Spaceboy 2573 Posted May 3, 2017 Author Posted May 3, 2017 and secondly, there is still an issue with iptv which hopefully another user can confirm. if you have a recording being made and you are watching live tv the live tv stream will always pause as the recording finishes in the background. it seems to happen every time. the only way to fix it is to back out of the stream and restart. i've waited and the video does not restart. That is not true. If you can properly report your issue, we will be happy to look into it. Thanks ! ok logs sent demonstrating this. its right at the end of the log. i was watching bbc news at ten live while it was also recording. the live tv stream paused at exactly the point where the recording finished 22.33.
Luke 42244 Posted May 3, 2017 Posted May 3, 2017 Can you discuss what happened, in what order, and from what apps? thanks.
Spaceboy 2573 Posted May 4, 2017 Author Posted May 4, 2017 (edited) Can you discuss what happened, in what order, and from what apps? thanks. theres nothing further to add. i was watching bbc news on bbc1 hd on the android tv on my shield. bbc news at ten is a daily scheduled recording. the recording started and finished on time with 3 mins padding either side. at 22.33 the live stream of bbc1 HD paused and could not be restarted without backing out of the stream and restarting it. this happens all the time in this scenario, regardless of whether i'm watching the program thats being recorded or any other one. Edited May 4, 2017 by Spaceboy
Spaceboy 2573 Posted May 4, 2017 Author Posted May 4, 2017 For newer setups as long as there is a tvg-id that should no longer happen. sorry but this is rubbish. i've not once had the series recordings preserved and i have done this 10+ times now. every channel that has series recordings set up on it has a unique tvg-id
CBers 7554 Posted June 23, 2017 Posted June 23, 2017 Hi, i've noticed from my first 2 days of heavier usage of live tv through m3u that overlapping recordings consistently don't run to full length. I had 2 consecutive 1 hour (plus padding of 2 before and 3 after) recordings set up, on different channels via IPTV, but the 2nd one ended after only 6 minutes. The 1st one recorded OK. I have the server and ffmpeg logs and will post once I have sanitised them. The reason for this post, is to ask @@Spaceboy if he's still seeing this issue, or if my error is local to me?
CBers 7554 Posted June 23, 2017 Posted June 23, 2017 I have the server and ffmpeg logs and will post once I have sanitised them. This is at the end of the ffmpeg/record-tranacode log: frame=12362 fps= 26 q=-1.0 size= 146143kB time=00:08:14.43 bitrate=2421.4kbits/s speed=1.04x [http @ 0000000000ce3860] HTTP error 502 Bad Gateway Error while filtering: Operation not permitted frame=12364 fps= 26 q=-1.0 Lsize= 146232kB time=00:08:14.51 bitrate=2422.4kbits/s speed=1.04x video:138396kB audio:7950kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Luke 42244 Posted June 23, 2017 Posted June 23, 2017 That could mean anything, like for example provider refusing connection.
CBers 7554 Posted June 23, 2017 Posted June 23, 2017 I had a single recording fail tonight with the following in the record-transcode log: frame=44186 fps= 25 q=-1.0 size= 450238kB time=00:29:27.38 bitrate=2086.9kbits/s speed=1.01x frame=44202 fps= 25 q=-1.0 size= 450374kB time=00:29:28.02 bitrate=2086.8kbits/s speed=1.01x frame=44224 fps= 25 q=-1.0 size= 450561kB time=00:29:28.90 bitrate=2086.6kbits/s speed= 1x Error while filtering: Operation not permitted frame=44224 fps= 25 q=-1.0 Lsize= 450606kB time=00:29:28.90 bitrate=2086.8kbits/s speed= 1x video:422064kB audio:28958kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknownAny ideas please?
Luke 42244 Posted June 23, 2017 Posted June 23, 2017 Well there is this open ticket in ffmpeg: https://trac.ffmpeg.org/ticket/6139 Looks like a workaround is removing the stream loop parameter but that will break things for those who need the stream looping.
CBers 7554 Posted June 23, 2017 Posted June 23, 2017 Well there is this open ticket in ffmpeg: https://trac.ffmpeg.org/ticket/6139 Looks like a workaround is removing the stream loop parameter but that will break things for those who need the stream looping. Ah, OK. I'm glad you understand it
Luke 42244 Posted June 23, 2017 Posted June 23, 2017 Ah, OK. I'm glad you understand it Some iptv providers provide a video url that is only like a 3 second video. You have to keep requesting it repeatedly to get more data. We accomplish that with the ffmpeg stream_loop param, which tells it to just keep looping forever, until user stops playback. Up until now it has been harmless to apply even when not needed, so now it looks like we're going to have to remove it and force the user to configure it when needed. 1
Spaceboy 2573 Posted June 24, 2017 Author Posted June 24, 2017 I had 2 consecutive 1 hour (plus padding of 2 before and 3 after) recordings set up, on different channels via IPTV, but the 2nd one ended after only 6 minutes. The 1st one recorded OK. I have the server and ffmpeg logs and will post once I have sanitised them. The reason for this post, is to ask @@Spaceboy if he's still seeing this issue, or if my error is local to me? hey! i've given up on using iptv as a recording source for now, it was far too unreliable. emby needs some functionality to allow it to deal better with momentary stream dropouts before it can be usable. presently i'm working on improving my MediaPortal integration in emby as its just rock solid as a recording server. also its the sport off season so less use for iptv anyway! but what you are reporting is in line with what i originally reported and still see. i set emby up with the same series recordings using my iptv service. i am still regularly seeing incomplete recordings, but as no-one seemed interested i wasnt pursuing it for now. the proposed changes sound interesting and when they are ready i can review and report any changes. 1
lifespeed 42 Posted July 3, 2017 Posted July 3, 2017 Well there is this open ticket in ffmpeg: https://trac.ffmpeg.org/ticket/6139 Looks like a workaround is removing the stream loop parameter but that will break things for those who need the stream looping. Is this failure of ffmpeg stream_loop parameter relevant to a problem with IPTV .M3U playlists stopping after a few seconds even though stream looping is enabled in the Live TV M3U tuner?
Luke 42244 Posted July 3, 2017 Posted July 3, 2017 If you have it enabled and they are still stopping then the best thing to do is please provide the information requested in how to report a problem. thanks !
Luke 42244 Posted February 15, 2019 Posted February 15, 2019 I had a single recording fail tonight with the following in the record-transcode log: frame=44186 fps= 25 q=-1.0 size= 450238kB time=00:29:27.38 bitrate=2086.9kbits/s speed=1.01x frame=44202 fps= 25 q=-1.0 size= 450374kB time=00:29:28.02 bitrate=2086.8kbits/s speed=1.01x frame=44224 fps= 25 q=-1.0 size= 450561kB time=00:29:28.90 bitrate=2086.6kbits/s speed= 1x Error while filtering: Operation not permitted frame=44224 fps= 25 q=-1.0 Lsize= 450606kB time=00:29:28.90 bitrate=2086.8kbits/s speed= 1x video:422064kB audio:28958kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknownAny ideas please? @@CBers do you still use this same live tv source?
CBers 7554 Posted February 15, 2019 Posted February 15, 2019 @@CBers do you still use this same live tv source? No, I now use a different IPTV provider. As an aside, I rarely use Live TV in Emby as the channel management is not there yet. I do have it set up via XTeVe though. 1
