Sludge Vohaul 23 Posted March 21, 2017 Posted March 21, 2017 Hi, custom titles for streams/tracks in MKV have been already discussed in https://emby.media/community/index.php?/topic/29047-is-there-a-way-to-display-track-name-if-available/page-1 and the feature is working fine for MKV. For MP4 containers custom stream titles are not supported, and the displayed title is the default composition of lang/codec/layout. This is probably due to the fact, that MP4 does not define a title-tag for streams (that's what they say on the internet...). Converting (*1) a MKV having a custom Title for an audio stream to MP4 results in file that somehow contains the title information, as VLC does show it (in "Description") and mediainfo as well (in "Title"). I wasn't able to find it with ffprobe though (but this doesn't say much as I am not good with all these things). Some people seem to be using (*2) the handler_name-tag of a stream for the title. This is obviously visible in ffprobe, but not in VLC (VLC is still showing the value of the original MKV's Title-tag). mediainfo displays both in "Title" (Title: <handler_name-tag value> / <MKV's Title-tag value>). Is it possible to make the MKV's Title-tag value visible with ffprobe in the MP4 container? *1: ffmpeg -i in.mkv -map 0:v -map 0:a -map_metadata 0 -sn -c:v libx264 -preset medium -tune film -profile:v high -level 4.0 -f mp4 out.m4v *2: ffmpeg -i in.mkv -map 0:v -map 0:a -map_metadata 0 -sn -c:v libx264 -preset medium -tune film -profile:v high -level 4.0 -metadata:s:a:2 handler="asd" -f mp4 out.m4v
Sludge Vohaul 23 Posted March 22, 2017 Author Posted March 22, 2017 $ ffprobe out.m4v ffprobe version git-2017-02-11-25d9cb4 Copyright © 2007-2017 the FFmpeg developers built with Apple LLVM version 8.0.0 (clang-800.0.38) configuration: --prefix=/usr/local/Cellar/ffmpeg/HEAD-25d9cb4 --enable-shared --enable-pthreads --enable-gpl --enable-version3 --enable-hardcoded-tables --enable-avresample --cc=clang --host-cflags= --host-ldflags= --disable-indev=qtkit --enable-libfdk-aac --enable-libmp3lame --enable-libx264 --enable-libxvid --enable-opencl --disable-lzma --enable-nonfree --enable-vda libavutil 55. 46.100 / 55. 46.100 libavcodec 57. 78.100 / 57. 78.100 libavformat 57. 66.102 / 57. 66.102 libavdevice 57. 2.100 / 57. 2.100 libavfilter 6. 73.100 / 6. 73.100 libavresample 3. 2. 0 / 3. 2. 0 libswscale 4. 3.101 / 4. 3.101 libswresample 2. 4.100 / 2. 4.100 libpostproc 54. 2.100 / 54. 2.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'out.m4v': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2avc1mp41 creation_time : 2017-03-19T21:49:32.000000Z encoder : Lavf57.66.102 Duration: 01:40:08.76, start: 0.000000, bitrate: 2 kb/s Chapter #0:0: start 0.000000, end 374.920000 Metadata: title : Chapter 01 Chapter #0:1: start 374.920000, end 732.160000 Metadata: title : Chapter 02 Chapter #0:2: start 732.160000, end 1004.120000 Metadata: title : Chapter 03 Chapter #0:3: start 1004.120000, end 1142.960000 Metadata: title : Chapter 04 Chapter #0:4: start 1142.960000, end 1436.760000 Metadata: title : Chapter 05 Chapter #0:5: start 1436.760000, end 1834.560000 Metadata: title : Chapter 06 Chapter #0:6: start 1834.560000, end 2176.720000 Metadata: title : Chapter 07 Chapter #0:7: start 2176.720000, end 2565.680000 Metadata: title : Chapter 08 Chapter #0:8: start 2565.680000, end 2965.560000 Metadata: title : Chapter 09 Chapter #0:9: start 2965.560000, end 3383.120000 Metadata: title : Chapter 10 Chapter #0:10: start 3383.120000, end 3723.200000 Metadata: title : Chapter 11 Chapter #0:11: start 3723.200000, end 4175.080000 Metadata: title : Chapter 12 Chapter #0:12: start 4175.080000, end 4488.120000 Metadata: title : Chapter 13 Chapter #0:13: start 4488.120000, end 4796.480000 Metadata: title : Chapter 14 Chapter #0:14: start 4796.480000, end 5236.920000 Metadata: title : Chapter 15 Chapter #0:15: start 5236.920000, end 6008.760000 Metadata: title : Chapter 16 Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x576 [sAR 64:45 DAR 16:9], 196 kb/s, 25 fps, 25 tbr, 12800 tbn, 50 tbc (default) Metadata: creation_time : 2017-03-19T21:49:32.000000Z handler_name : VideoHandler Stream #0:1(ger): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 342 kb/s (default) Metadata: creation_time : 2017-03-19T21:49:32.000000Z handler_name : SoundHandler Stream #0:2(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 5.1, fltp, 340 kb/s Metadata: creation_time : 2017-03-19T21:49:32.000000Z handler_name : SoundHandler Stream #0:3(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 132 kb/s Metadata: creation_time : 2017-03-19T21:49:32.000000Z handler_name : asd Stream #0:4(eng): Data: bin_data (text / 0x74786574) Metadata: creation_time : 2017-03-19T21:49:32.000000Z handler_name : SubtitleHandler Unsupported codec with id 100359 for input stream 4
Luke 42197 Posted March 22, 2017 Posted March 22, 2017 how about with the options -show_streams -show_format -print_format json
Sludge Vohaul 23 Posted March 22, 2017 Author Posted March 22, 2017 (edited) $ ffprobe -show_streams -select_streams a:2 -show_format -show_entries format_tags=: -hide_banner -print_format json out.m4v "streams": [ { "index": 3, "codec_name": "aac", "codec_long_name": "AAC (Advanced Audio Coding)", "profile": "LC", "codec_type": "audio", "codec_time_base": "1/48000", "codec_tag_string": "mp4a", "codec_tag": "0x6134706d", "sample_fmt": "fltp", "sample_rate": "48000", "channels": 2, "channel_layout": "stereo", "bits_per_sample": 0, "r_frame_rate": "0/0", "avg_frame_rate": "0/0", "time_base": "1/48000", "start_pts": 0, "start_time": "0.000000", "duration_ts": 586752, "duration": "12.224000", "bit_rate": "132333", "max_bit_rate": "132333", "nb_frames": "574", "disposition": { "default": 0, "dub": 0, "original": 0, "comment": 0, "lyrics": 0, "karaoke": 0, "forced": 0, "hearing_impaired": 0, "visual_impaired": 0, "clean_effects": 0, "attached_pic": 0, "timed_thumbnails": 0 }, "tags": { "creation_time": "2017-03-19T21:49:32.000000Z", "language": "eng", "handler_name": "asd" } } ], "format": { "filename": "out.m4v", "nb_streams": 5, "nb_programs": 0, "format_name": "mov,mp4,m4a,3gp,3g2,mj2", "format_long_name": "QuickTime / MOV", "start_time": "0.000000", "duration": "6008.760000", "size": "1566257", "bit_rate": "2085", "probe_score": 100 } $ mediainfo out.m4v ... Audio #3 ID : 4 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 12 s 246 ms Bit rate mode : Constant Bit rate : 132 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 spf) Compression mode : Lossy Stream size : 198 KiB (13%) Title : asd / Regiekommentar Language : English Default : No Alternate group : 1 Encoded date : UTC 2017-03-19 21:49:32 Tagged date : UTC 2017-03-19 21:49:32 Menus : 5 Edited March 22, 2017 by Sludge Vohaul
Sludge Vohaul 23 Posted March 22, 2017 Author Posted March 22, 2017 Yes, the MKVs Title-tag for the 3rd audio stream is "Regiekommentar". mediainfo displays it in the "Title" together with the handler_name tag set with ffmpeg's -metadata:s:a:2 handler="asd"
Sludge Vohaul 23 Posted March 22, 2017 Author Posted March 22, 2017 Just for completeness' sake here the metadata from the MKV stream. ffprobe -show_streams -select_streams a:2 -show_entries stream=tags -hide_banner -print_format json in.mkv "streams": [ { "disposition": { "default": 0, "dub": 0, "original": 0, "comment": 0, "lyrics": 0, "karaoke": 0, "forced": 0, "hearing_impaired": 0, "visual_impaired": 0, "clean_effects": 0, "attached_pic": 0, "timed_thumbnails": 0 }, "tags": { "language": "eng", "title": "Regiekommentar", "BPS": "192000", "BPS-eng": "192000", "DURATION": "01:40:08.736000000", "DURATION-eng": "01:40:08.736000000", "NUMBER_OF_FRAMES": "187773", "NUMBER_OF_FRAMES-eng": "187773", "NUMBER_OF_BYTES": "144209664", "NUMBER_OF_BYTES-eng": "144209664", "_STATISTICS_WRITING_APP": "mkvmerge v9.9.0 ('Pick Up') 64bit", "_STATISTICS_WRITING_APP-eng": "mkvmerge v9.9.0 ('Pick Up') 64bit", "_STATISTICS_WRITING_DATE_UTC": "2017-03-19 21:49:32", "_STATISTICS_WRITING_DATE_UTC-eng": "2017-03-19 21:49:32", "_STATISTICS_TAGS": "BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES", "_STATISTICS_TAGS-eng": "BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES" } } ]
Sludge Vohaul 23 Posted March 23, 2017 Author Posted March 23, 2017 Yes, the title-tag is displayed correctly for MKVs but MP4s show the default (lang/codec/layout), though the information is somewhere inside the file. I thought it should be easy to extract it with ffprobe, but maybe it is not. In case I find it out, I'll post it here... Thanks for your time anyway
Luke 42197 Posted March 24, 2017 Posted March 24, 2017 I thought we were looking at example ffprobe data from the mp4 in question?
Sludge Vohaul 23 Posted March 24, 2017 Author Posted March 24, 2017 Yes we were. In #5 is the ffprobe output from the MP4 and in #8 the output of the source MKV. The source MKV has in an audio stream the title-tag "Regiekommentar". I am not able to make this tag visible in the MP4 file with ffprobe, though it must be there as mediainfo does show it (see #5)
Luke 42197 Posted March 25, 2017 Posted March 25, 2017 Ok, I think this might be a question for ffprobe then. If we can get it into their output somehow, then certainly Emby can utilize it.
