utah-dave 5 Posted March 17, 2017 Posted March 17, 2017 I have an odd one ( I think) I copy my movies the same each time and each folder has the same permissions as all the others. yet, only a few will stream and others will not. And the ones that will stream will only play 1/2 the movie before stopping.. I have a windows 2016 server, quad core, 16gb ram in a VM... here is the log I am getting http://media.theutahitgroup.com:8096/emby/videos/56619670814c6813543a002b12d7bba2/hls1/main/0.ts?DeviceId=684fab028e0ef5fcae4d8e6f0f2b201dbb3194c7&MediaSourceId=56619670814c6813543a002b12d7bba2&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=2&VideoBitrate=2155682&AudioBitrate=384000&Level=51&Profile=high&PlaySessionId=dc4afd0c7ca6458188062b413c037f00&api_key=fb9f4ec6b8c240e18c64948330353a34&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=79b360cf2d3dcd2da9d3dbb42c3d3b89&RequireAvc=true {"Protocol":"File","Id":"56619670814c6813543a002b12d7bba2","Path":"\\\\media\\movies\\Halloween\\Dr. Horrible's Sing-Along Blog (2008)","Type":"Default","Name":"DVD/480P/MPEG2VIDEO/AC3","IsRemote":false,"ETag":"79b360cf2d3dcd2da9d3dbb42c3d3b89","RunTimeTicks":25410660352,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"Dvd","MediaStreams":[{"Codec":"mpeg2video","TimeBase":"1/90000","CodecTimeBase":"1001/60000","IsInterlaced":false,"BitRate":4640390,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":480,"Width":720,"AverageFrameRate":30,"RealFrameRate":59.94006,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":448000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"DVDSUB","TimeBase":"1/90000","CodecTimeBase":"0/1","DisplayTitle":"Und","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":6,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":["VTS_01_1.VOB","VTS_01_2.VOB"],"Formats":[],"Bitrate":5664390,"RequiredHttpHeaders":{}} C:\Users\daveorn\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -probesize 1G -analyzeduration 200M -i concat:"\\media\movies\Halloween\Dr. Horrible's Sing-Along Blog (2008)\VIDEO_TS\VTS_01_1.VOB|\\media\movies\Halloween\Dr. Horrible's Sing-Along Blog (2008)\VIDEO_TS\VTS_01_2.VOB" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:1 -map 0:2 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 2155682 -bufsize 4311364 -vsync -1 -profile:v high -level 4.1 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -af "adelay=1,aresample=async=1" -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\daveorn\AppData\Roaming\Emby-Server\transcoding-temp\a22e6ea09c47be9773a7f198afaa97d0.m3u8" -y "C:\Users\daveorn\AppData\Roaming\Emby-Server\transcoding-temp\a22e6ea09c47be9773a7f198afaa97d0%d.ts" ffmpeg version N-79277-g0c90b2e Copyright © 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100Input #0, mpeg, from 'concat:\\media\movies\Halloween\Dr. Horrible's Sing-Along Blog (2008)\VIDEO_TS\VTS_01_1.VOB|\\media\movies\Halloween\Dr. Horrible's Sing-Along Blog (2008)\VIDEO_TS\VTS_01_2.VOB': Duration: 00:42:20.22, start: 0.300300, bitrate: 4640 kb/s Stream #0:0[0x1bf]: Data: dvd_nav_packet Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, smpte170m), 720x480 [sAR 32:27 DAR 16:9], Closed Captions, max. 6000 kb/s, 30 fps, 59.94 tbr, 90k tbn, 59.94 tbc Stream #0:2[0x81]: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s Stream #0:3[0x80]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Stream #0:4[0x82]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Stream #0:5[0x83]: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Stream #0:6[0x20]: Subtitle: dvd_subtitle[libx264 @ 0000000009333a20] using SAR=1912/1917[libx264 @ 0000000009333a20] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX[libx264 @ 0000000009333a20] profile Main, level 4.1[libx264 @ 0000000009333a20] 264 - core 148 r2665 a01e339 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=2155 vbv_bufsize=4311 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00Output #0, segment, to 'C:\Users\daveorn\AppData\Roaming\Emby-Server\transcoding-temp\a22e6ea09c47be9773a7f198afaa97d0%d.ts': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (libx264), yuv420p, 852x478 [sAR 1912:1917 DAR 16:9], q=-1--1, max. 2155 kb/s, 29.97 fps, 90k tbn, 29.97 tbc Metadata: encoder : Lavc57.34.100 libx264 Side data: cpb: bitrate max/min/avg: 2155000/0/0 buffer size: 4311000 vbv_delay: -1 Stream #0:1: Audio: aac (LC), 48000 Hz, 5.1, fltp, 384 kb/s Metadata: encoder : Lavc57.34.100 aacStream mapping: Stream #0:1 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:2 -> #0:1 (ac3 (native) -> aac (native))Press [q] to stop, [?] for helpframe= 42 fps=0.0 q=29.0 size=N/A time=00:00:01.06 bitrate=N/A dup=8 drop=0 speed=2.13x frame= 87 fps= 87 q=29.0 size=N/A time=00:00:02.47 bitrate=N/A dup=17 drop=0 speed=2.47x frame= 161 fps=107 q=29.0 size=N/A time=00:00:04.94 bitrate=N/A dup=32 drop=0 speed= 3.3x frame= 207 fps=103 q=29.0 size=N/A time=00:00:06.42 bitrate=N/A dup=41 drop=0 speed=3.19x frame= 252 fps=100 q=29.0 size=N/A time=00:00:07.85 bitrate=N/A dup=50 drop=0 speed=3.12x frame= 288 fps= 96 q=29.0 size=N/A time=00:00:09.32 bitrate=N/A dup=57 drop=0 speed=3.09x frame= 333 fps= 95 q=29.0 size=N/A time=00:00:10.83 bitrate=N/A dup=66 drop=0 speed=3.08x frame= 372 fps= 92 q=29.0 size=N/A time=00:00:12.11 bitrate=N/A dup=74 drop=0 speed=3.01x frame= 417 fps= 92 q=29.0 size=N/A time=00:00:13.41 bitrate=N/A dup=83 drop=0 speed=2.96x frame= 449 fps= 89 q=29.0 size=N/A time=00:00:14.80 bitrate=N/A dup=89 drop=0 speed=2.94x frame= 478 fps= 86 q=29.0 size=N/A time=00:00:15.78 bitrate=N/A dup=95 drop=0 speed=2.85x frame= 509 fps= 84 q=29.0 size=N/A time=00:00:16.81 bitrate=N/A dup=101 drop=0 speed=2.79x frame= 544 fps= 83 q=29.0 size=N/A time=00:00:17.87 bitrate=N/A dup=108 drop=0 speed=2.73x frame= 582 fps= 83 q=29.0 size=N/A time=00:00:18.98 bitrate=N/A dup=116 drop=0 speed=2.69x frame= 621 fps= 82 q=29.0 size=N/A time=00:00:20.37 bitrate=N/A dup=124 drop=0 speed= 2.7x frame= 671 fps= 83 q=29.0 size=N/A time=00:00:21.90 bitrate=N/A dup=134 drop=0 speed=2.72x frame= 717 fps= 84 q=29.0 size=N/A time=00:00:23.40 bitrate=N/A dup=143 drop=0 speed=2.73x frame= 747 fps= 82 q=29.0 size=N/A time=00:00:24.72 bitrate=N/A dup=149 drop=0 speed=2.73x frame= 807 fps= 84 q=29.0 size=N/A time=00:00:26.66 bitrate=N/A dup=161 drop=0 speed=2.79x frame= 841 fps= 84 q=29.0 size=N/A time=00:00:27.81 bitrate=N/A dup=168 drop=0 speed=2.76x frame= 882 fps= 84 q=29.0 size=N/A time=00:00:29.03 bitrate=N/A dup=176 drop=0 speed=2.75x frame= 912 fps= 82 q=29.0 size=N/A time=00:00:30.05 bitrate=N/A dup=182 drop=0 speed=2.72x frame= 952 fps= 82 q=29.0 size=N/A time=00:00:31.40 bitrate=N/A dup=190 drop=0 speed=2.72x frame= 987 fps= 82 q=29.0 size=N/A time=00:00:32.46 bitrate=N/A dup=197 drop=0 speed=2.69x frame= 1017 fps= 81 q=29.0 size=N/A time=00:00:33.62 bitrate=N/A dup=203 drop=0 speed=2.68x frame= 1057 fps= 81 q=29.0 size=N/A time=00:00:34.85 bitrate=N/A dup=211 drop=0 speed=2.67x frame= 1092 fps= 81 q=29.0 size=N/A time=00:00:36.24 bitrate=N/A dup=218 drop=0 speed=2.67x frame= 1122 fps= 80 q=29.0 size=N/A time=00:00:37.03 bitrate=N/A dup=224 drop=0 speed=2.63x frame= 1152 fps= 79 q=29.0 size=N/A time=00:00:37.99 bitrate=N/A dup=230 drop=0 speed=2.61x frame= 1191 fps= 79 q=29.0 size=N/A time=00:00:39.38 bitrate=N/A dup=238 drop=0 speed=2.61x frame= 1242 fps= 80 q=29.0 size=N/A time=00:00:40.93 bitrate=N/A dup=248 drop=0 speed=2.63x frame= 1282 fps= 80 q=29.0 size=N/A time=00:00:42.34 bitrate=N/A dup=256 drop=0 speed=2.63x frame= 1332 fps= 80 q=29.0 size=N/A time=00:00:44.13 bitrate=N/A dup=266 drop=0 speed=2.66x frame= 1377 fps= 81 q=29.0 size=N/A time=00:00:45.78 bitrate=N/A dup=275 drop=0 speed=2.68x frame= 1422 fps= 81 q=29.0 size=N/A time=00:00:47.08 bitrate=N/A dup=284 drop=0 speed=2.68x frame= 1462 fps= 81 q=29.0 size=N/A time=00:00:48.40 bitrate=N/A dup=292 drop=0 speed=2.68x frame= 1512 fps= 81 q=29.0 size=N/A time=00:00:49.96 bitrate=N/A dup=302 drop=0 speed=2.69x frame= 1539 fps= 81 q=29.0 size=N/A time=00:00:50.90 bitrate=N/A dup=307 drop=0 speed=2.67x frame= 1572 fps= 80 q=29.0 size=N/A time=00:00:52.07 bitrate=N/A dup=314 drop=0 speed=2.66x frame= 1609 fps= 80 q=29.0 size=N/A time=00:00:53.39 bitrate=N/A dup=321 drop=0 speed=2.66x frame= 1644 fps= 80 q=29.0 size=N/A time=00:00:54.44 bitrate=N/A dup=328 drop=0 speed=2.64x frame= 1679 fps= 79 q=29.0 size=N/A time=00:00:55.89 bitrate=N/A dup=335 drop=0 speed=2.65x frame= 1717 fps= 79 q=29.0 size=N/A time=00:00:56.91 bitrate=N/A dup=343 drop=0 speed=2.63x frame= 1751 fps= 79 q=29.0 size=N/A time=00:00:57.94 bitrate=N/A dup=350 drop=0 speed=2.62x frame= 1782 fps= 79 q=29.0 size=N/A time=00:00:59.02 bitrate=N/A dup=356 drop=0 speed=2.61x frame= 1819 fps= 79 q=29.0 size=N/A time=00:01:00.39 bitrate=N/A dup=363 drop=0 speed=2.61x frame= 1872 fps= 79 q=29.0 size=N/A time=00:01:02.05 bitrate=N/A dup=374 drop=0 speed=2.63x frame= 1908 fps= 79 q=29.0 size=N/A time=00:01:03.38 bitrate=N/A dup=381 drop=0 speed=2.63x frame= 1947 fps= 79 q=29.0 size=N/A time=00:01:04.72 bitrate=N/A dup=389 drop=0 speed=2.63x frame= 1991 fps= 79 q=29.0 size=N/A time=00:01:05.96 bitrate=N/A dup=398 drop=0 speed=2.62x frame= 2027 fps= 79 q=29.0 size=N/A time=00:01:07.41 bitrate=N/A dup=405 drop=0 speed=2.63x frame= 2081 fps= 80 q=29.0 size=N/A time=00:01:08.94 bitrate=N/A dup=416 drop=0 speed=2.64x frame= 2127 fps= 80 q=29.0 size=N/A time=00:01:10.48 bitrate=N/A dup=425 drop=0 speed=2.65x frame= 2172 fps= 80 q=29.0 size=N/A time=00:01:12.17 bitrate=N/A dup=434 drop=0 speed=2.66x frame= 2214 fps= 80 q=29.0 size=N/A time=00:01:13.45 bitrate=N/A dup=442 drop=0 speed=2.66x frame= 2247 fps= 80 q=29.0 size=N/A time=00:01:14.77 bitrate=N/A dup=449 drop=0 speed=2.66x frame= 2283 fps= 80 q=29.0 size=N/A time=00:01:15.92 bitrate=N/A dup=456 drop=0 speed=2.65x frame= 2322 fps= 80 q=29.0 size=N/A time=00:01:17.09 bitrate=N/A dup=464 drop=0 speed=2.64x frame= 2353 fps= 79 q=29.0 size=N/A time=00:01:18.31 bitrate=N/A dup=470 drop=0 speed=2.64x frame= 2397 fps= 79 q=29.0 size=N/A time=00:01:19.70 bitrate=N/A dup=479 drop=0 speed=2.64x frame= 2442 fps= 80 q=29.0 size=N/A time=00:01:21.06 bitrate=N/A dup=488 drop=0 speed=2.64x frame= 2472 fps= 79 q=29.0 size=N/A time=00:01:22.21 bitrate=N/A dup=494 drop=0 speed=2.64x frame= 2517 fps= 79 q=29.0 size=N/A time=00:01:23.73 bitrate=N/A dup=503 drop=0 speed=2.64x frame= 2548 fps= 79 q=29.0 size=N/A time=00:01:24.77 bitrate=N/A dup=509 drop=0 speed=2.63x frame= 2592 fps= 79 q=29.0 size=N/A time=00:01:26.16 bitrate=N/A dup=518 drop=0 speed=2.64x frame= 2626 fps= 79 q=29.0 size=N/A time=00:01:27.40 bitrate=N/A dup=525 drop=0 speed=2.63x frame= 2667 fps= 79 q=29.0 size=N/A time=00:01:28.46 bitrate=N/A dup=533 drop=0 speed=2.62x frame= 2697 fps= 79 q=29.0 size=N/A time=00:01:29.57 bitrate=N/A dup=539 drop=0 speed=2.62x frame= 2727 fps= 79 q=29.0 size=N/A time=00:01:30.66 bitrate=N/A dup=545 drop=0 speed=2.61x frame= 2776 fps= 79 q=29.0 size=N/A time=00:01:32.43 bitrate=N/A dup=555 drop=0 speed=2.63x frame= 2816 fps= 79 q=29.0 size=N/A time=00:01:33.54 bitrate=N/A dup=563 drop=0 speed=2.62x frame= 2862 fps= 79 q=29.0 size=N/A time=00:01:35.08 bitrate=N/A dup=572 drop=0 speed=2.63x frame= 2906 fps= 79 q=29.0 size=N/A time=00:01:36.55 bitrate=N/A dup=581 drop=0 speed=2.63x frame= 2968 fps= 80 q=29.0 size=N/A time=00:01:38.90 bitrate=N/A dup=593 drop=0 speed=2.66x frame= 3027 fps= 80 q=29.0 size=N/A time=00:01:40.58 bitrate=N/A dup=605 drop=0 speed=2.67x frame= 3059 fps= 80 q=29.0 size=N/A time=00:01:41.93 bitrate=N/A dup=611 drop=0 speed=2.67x frame= 3091 fps= 80 q=29.0 size=N/A time=00:01:42.93 bitrate=N/A dup=618 drop=0 speed=2.66x frame= 3121 fps= 80 q=29.0 size=N/A time=00:01:43.97 bitrate=N/A dup=624 drop=0 speed=2.65x frame= 3162 fps= 80 q=29.0 size=N/A time=00:01:45.13 bitrate=N/A dup=632 drop=0 speed=2.65x frame= 3193 fps= 79 q=29.0 size=N/A time=00:01:46.38 bitrate=N/A dup=638 drop=0 speed=2.64x frame= 3238 fps= 79 q=29.0 size=N/A time=00:01:47.88 bitrate=N/A dup=647 drop=0 speed=2.65x frame= 3283 fps= 80 q=29.0 size=N/A time=00:01:49.35 bitrate=N/A dup=656 drop=0 speed=2.65x frame= 3327 fps= 80 q=29.0 size=N/A time=00:01:50.63 bitrate=N/A dup=665 drop=0 speed=2.65x frame= 3363 fps= 80 q=29.0 size=N/A time=00:01:51.95 bitrate=N/A dup=672 drop=0 speed=2.65x frame= 3403 fps= 80 q=29.0 size=N/A time=00:01:53.32 bitrate=N/A dup=680 drop=0 speed=2.65x frame= 3438 fps= 79 q=29.0 size=N/A time=00:01:54.47 bitrate=N/A dup=687 drop=0 speed=2.64x frame= 3479 fps= 79 q=29.0 size=N/A time=00:01:55.88 bitrate=N/A dup=695 drop=0 speed=2.65x frame= 3522 fps= 80 q=29.0 size=N/A time=00:01:57.14 bitrate=N/A dup=704 drop=0 speed=2.64x frame= 3552 fps= 79 q=29.0 size=N/A time=00:01:58.29 bitrate=N/A dup=710 drop=0 speed=2.64x frame= 3587 fps= 79 q=29.0 size=N/A time=00:01:59.44 bitrate=N/A dup=717 drop=0 speed=2.64x frame= 3627 fps= 79 q=29.0 size=N/A time=00:02:00.55 bitrate=N/A dup=725 drop=0 speed=2.63x frame= 3667 fps= 79 q=29.0 size=N/A time=00:02:01.96 bitrate=N/A dup=733 drop=0 speed=2.63x frame= 3703 fps= 79 q=26.0 size=N/A time=00:02:03.30 bitrate=N/A dup=740 drop=0 speed=2.63x frame= 3747 fps= 79 q=29.0 size=N/A time=00:02:04.75 bitrate=N/A dup=749 drop=0 speed=2.64x frame= 3793 fps= 79 q=26.0 size=N/A time=00:02:06.31 bitrate=N/A dup=758 drop=0 speed=2.64x frame= 3836 fps= 79 q=29.0 size=N/A time=00:02:07.53 bitrate=N/A dup=767 drop=0 speed=2.64x frame= 3858 fps= 79 q=29.0 size=N/A time=00:02:08.46 bitrate=N/A dup=771 drop=0 speed=2.63x frame= 3889 fps= 79 q=29.0 size=N/A time=00:02:09.49 bitrate=N/A dup=777 drop=0 speed=2.62x frame= 3927 fps= 79 q=29.0 size=N/A time=00:02:10.66 bitrate=N/A dup=785 drop=0 speed=2.62x frame= 3972 fps= 79 q=29.0 size=N/A time=00:02:12.20 bitrate=N/A dup=794 drop=0 speed=2.63x frame= 4003 fps= 79 q=29.0 size=N/A time=00:02:13.39 bitrate=N/A dup=800 drop=0 speed=2.62x frame= 4047 fps= 79 q=29.0 size=N/A time=00:02:14.63 bitrate=N/A dup=809 drop=0 speed=2.62x frame= 4073 fps= 79 q=29.0 size=N/A time=00:02:15.50 bitrate=N/A dup=814 drop=0 speed=2.61x frame= 4102 fps= 78 q=29.0 size=N/A time=00:02:16.53 bitrate=N/A dup=820 drop=0 speed=2.61x frame= 4148 fps= 78 q=29.0 size=N/A time=00:02:18.00 bitrate=N/A dup=829 drop=0 speed=2.61x frame= 4184 fps= 78 q=29.0 size=N/A time=00:02:19.43 bitrate=N/A dup=836 drop=0 speed=2.61x frame= 4213 fps= 78 q=29.0 size=N/A time=00:02:20.39 bitrate=N/A dup=842 drop=0 speed=2.61x frame= 4247 fps= 78 q=29.0 size=N/A time=00:02:21.46 bitrate=N/A dup=849 drop=0 speed= 2.6x frame= 4279 fps= 78 q=29.0 size=N/A time=00:02:22.48 bitrate=N/A dup=855 drop=0 speed= 2.6x frame= 4282 fps= 78 q=-1.0 Lsize=N/A time=00:02:22.80 bitrate=N/A dup=856 drop=0 speed= 2.6x video:9620kB audio:6712kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown[libx264 @ 0000000009333a20] frame I:51 Avg QP:19.22 size: 35972[libx264 @ 0000000009333a20] frame P:1180 Avg QP:22.80 size: 5116[libx264 @ 0000000009333a20] frame B:3051 Avg QP:24.31 size: 648[libx264 @ 0000000009333a20] consecutive B-frames: 4.6% 0.4% 2.9% 92.2%[libx264 @ 0000000009333a20] mb I I16..4: 29.3% 0.0% 70.7%[libx264 @ 0000000009333a20] mb P I16..4: 3.7% 0.0% 0.0% P16..4: 35.8% 0.0% 0.0% 0.0% 0.0% skip:60.6%[libx264 @ 0000000009333a20] mb B I16..4: 0.2% 0.0% 0.0% B16..8: 7.2% 0.0% 0.0% direct: 4.3% skip:88.2% L0:30.5% L1:45.4% BI:24.0%[libx264 @ 0000000009333a20] coded y,uvDC,uvAC intra: 61.1% 67.5% 42.5% inter: 5.6% 7.3% 0.3%[libx264 @ 0000000009333a20] i16 v,h,dc,p: 50% 24% 15% 11%[libx264 @ 0000000009333a20] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 22% 10% 7% 7% 7% 8% 6% 7%
ebr 16309 Posted March 17, 2017 Posted March 17, 2017 Is that one that worked or didn't work? I will say that streaming/transcoding from old folder-style DVD rips is considered experimental because most of the components we use don't actually support it. But, in many cases, we can force it to work.
utah-dave 5 Posted March 17, 2017 Author Posted March 17, 2017 (edited) yes this one dose not stream. I have been making my movies collection since 2004 and all of them are copied in the format. I did it this was because back in the day it way Media Browser and it worked well with it. Should I be doing it different? There is about 10tb of movies that are copied like this. I still use Media Browser at home manly because I can pick the folders that it displays the movies from. So AKA I have a folder called kids and all the movies the kids watch are in the folder, then in Media Center they can brows to there folder. (makes it easy on them ) I don't mind redoing all the movies in a different format, I would like it to still work in Media Browser for the folders, or is there a way to do the same thing in the Emby server. Edited March 17, 2017 by utah-dave
Luke 42198 Posted March 17, 2017 Posted March 17, 2017 Ebr is correct. Transcoding of folder rips is only expiremental. You can have full support for these rips but you'll need to play them from our HTPC apps such as Emby for WMC, Emby for Kodi, and Emby Theater Desktop. Playing from the web app, Roku, Chromecast, etc, these do not support dvd folders natively, then server transcoding is required and that's when we consider it experimental.
utah-dave 5 Posted March 17, 2017 Author Posted March 17, 2017 that's fine. what would be a happy ground for me.. I like the web app, but like folder streaming. if it were you, would you convert all the movies?
sh0rty 727 Posted March 17, 2017 Posted March 17, 2017 that's fine. what would be a happy ground for me.. I like the web app, but like folder streaming. if it were you, would you convert all the movies? I converted mine. All.
utah-dave 5 Posted March 17, 2017 Author Posted March 17, 2017 any good recommendation on what soft you use.
utah-dave 5 Posted March 17, 2017 Author Posted March 17, 2017 Thanks I will give that a try... Thank you for your help and input today.
utah-dave 5 Posted March 22, 2017 Author Posted March 22, 2017 how about a video format that both the server will play and media browser? the makeMkv works great for the server. but media browser wont play it.
Happy2Play 9802 Posted March 22, 2017 Posted March 22, 2017 how about a video format that both the server will play and media browser? the makeMkv works great for the server. but media browser wont play it. What do you mean media browser won't play it?
utah-dave 5 Posted March 22, 2017 Author Posted March 22, 2017 when I go into media browser, then the folder, then click on the folder that has the movie, the movie is split into 4 peace's and when you click MKV_t00 or what ever one I get an err that say cant play format. my other movies at are in a VTS format. and media browser will play those and dose not show the individual file formats.
Luke 42198 Posted March 22, 2017 Posted March 22, 2017 By Media Browser, you mean Emby for Windows Media Center? It should play mkv's just fine. Try installing LAV filters.
ebr 16309 Posted March 22, 2017 Posted March 22, 2017 when I go into media browser, then the folder, then click on the folder that has the movie, the movie is split into 4 peace's and when you click MKV_t00 or what ever one I get an err that say cant play format. my other movies at are in a VTS format. and media browser will play those and dose not show the individual file formats. This sounds to me like maybe you selected all the "titles" that were defined on your disc when you ran MakeMkv. You wanted to only select the proper one (the version of the film you wanted). Some copy protection schemes make this a little tricky to find but most discs are pretty straightforward. But all of that is beyond the scope of Emby and there is lots of information on it on other forums.
utah-dave 5 Posted March 29, 2017 Author Posted March 29, 2017 Ok. I know your getting sick of me. But one more question. I have found the .avi works both in media browser and Emby server online streaming. But the movie is way jumpy. is that just how AVI is or is it the quality of the software I am using? MVK works great for the server streaming but media browser wont play the media format. it is no way a hardware problem I have sooo over killed the server its not funny. Trying to find the best of both worlds. Thanks again
Luke 42198 Posted March 29, 2017 Posted March 29, 2017 We'd have to look at an example. Best thing to do is provide the information requested in how to report a problem. Just be aware, Emby for WMC (which you're referring to as Media Browser) can play MKV no problem. I'm afraid the fact you feel that way is only your perception, however since WMC does rely on Windows Media Player, it does mean you have to install additional software in order to make it play. Thanks !
utah-dave 5 Posted March 29, 2017 Author Posted March 29, 2017 there is no perception here. I just know what works for my kids... The ver of media browser I am using is 6.2. And if you remember you would install it, then go to config media browser and set the folders you wish to stream from. Back wards from what it is like today. the only reason I stick with it, is because I have a folder called kids, and in that folder all the movies the kids watch are in that, its is supper supper easy for the kids in WMC to click Media Browser, Kids then pick their film. I have only been able to get It to stream the AVI or ripped dvds. if there was some way to display the folders how I have them right now I would bail and jump ship on the "old way" and convert everything. Me and you get how navigate around, but to a 9 year old, simple is key. Heck the currant system is so simple that my toddler knows how to work it.. sorry to sounding like a broken recorded, and a pain. I understand more than most about IT support, and there are some people you wish would just upgrade so the support was not so hard to mix old with new. I will find a way around. Thanks for giving it a go for me.
Luke 42198 Posted March 29, 2017 Posted March 29, 2017 Even the old media browser can play MKV, no problem. We all did it for years back in the day.
Spaceboy 2573 Posted March 29, 2017 Posted March 29, 2017 We did but wasn't there something you had to do to tell wmc it could play mkv's ? But as you say it's been a while so maybe I misremembered
ebr 16309 Posted March 29, 2017 Posted March 29, 2017 You need the proper codecs which used to be a pain but, these days, just installing LAV should get you everything you need.
ebr 16309 Posted March 30, 2017 Posted March 30, 2017 sorry to sound dumb again... LAV??? LAV Filters
