CBers 7554 Posted March 16, 2017 Posted March 16, 2017 I'm having issues with the channels in the UK not having a fully populated EPG.I have removed the HDHomeRun tuner, cleared the cache/httpclient folder, restarted Emby, re-added the HDHomeRun timer and refreshed the guide, but I still have huge gaps in the EPG.I'm also seeing channels appear in the EPG that are not part of the UK FreeView TV pacakge, such as Sky Sports (see attached images).Not sure if this is due to the recent tuner changes or a problem at SD, but the HDHomeRun app on my Shield TV's seems to be working fine.Will post server log shortly.
Luke 42243 Posted March 16, 2017 Posted March 16, 2017 cleared the cache/httpclient folder You never need to do this. I should not have said anything. I will move that folder so there is no longer a feeling that it should be removed. Thanks for attaching the server log. 1
CBers 7554 Posted March 17, 2017 Author Posted March 17, 2017 Luke - did you see anything awry in the server log? Under my SD account, it looks like I have 3 UK lineups: GBR GBR-0000069-DEFAULT SD-JSON GBR GBR-0001318-DEFAULT SD-JSON GBR GBR-0003012-DEFAULT SD-JSON
CBers 7554 Posted March 17, 2017 Author Posted March 17, 2017 Under my SD account, it looks like I have 3 UK lineups: GBR GBR-0000069-DEFAULT SD-JSON GBR GBR-0001318-DEFAULT SD-JSON GBR GBR-0003012-DEFAULT SD-JSON Luke - SchedulesDirect are telling me to delete those entries from my SD account via Emby, but there's no option, so where are the details stored please?
Luke 42243 Posted March 17, 2017 Posted March 17, 2017 To remove it from your SD account is a feature we still need to add into our SD account management page.
CBers 7554 Posted March 17, 2017 Author Posted March 17, 2017 To remove it from your SD account is a feature we still need to add into our SD account management page. So is the information in the library.db ??
