay for mine + power lead converter to psu. 1
