roberto188 33 Posted March 15, 2017 Posted March 15, 2017 When I go to play a movie that has a TrueHD audio track on my Roku TV, no audio comes out. I don't think Emby is transcoding the audio. All other audio tracks work except that one. My Roku 3 plays it no problem, just the Roku TV has the issue.
Luke 42242 Posted March 15, 2017 Posted March 15, 2017 Hi there @@roberto188, we're very sorry to hear about this. Can you please provide the Emby Server and ffmpeg logs from this playback attempt? You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
roberto188 33 Posted March 16, 2017 Author Posted March 16, 2017 (edited) My apologies @@ebr. The audio is NOT TrueHD it's DTS. None the less my roku TV audio settings is set to stereo mode only and I am NOT passing through any audio to a receiver, yet Emby directplays the movie with no transcoding of the audio. If I reduce the allowable bitrate to below that of the movie and emby is forced to transcode the audio it works no problem. Attached is the relevent portion of server log where it is directplaying the movie, yet the ROKU TV cannot decode DTS audio. serverlog.txt Edited March 17, 2017 by Luke
KeyserSoze1 2 Posted March 18, 2017 Posted March 18, 2017 Well I can't say for sure. But I do know my Roku TV specifications lists DTS in the audio codec list. However there is an asterisk beside it that states only for passthrough the optical or ARC. @@ebr would know the answer better than me, but can the Roku Emby app determine what the audio settings are set at for the tv? Then it could include/exclude dts based on that. If not it gets a bit more complicated.
ebr 16335 Posted March 18, 2017 Posted March 18, 2017 Hi roberto, I missed this post somehow. Sorry. Can you please do the following: Go to settings in the app and turn on Debug Options Restart the app Play your item for a few seconds Go back to the home screen and hit the "Send Log" button on the bottom row Come back here and tell me what you played, when you did that and the name of your Emby server Thanks.
ebr 16335 Posted March 18, 2017 Posted March 18, 2017 can the Roku Emby app determine what the audio settings are set at for the tv? @@speechles do you know the answer to this off the top of your head?
roberto188 33 Posted March 18, 2017 Author Posted March 18, 2017 Was using the old emby app. New one works perfect. Thanks!
speechles 2062 Posted March 18, 2017 Posted March 18, 2017 (edited) @@speechles do you know the answer to this off the top of your head? The answer is most certainly yes. The only time the roku may do this incorrectly is if the TV is off when the roku is first turned on. This means the HDMI handshake isn't telling the roku what isnt supported. Usually people leave their roku always on then just turn the tv on/off and will never experience an issue. Its those who turn off their rokus who will find problems. EDIT: The rokuTV may report it supports DTS, when in fact it doesn't natively. This is because it has ability to pass-through DTS to a receiver. The TV itself will not be able to decode the audio and will produce silence. Edited March 18, 2017 by speechles
