all4dom 101 Posted March 19, 2017 Posted March 19, 2017 Can I get everyone's input on which power supply to purchase. Not sure which one is better. (both are from newegg). Thanks RAIDMAX Scorpio series RX-535AP-S 535W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Power Supply CORSAIR CX-M Series CX550M 550W 80 PLUS BRONZE Haswell Ready ATX12V & EPS12V Modular Power Supply
Guest asrequested Posted March 19, 2017 Posted March 19, 2017 See that bronze rating? You want better. Spend just a little more. I have two of these, a 550 and an 850. An excellent power supply https://www.amazon.com/gp/product/B0106RDI3W/ref=oh_aui_detailpage_o09_s01?ie=UTF8&psc=1
all4dom 101 Posted March 20, 2017 Author Posted March 20, 2017 OK thanks dufus. I'll swap the one I was going to get for that one.
all4dom 101 Posted March 20, 2017 Author Posted March 20, 2017 Is the 550w modular & does it come with the cables. It does not mention that but it does say fully modular in the heading.
CBers 7554 Posted March 20, 2017 Posted March 20, 2017 Doubt it'll come with a power lead though. The one I bought last month didn't.
AdrianW 1058 Posted March 20, 2017 Posted March 20, 2017 Doubt it'll come with a power lead though. Power leads seem to come with everything (at least in Australia) I have way too many of the things.
CBers 7554 Posted March 20, 2017 Posted March 20, 2017 Power leads seem to come with everything (at least in Australia) I have way too many of the things.
Swynol 375 Posted March 20, 2017 Posted March 20, 2017 Can I get everyone's input on which power supply to purchase. Not sure which one is better. (both are from newegg). Thanks RAIDMAX Scorpio series RX-535AP-S 535W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Power Supply CORSAIR CX-M Series CX550M 550W 80 PLUS BRONZE Haswell Ready ATX12V & EPS12V Modular Power Supply what are you trying to power with it? 550w enough? i'm looking at buying a 850w+ one soon. looking at the EVGA range. I would always stick with a main brand and also be careful with the corsair PSUs, they have some budget ones which i wouldnt go near but their enthusiast ones are fine.
all4dom 101 Posted March 20, 2017 Author Posted March 20, 2017 Just an intel I5 (3.4), 6 hard drives, no video cards and a blueray drive. It will be use as a home server. I also want to keep it efficient as possible.
Guest asrequested Posted March 20, 2017 Posted March 20, 2017 It comes with more cables than you'll need, power cable included.
