dcook 303 Posted March 21, 2017 Posted March 21, 2017 Is it possible to have a Library with both Movies and TV inside? For example if I wanted to make a new Library called "Kids" that would contain all animated movies and tv shows? I know I can create the library with Unset content type, but as I have never used this content type before, will the movies and tv shows in the library get all the correct metadata?
Happy2Play 9802 Posted March 21, 2017 Posted March 21, 2017 As long as they get indentified correctly they will get the correct metadata, no different then by content type libraries.
