No Hardware Accleration 7th Gen I3-7100
JeremyFr79
@@Luke,@@babgvant any chance you can release control of the LAV settings, in an advanced mode? For people like us, it would be very useful.
This^^^^^ Being as such I can't seem to "hack" my way into the settings of the "built in" LAV as of yet.
Guest asrequested
Yeah, this has been an issue from the beginning. Multiple requests were made to allow us control, but it never happened. I think Luke wanted to have a standardized 'play all' solution. It hasn't worked out quite that well. There seem to be continual playback issues. I liked the old way, where we could select any option, and use any filters we wanted.
JeremyFr79
All I need is the option to run LAV in ET with DXVA native and I should be good.  That's what yields the best results outside of ET on the same machine.
Guest asrequested
Maybe Babgvant can add that as an option, if they won't release control to us.
daedalus
you cant select native through the configuration
but you can trick it by setting
<HwaMode>4</HwaMode>
in your directshowplayer.xml
but just to notice this will get overwritten as soon as you change something in the video section in the configuration and you have to set it manually again
Guest asrequested
Ah! There we go. Yeah, it all gets reset by theater when you use the general settings.
Guest asrequested
The changes I've made are global, and I set and forget.
JeremyFr79
Could you flag the file "read only" to fix this?
JeremyFr79
Seriously I think you are a life saver, I'll know for sure tonight, but looking at it via RDP, that looks like it took care of it for me!
Guest asrequested
This really should be one of the available settings in the theater UI
And the convert to AC3 :D (just thought I'd throw that out, again)
Edited by Doofus
JeremyFr79
Disregard, I get playback with 4 set, but CPU spikes to 100%, seems there's something else I need to change.  Mind you this is HEVC content I'm trying to play which my Processor will decode via DXVA.
Guest asrequested
I think the best configuration with the settings we have available, is going to be with madVR. Especially for you, as you want refresh rate switching. MadVR has dxva settings and a lot more.
Edited by Doofus
JeremyFr79
MADvr is giving me the most issue, External to ET, if I use LAV .69 have it set for DXVA Native, enable all the codecs for hardware decoding everything works plain and simple, MadVR doesn't seem to like the GPU on the KabyLake at all yet, no surprise it's so new and it features a whole new hardware decode block.  Obviously LAV doesn't support it either at least through native QS, but it at least does through DXVANative for now which I can live with as the end result is my files play.
JeremyFr79
p.s. I don't need any of the "extras" madvr gives you, I just want solid file playback.
Guest asrequested
This is all making me want my new i7 more and more. I'll be getting the 7700k, so I may not have as much of an issue. But I'm going to put it through its paces.
Edited by Doofus
JeremyFr79
no difference in the decoder block between the i3,i5, and i7's
Guest asrequested
As strange as this sounds, I hope I get the same problems lol... I want to experiment :D
Sadly, I don't have a 4k TV, but hopefully I can still recreate the problem
JeremyFr79
Ok, I think I just figured out the issue.  The movies that work are all 2.40:1 aspect, all the movies that don't play in ET are 16:9 or 1.85:1 So any ideas on why the aspect ratio would cause one movie to play fine, and another to not??
JeremyFr79
So it looks like no matter what I set in ET it's just not using hardware decoding (even though I can get LAV to hardware decode just fine external to ET)  My assumption here is that the files that are not "full screen" aspect ration are of course less complex and the CPU can decode/play them back just fine.  I just wish I could figure this out, I really don't want to have to use an external player for ET.
Guest asrequested
Are you seeing anything in the directshowplayer, that could be responsible? So all your 1080 HEVC files play OK?
JeremyFr79
I don't understand the file enough to know what I need to look for, I added HEVC and VP9 to the HwaEnabledCodecs area but that doesn't seemed to have helped either.  1080p plays fine but I assume it to is only using CPU, but the CPU can decode it just fine, unlike a full 3840x2160p file.
JeremyFr79
Yeah with 1080p, I still see 50% cpu utilization, where externally it's always less than 10%  So it looks like ET is not hardware decoding ANY HEVC
Guest asrequested
Right, that's why I was thinking that the 7700k will have less of a problem. As for the directshowplayer, I've messed with adding types, too. To no avail. Probably because LAV doesn't directly support them or some such thing. Calling the lord @@babgvant
JeremyFr79
Yeah so through my fooling around remoted into my system from work, I've found that nothing is hardware decoding through ET on my KabyLake, outside of ET, I get best results for HEVC and h.264, using DXVAnative in LAV .69, when I switch to QS in LAV it grays out HEVC, & VP9, which seems to be a pretty clear indicator that LAV does not support the newest QS capabilities of KabyLake as of yet.  Though it does through DXVAnative.  Still doesn't help me fix the issue with ET, but at least I know without a doubt the problem IS with ET and not any of my stuff.
Guest asrequested
I wonder how much of that is related to the Intel driver?
