mbguy 40 Posted August 17, 2021 Posted August 17, 2021 I can’t find subtitle size/color adjustments on Emby’s Android TV app which I use on Shield. This is a real issue because my Samsung HDR TV is producing color shifts due to the brightness of the subtitle white text so I need to reduce subtitle size, change subtitle color or add a semi transparent block behind white text to prevent color shifts. I can perform these changes on Netflix and Prime apps but missing this ability to do so on Emby. Please, Emby team, are you guys close to getting this done?
GrimReaper 4899 Posted August 17, 2021 Posted August 17, 2021 (edited) 2 hours ago, mbguy said: I can’t find subtitle size/color adjustments on Emby’s Android TV app which I use on Shield. This is a real issue because my Samsung HDR TV is producing color shifts due to the brightness of the subtitle white text so I need to reduce subtitle size, change subtitle color or add a semi transparent block behind white text to prevent color shifts. I can perform these changes on Netflix and Prime apps but missing this ability to do so on Emby. Please, Emby team, are you guys close to getting this done? What do you mean by "can't find it"? Settings>Sub/Audio Defaults? Change Size, Color, Brightness, Enable/Disable Background? Edited August 17, 2021 by GrimReaper76 Typo
ebr 16338 Posted August 17, 2021 Posted August 17, 2021 1 hour ago, GrimReaper76 said: What do you mean by "can't find it"? Settings>Sub/Audio Defaults? Change Size, Color, Brightness, Enable/Disable Background? Hi. Yes, this is available in that app. Please let us know if that answers your question.
mbguy 40 Posted August 17, 2021 Posted August 17, 2021 7 hours ago, GrimReaper76 said: What do you mean by "can't find it"? Settings>Sub/Audio Defaults? Change Size, Color, Brightness, Enable/Disable Background? I meant what I wrote, that I couldn't locate the settings for the subtitles, because I thought "Sub/Audio" refers to subwoofer+audio due to semantic association effect and also I expected the subtitle settings to be available in-video not in app menu. Thanks for pointing out where it is though! Much appreciated. 5 hours ago, ebr said: Hi. Yes, this is available in that app. Please let us know if that answers your question. Yes it did. Thanks. Out of curiosity, may I ask why these settings are placed in the app menu, instead of video/playback window? For example, Prime app allows subtitles color, font and background color to be changed during playback, so one can preview exactly how the changes look like and choose the best one based on content. Emby's implementation is of course still miles better than Netflix's horrible and web-based settings for subtitles that are not even available in-app. Still I'm curious why Emby decided on this approach.
ebr 16338 Posted August 17, 2021 Posted August 17, 2021 Hi. We might put a link to this during playback at some point but there are already so many options available on the OSD that it just starts to get to be overload. Thanks. 1
mbguy 40 Posted August 18, 2021 Posted August 18, 2021 22 hours ago, ebr said: Hi. We might put a link to this during playback at some point but there are already so many options available on the OSD that it just starts to get to be overload. Thanks. Thanks for the explanation. If it makes the difference, I do not think "there are already so many options on the OSD right now" so making subtitles settings available in playback will not be an "overload," for me at least. I know it's just a single vote and one single data point, but maybe you will find other users or team members who think the "Netflix-style" setting sucks, and "Prime-style" setting should be the standard. I haven't tested Apple TV app yet, now I am curious if they are Netflix-style or Prime-style too. 1
Luke 42246 Posted September 9, 2021 Posted September 9, 2021 The ability to adjust subtitle background color and background opacity will be in Emby Server 4.7 as well as in upcoming app updates. Thanks. 4
mbguy 40 Posted September 11, 2021 Posted September 11, 2021 On 9/9/2021 at 11:13 AM, Luke said: The ability to adjust subtitle background color and background opacity will be in Emby Server 4.7 as well as in upcoming app updates. Thanks. Thanks for this wonderful gift that makes Emby the best!
Davey's 40 Posted September 17, 2021 Posted September 17, 2021 Does this mean - all apps-? When I'm playing a DVD its subs are always yellow in most of the apps I use; LG, Android and RPI.
Luke 42246 Posted September 17, 2021 Posted September 17, 2021 1 hour ago, Davey's said: Does this mean - all apps-? When I'm playing a DVD its subs are always yellow in most of the apps I use; LG, Android and RPI. All apps will get there in upcoming app releases. Make sure to read the help text that indicates what subtitle formats it applies to. Your DVD subtitles are image based and have all of the styles already embedded.
Eskape 3 Posted July 28, 2023 Posted July 28, 2023 Can you please add this functionality to the Apple TV app? Thank you!
Luke 42246 Posted August 2, 2023 Posted August 2, 2023 On 7/28/2023 at 2:38 PM, Eskape said: Can you please add this functionality to the Apple TV app? Thank you! HI, yes it is planned for future updates to the Emby Apple TV app. Thanks.
bleachjt 1 Posted September 2, 2023 Posted September 2, 2023 Any ETA on this feature on AppleTV? Some shows are unwatchable because subs are white, no background and a bit too small. Gets worse if it's a show that use a lot of bright colors. If there was any beta version I could sign up for to test this feature, I'd be up for that.
Luke 42246 Posted September 14, 2023 Posted September 14, 2023 On 9/2/2023 at 1:35 PM, bleachjt said: Any ETA on this feature on AppleTV? Some shows are unwatchable because subs are white, no background and a bit too small. Gets worse if it's a show that use a lot of bright colors. If there was any beta version I could sign up for to test this feature, I'd be up for that. Hi, no ETA yet but it is on our roadmap. It's moving up the list. Thanks.
