JeremyFr79 228 Posted March 20, 2017 Author Posted March 20, 2017 UGH, so hit and miss with codecs/files/players lol getting a bit frustrating but I know it's mainly due to everyone trying to catch up with 4K and HEVC, just going to have to be patient. On a side note I did get to watch Billy Lynss Long Half Time Walk this weekend in 4K/HFR, movie was so so at best, but it was interesting to see a movie in full 60fps, it was weird, like "hyper real" kind of weird to watch. I think I prefer 24fps to 60fps, but time will tell.
JeremyFr79 228 Posted March 20, 2017 Author Posted March 20, 2017 Ha! Was is super smooth? Too perfect? Yeah super smooth, little to 0 motion blur, the detail was crazy. It was actually distracting though you got more used to it as the movie went on though never completely used to it. It's really hard to explain, but it was like a SOE you couldn't turn off. Don't get me wrong it was great seeing what my TV could REALLY do, but yeah for now I think I prefer my movies in 24fps, I could see 60fps being awesome for things like RedBull films and stuff like that though.
Guest asrequested Posted March 20, 2017 Posted March 20, 2017 I'm planning to buy a new TV this year. I've been waiting until there was more content and more support with more options. I think the time is about right. That's why I'm buying the gen 7. Preparing for things to come.
JeremyFr79 228 Posted March 20, 2017 Author Posted March 20, 2017 I've got a pair of Vizio M-Series (80" and 65") and love em, nice thing is they support all the HDR standards that will stick around, and the picture quality is top notch on them. Not to mention having the built in 4K Chromecast is nice to (thought Emby wont cast 4K to them)
Guest asrequested Posted March 20, 2017 Posted March 20, 2017 I don't know what I'll get, yet. Probably a Samsung.
JeremyFr79 228 Posted March 20, 2017 Author Posted March 20, 2017 I saw nothing in the Samsung side by side with the M or P series that made them worth more than the Vizios. Not to mention that with recent event's with their product quality have more and more made me lean away from them. Exploding cellphones and washers show's an inherent lack of quality control or care for consumer safety.
Guest asrequested Posted March 20, 2017 Posted March 20, 2017 That's a valid point. By the time I decide to buy one, there'll probably be new developments. How does the IR sensor work on yours? The last time I installed a vizio, the IR sensor really sucked.
JeremyFr79 228 Posted March 20, 2017 Author Posted March 20, 2017 That's a valid point. By the time I decide to buy one, there'll probably be new developments. How does the IR sensor work on yours? The last time I installed a vizio, the IR sensor really sucked. Both work fine, I have a Harmony hub running one, so it's actually sitting in a cabinet 4 feet below and to the right of the TV facing out into the room, the other I'm using a Harmony Ultimate from 14 feet away with 0 issues as well. The thing with both M & P series they actually come with Android tablets as remotes, so you can control via IR or Android App that you can install on any android device.
Guest asrequested Posted March 20, 2017 Posted March 20, 2017 That's good to know. I'll keep it mind when I start looking. I don't need any real functionality, just on and off. I've got a hub, too.
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 Ok, so things are seeming very weird to me, I have some 4K files that play without issue in ET, yet others that won't at all, They ALL will play outside of ET just fine. Looking at media info they seem to be same codec, level etc not sure what I could be missing, I'm posting media info below see if any of you can spot something I'm not seeing or not privy to that may be causing the issue. File that won't play..... General Unique ID : 218048835959931649836626088966274064414 (0xA40AADA1E242E90CA7FCAED161BEA01E) Complete name : \\RJSERVER\Emby\Movies\Miss Peregrines Home for Peculiar Children\Miss Peregrines Home For Peculiar Children - 2160p.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 14.6 GiB Duration : 2 h 6 min Overall bit rate : 16.4 Mb/s Movie name : Miss Peregrine's Home for Peculiar Children (2016) Encoded date : UTC 2017-03-20 21:13:20 Writing application : mkvmerge v9.7.1 ('Pandemonium') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 6 min Bit rate : 11.9 Mb/s Width : 3 840 pixels Height : 2 064 pixels Display aspect ratio : 1.85:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.063 Stream size : 10.5 GiB (72%) Writing library : x265 2.3+18-88fd9082764c:[Windows][GCC 7.0.1][64 bit] 10bit Encoding settings : cpuid=1049087 / frame-threads=3 / numa-pools=10 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2064 / interlace=0 / total-frames=182593 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=11892 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / refine-level=5 Default : Yes Forced : No Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / ES Matrix / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 6 min Bit rate mode : Variable / Constant / Constant Bit rate : 4 528 kb/s / 1 509 kb/s / 1 509 kb/s Channel(s) : 8 channels / 7 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy / Lossy Stream size : 4.01 GiB (28%) Title : English DTS-HD Language : English Default : Yes Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:03:40.804 : en:00:03:40.804 00:08:38.017 : en:00:08:38.017 00:13:06.828 : en:00:13:06.828 00:15:26.551 : en:00:15:26.551 00:19:47.478 : en:00:19:47.478 00:23:23.652 : en:00:23:23.652 00:27:47.040 : en:00:27:47.040 00:31:06.448 : en:00:31:06.448 00:34:36.783 : en:00:34:36.783 00:39:34.998 : en:00:39:34.998 00:42:42.810 : en:00:42:42.810 00:46:05.638 : en:00:46:05.638 00:48:36.497 : en:00:48:36.497 00:54:16.462 : en:00:54:16.462 00:57:21.480 : en:00:57:21.480 01:02:03.261 : en:01:02:03.261 01:08:20.847 : en:01:08:20.847 01:14:29.006 : en:01:14:29.006 01:18:54.063 : en:01:18:54.063 01:24:15.300 : en:01:24:15.300 01:28:42.442 : en:01:28:42.442 01:33:11.753 : en:01:33:11.753 01:36:29.033 : en:01:36:29.033 01:40:43.788 : en:01:40:43.788 01:46:09.238 : en:01:46:09.238 01:53:35.308 : en:01:53:35.308 02:00:34.394 : en:02:00:34.394 File that will play.... General Unique ID : 174166011276538110610986491150609392246 (0x83072755078C51E0AAFF070F4D2BA276) Complete name : \\RJSERVER\Emby\Movies\Sicario\Sicario - 2160p.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 13.1 GiB Duration : 2 h 1 min Overall bit rate : 15.4 Mb/s Movie name : Sicario (2015) Encoded date : UTC 2017-03-19 21:11:35 Writing application : mkvmerge v9.7.1 ('Pandemonium') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Cover : Yes Attachments : cover.jpg / xlog.txt Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 1 min Bit rate : 12.0 Mb/s Width : 3 840 pixels Height : 1 600 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.081 Stream size : 10.1 GiB (77%) Writing library : x265 2.3+17-6e348252e902:[Windows][GCC 7.0.1][64 bit] 10bit Encoding settings : cpuid=1049087 / frame-threads=3 / numa-pools=10 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1600 / interlace=0 / total-frames=174553 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=11962 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-optrefine-level=5 Default : Yes Forced : No Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 1 min Bit rate mode : Variable / Constant Bit rate : 3 471 kb/s / 1 509 kb/s Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 2.94 GiB (22%) Title : Sicario.2015.1080p.BluRay.DTS-HD.MA.7.1.x264.SiMPLE-NoHaTE Language : English Default : Yes Forced : No Menu 00:00:00.000 : en:Chapter 1 00:07:14.350 : en:Chapter 2 00:12:55.107 : en:Chapter 3 00:20:04.369 : en:Chapter 4 00:25:24.814 : en:Chapter 5 00:32:11.596 : en:Chapter 6 00:39:24.820 : en:Chapter 7 00:46:15.314 : en:Chapter 8 00:53:24.576 : en:Chapter 9 01:01:40.321 : en:Chapter 10 01:10:49.119 : en:Chapter 11 01:18:02.886 : en:Chapter 12 01:30:59.370 : en:Chapter 13 01:36:57.770 : en:Chapter 14 01:47:42.038 : en:Chapter 15 01:54:12.804 : en:Chapter 16
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 Here's another pair top file will play in ET, bottom file will not. General Unique ID : 235160688597244188232316085643878031399 (0xB0EA4D1ADE143CEBB3FDD65996136027) Complete name : \\RJSERVER\Emby\Movies\The Revenant\The Revenant - 2160p.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 10.5 GiB Duration : 2 h 36 min Overall bit rate : 9 607 kb/s Encoded date : UTC 2017-03-20 21:01:15 Writing application : mkvmerge v9.7.1 ('Pandemonium') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 36 min Bit rate : 5 001 kb/s Width : 3 840 pixels Height : 1 606 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.034 Stream size : 5.46 GiB (52%) Writing library : x265 2.2+7-5e7abd981a2f:[Mac OS X][clang 8.0.0][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1606 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=5000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 36 min Bit rate mode : Variable / Constant Bit rate : 4 603 kb/s / 1 509 kb/s Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 5.03 GiB (48%) Title : English DTS-HD MA 7.1 4603 kbps Language : English Default : Yes Forced : No Menu 00:00:00.000 : :00:00:00.000 00:05:05.013 : :00:05:04.846 00:07:58.311 : :00:07:58.311 00:13:18.965 : :00:13:18.965 00:21:10.686 : :00:21:10.686 00:28:21.700 : :00:28:21.658 00:37:07.934 : :00:37:07.767 00:44:00.346 : :00:44:00.346 00:48:14.975 : :00:48:14.975 00:51:42.266 : :00:51:42.266 00:56:51.199 : :00:56:51.033 00:59:50.754 : :00:59:50.754 01:03:31.766 : :01:03:31.766 01:11:52.517 : :01:11:52.433 01:16:36.133 : :01:16:36.133 01:21:22.378 : :01:21:22.377 01:28:31.223 : :01:28:31.139 01:37:30.261 : :01:37:29.969 01:48:44.643 : :01:48:44.643 01:53:08.782 : :01:53:08.782 01:59:05.972 : :01:59:05.930 02:02:56.703 : :02:02:56.703 02:15:45.471 : :02:15:45.262 02:22:51.021 : :02:22:51.021 Won't play... General Unique ID : 235160688597244188232316085643878031399 (0xB0EA4D1ADE143CEBB3FDD65996136027) Complete name : \\RJSERVER\Emby\Movies\The Revenant\The Revenant - 2160p.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 10.5 GiB Duration : 2 h 36 min Overall bit rate : 9 607 kb/s Encoded date : UTC 2017-03-20 21:01:15 Writing application : mkvmerge v9.7.1 ('Pandemonium') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 36 min Bit rate : 5 001 kb/s Width : 3 840 pixels Height : 1 606 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.034 Stream size : 5.46 GiB (52%) Writing library : x265 2.2+7-5e7abd981a2f:[Mac OS X][clang 8.0.0][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1606 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=8 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=5000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 36 min Bit rate mode : Variable / Constant Bit rate : 4 603 kb/s / 1 509 kb/s Channel(s) : 8 channels / 6 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossless / Lossy Stream size : 5.03 GiB (48%) Title : English DTS-HD MA 7.1 4603 kbps Language : English Default : Yes Forced : No Menu 00:00:00.000 : :00:00:00.000 00:05:05.013 : :00:05:04.846 00:07:58.311 : :00:07:58.311 00:13:18.965 : :00:13:18.965 00:21:10.686 : :00:21:10.686 00:28:21.700 : :00:28:21.658 00:37:07.934 : :00:37:07.767 00:44:00.346 : :00:44:00.346 00:48:14.975 : :00:48:14.975 00:51:42.266 : :00:51:42.266 00:56:51.199 : :00:56:51.033 00:59:50.754 : :00:59:50.754 01:03:31.766 : :01:03:31.766 01:11:52.517 : :01:11:52.433 01:16:36.133 : :01:16:36.133 01:21:22.378 : :01:21:22.377 01:28:31.223 : :01:28:31.139 01:37:30.261 : :01:37:29.969 01:48:44.643 : :01:48:44.643 01:53:08.782 : :01:53:08.782 01:59:05.972 : :01:59:05.930 02:02:56.703 : :02:02:56.703 02:15:45.471 : :02:15:45.262 02:22:51.021 : :02:22:51.021
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 When you say won't play....nothing happens, the file stops playing after a few seconds, crashes app...??
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 refresh rate switches over, seek bar comes up stays at 0:00 and sometimes if I try to back out it'll crash ET, other times it'll back out back to the menu. I've also had it play audio with a black screen/seek bar etc. There seems to be no rhyme or reason to this and I don't know enough about encoding to even know where to start looking. Yet all of them play just fine in Windows Media Player with LAV 0.69 running DXVANative, (LAV's quicksync support doesn't seem to like the 7th gen procs yet)
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 (edited) It may be to do with refresh rate switching. Others have reported similar issues. I imagine you have set it in MadVR? Edited March 21, 2017 by Doofus
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 ET is set to Auto/Auto so I'm not sure if it's using EVR or MAD
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 I suppose I could try running ET at 23p and see if that changes anything....
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 (edited) Disable switching and let the gpu up it 59Hz. That's how I have mine. My GPU is set to 59Hz Edited March 21, 2017 by Doofus
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 Disable switching and let the gpu up it 59Hz. That's how I have mine. My GPU is set to 59Hz I prefer the post processing in my television to that of the computer and prefer to feed it the purest signal possible. But to the issue, I've adjusted the default refresh to 23p for the video card and disable auto refresh changing. With that disabled I get a green screen with audio playing if set to auto/auto. If I set Intel QS and EVR I get playback but it's obviously not hardware decoding and so i get tons of skipped frames/lag and cpu pegged at 100% If I set DXVA CopyBack with EVR I get the same exact results, tons of dropped frames/lag cpu pegged. Setting Intel Qucksync with MadVR again the same results as the first 2 And lastly DXVA Copyback with MadVR causes ET to crash.
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 (edited) Well, with madVR you'll probably need to change the configuration. Have you tried adding the different refresh rates and let madVR do the switching? Edited March 21, 2017 by Doofus
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 as part of my troubleshoot I completely disabled those 2 settings and just ran video output at 23p and still same issues.
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 I'm looking forward to playing around with mine, when I get it.
JeremyFr79 228 Posted March 21, 2017 Author Posted March 21, 2017 Now knowing that a custom version of LAV is being used in ET, I'm going to see if I can configure the custom version with the settings I know work with my card and make ET work correctly tonight.
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 LAV itself isn't custom, you can overwrite it with the a downloaded version. But you can alter the directshowplayer.xml.
Guest asrequested Posted March 21, 2017 Posted March 21, 2017 @@Luke,@@babgvant any chance you can release control of the LAV settings, in an advanced mode? For people like us, it would be very useful. 1
