berrick 30 Posted March 15, 2017 Posted March 15, 2017 Emby server Version 3.2.7.0 Running on Windows 7 Ultimate Pro All libraries configured to Download from internet Save artwork etc to media folders enabled for real time monitoring I did some house keeping on music in my library to get rid of duplicate entries which were there mostly due to typo's. However once corrected no matter how I try the library still shows the duplicates. It does appear that some data is being updated. Any suggestions pls?
Luke 42200 Posted March 15, 2017 Posted March 15, 2017 Hi there, we're sorry to hear about your issue. Please discuss a specific a specific example and provide the information requested in how to report a problem. thanks !
berrick 30 Posted March 20, 2017 Author Posted March 20, 2017 Hi Luke, Deliberately didn't post any logs in case you want to capture log info whilst doing something specific. Will post logs shortly.
berrick 30 Posted April 14, 2017 Author Posted April 14, 2017 Hi Luke, A bit of a delay posting logs sorry. I have also noticed that Emby and Emby theater don't display the same content for the same selection. Kind regards Logs.txt
Luke 42200 Posted April 14, 2017 Posted April 14, 2017 I still need the discussion of a specific example, thanks.
berrick 30 Posted April 16, 2017 Author Posted April 16, 2017 After correcting double entry's for things such as missing letter in artist name etc Emby doesn't remove from DB, I'm guessing, as they still display in output as show in above images. For example, S.I.A Sammy Davis Jnr. Sagitaire
Luke 42200 Posted April 17, 2017 Posted April 17, 2017 @@berrick How exactly did you perform that correction?
berrick 30 Posted April 18, 2017 Author Posted April 18, 2017 The corrections were made outside of Emby. I browsed to the relevant file and either renamed the filename and or edited the tags as necessary.
Luke 42200 Posted April 18, 2017 Posted April 18, 2017 Ok yes in that case there are some improvements that need to be made to our cleanup of obsolete artist entries. thanks.
