Bloodred 14 Posted September 30, 2018 Author Posted September 30, 2018 From the PlayRequest, as in playReq.ControllingUserId (in this case it's "1").
Elegant 11 Posted December 15, 2018 Posted December 15, 2018 Any chance for the launcher to support the https port? It doesn't seem to like the certificate used by my proxy. Thanks! 1
Bloodred 14 Posted December 15, 2018 Author Posted December 15, 2018 Hi, I'm afraid I don't know much about how HTTPS support works with Emby and I don't have it set up myself. The connection to the server is established in the Emby API client library, so the E2PL doesn't touch that directly at all, though I don't know at this point if there's any special setup/configuration required in order for it to support HTTPS. More of a guess than anything else, but are you using a self-signed certificate or one signed by a CA which isn't trusted by default on your proxy? That might cause the connection to fail I assume, so if this is the case it might help to try to get your hands on a different certificate or to configure your CA as trusted in Windows (I don't remember exactly what the process for this was) with the hope that the Emby client will know to pick up on that. Sorry I can't be of more help, but when I get some time I'll have a quick look to see if there's anything I could do from the E2PL side.
Luke 42237 Posted December 15, 2018 Posted December 15, 2018 For HTTPS you will need to supply a certificate under Advanced settings.
Elegant 11 Posted December 15, 2018 Posted December 15, 2018 @@Bloodred The reverse proxy is providing the CA signed certificate and Windows does trust it per the attached. @@Luke In this case, wouldn't Emby require the CA instead of the certificate since it's handled by the reverse proxy? I wasn't able to spot an option to supply the CA.
Luke 42237 Posted December 15, 2018 Posted December 15, 2018 There is a setting in the advanced section of the server dashboard to allow you to indicate that https is being handled by your reverse proxy.
Elegant 11 Posted December 15, 2018 Posted December 15, 2018 "Secure Connection Mode" is already set to "Handled by reverse proxy" though, is there something else required? Thanks!
Elegant 11 Posted December 16, 2018 Posted December 16, 2018 (edited) Unfortunately, it's not working. Whenever I connect using emby.svc.example.com:443 I am met with "Could not connect to Emby. Please check your settings." If I revert to using emby.svc.example.com:80, I have no issues. 80 and 443 (SSL) are the ports used for the reverse proxy, Emby is still using 8096 internally. Something must be missing... Edited December 16, 2018 by Elegant
Elegant 11 Posted December 16, 2018 Posted December 16, 2018 (edited) The Emby External Player Launcher, if I set the address to use the SSL port (443) it will fail to connect (see attached). If I access Emby using the same address and port in the web browser, I have no issues and the certificate is trusted per my previous post. Edited December 16, 2018 by Elegant
Luke 42237 Posted December 16, 2018 Posted December 16, 2018 Ok, I'm not familiar enough with this , but first things being first, are you able to use https with Emby apps?
KMBanana 116 Posted December 16, 2018 Posted December 16, 2018 Is there a need for https with this app? You need to be on the same machine or LAN as the Emby server for it to work in the first place.
Elegant 11 Posted December 16, 2018 Posted December 16, 2018 (edited) @@Luke I never had to download an Emby app previously. Downloading Emby Theatres actually taught me what the issue was. I noticed that using emby.svc.example.com:443 did not work here either BUT I did notice the example at the bottom of Emby Theatre (192.168.1.100 or https://myserver.com). So I tried using https://emby.svc.example.com instead which works. The key was putting https:// in the address bar. Thanks! Edited December 16, 2018 by Elegant
Bloodred 14 Posted December 17, 2018 Author Posted December 17, 2018 I'm glad you got it working! It makes a lot of sense actually for "https://" to be required there since the client wouldn't really have any way to know that it should be trying to establish an encrypted connection, so I guess it was just using regular HTTP over port 443 which obviously wouldn't work if your proxy expected HTTPS. I should've thought of that. Anyway, good thing you could solve the problem and thanks for posting the solution.
fyngd 2 Posted March 15, 2019 Posted March 15, 2019 2019-03-15 10:38:38,753 [1 ] INFO EmbyExternalPlayerLauncher.Program - Emby External Player Launcher is starting. 2019-03-15 10:38:39,136 [1 ] INFO EmbyExternalPlayerLauncher.ServerConnect.AutoConnector - Connecting to Emby Server... 2019-03-15 10:38:40,869 [5 ] INFO EmbyExternalPlayerLauncher.ServerConnect.EmbyPlayerConnector - Connected to Emby server at http://192.168.1.8:8096 2019-03-15 10:38:40,904 [9 ] ERROR EmbyExternalPlayerLauncher.ServerConnect.Logging.EmbyLogger - Error connecting to ws://192.168.1.8:8096/emby/embywebsocket?api_key=373cf605e5ba48fb9a4b881bdafc9422&deviceId=E2PL-admin@@Ning System.PlatformNotSupportedException: 此平台不支持 WebSocket 协议。 在 System.Net.WebSockets.ClientWebSocket..ctor() 在 Emby.ApiClient.WebSocket.NativeClientWebSocket..ctor(ILogger logger) 在 Emby.ApiClient.WebSocket.ClientWebSocketFactory.CreateWebSocket(ILogger logger) 在 Emby.ApiClient.WebSocket.ClientWebSocketFactory.CreateWebSocket() 在 Emby.ApiClient.ApiClient.<EnsureConnectionAsync>d__296.MoveNext()
Elegant 11 Posted July 13, 2019 Posted July 13, 2019 Just noticed that it seems to fail if using LDAP for authentication. Tested with one user using LDAP and another without. Would it be possible to have support added? Thanks!
Bloodred 14 Posted July 21, 2019 Author Posted July 21, 2019 Hello! I'm afraid I've never personally used LDAP and don't know much about it. I assume it's something you configure on the Emby server, right? The authentication is handled by the Emby client library and E2PL only really provides the user name and password. I can have a look at it, but I'm not sure I'll be able to do anything about it. Is this something which used to work in the past but no longer works since a server update or something like that? It's possible that something changed in the server API too.
Elegant 11 Posted July 22, 2019 Posted July 22, 2019 It may be related to the server API per @@Luke's comments in the LDAP Plugin thread. My credentials work fine in other tools/plugins such as Emby for Kodi but this specific one is giving me trouble when authentication is changed to LDAP in Emby. Thanks!
saltywatermelonsoda 2 Posted September 22, 2019 Posted September 22, 2019 is E2PL still being actively developed? basic functionality of playing videos with MPC-HC (1.8.7) still works, but Automatic viewing progress synchronization Resuming in-progress videos Remote control are now broken. the log shows this error: 2019-09-20 22:09:28,494 [9 ] INFO EmbyExternalPlayerLauncher.ServerConnect.EmbyPlayerConnector - Playing "XYZ" from "F:\Movies\1080p\XYZ.mp4"2019-09-20 22:09:30,515 [22 ] ERROR EmbyExternalPlayerLauncher.Players.MpcHc.MpcHcWebAdapter - Could not get player status. I'm running the latest versions of Emby Server (4.2.1.0), MPC-HC (1.8.7) and E2PL. Thanks!
Bloodred 14 Posted September 23, 2019 Author Posted September 23, 2019 Hello! Apologies for the late reply, my free time was limited lately as I have a few other things keeping me busy. @@Elegant - in regards to LDAP not working, what you've found is sadly correct, the problem is the fact that there have been API changes on the server side which don't seem to have been carried over to the client library I'm using in E2PL, I don't think there's much I can do about it from the E2PL code itself, unless the library gets updated and the new version remains compatible with what E2PL is using. For my own Emby server, I decided a while ago to stop updating it (on 3.5.2.0) because I assumed API changes would indeed appear at one point, as they actually have. I don't know if downgrading is possibly an option for you or not, but I guess LDAP might work with an older server version, before the API changes. Again, I don't use LDAP myself though. @@Luke, the library seems to have been last updated 2 years ago, at least there isn't a newer NuGet package that I can see (I'm looking here: https://www.nuget.org/packages/MediaBrowser.ApiClient/). Will this library ever be updated again, or is it deprecated/abandoned at this point? @@saltywatermelonsoda, for that issue I actually have some good news. I have encountered it myself since I use the same version of MPC-HC, along with another issue which sometimes prevented proper progress tracking. This happens because the web server in newer versions of MPC-HC seems to behave differently. One problem is that it's very slow to respond sometimes, so the request from E2PL times out and as such it cannot get the status, as if the player wasn't running. You can already mitigate this by setting the timeout in E2PL to a larger value, such as 10s (so 10000ms in the config). There's another problem with the newer version of MPC-HC sometimes intermittently returning player stopped status when it's not actually stopped, seems to happen sometimes when loading videos or changing refresh rate. I have a new version which tries to address this problem and I will release it in the following days. There are some other issues which I believe might be related to API changes too (live progress updates during playback don't always work properly anymore, but progress should be corrected when you close MPC-HC), not sure whether I'll be able to fix those. Increasing the timeout and the upcoming version should fix some of the functionality, though.
saltywatermelonsoda 2 Posted September 23, 2019 Posted September 23, 2019 There's another problem with the newer version of MPC-HC sometimes intermittently returning player stopped status when it's not actually stopped, seems to happen sometimes when loading videos or changing refresh rate. I have a new version which tries to address this problem and I will release it in the following days. Thanks Bloodred! think this is also what is happening on my side, except it happens every time with every video i've tried so far. the emby actvity log shows these events on the dashboard (always exactly on the 60s mark): saltywatermelonsoda is playing XYZ.mp4 on E2PL 9/23/2019, 7:15:37 pm saltywatermelonsoda has finished playing XYZ.mp4 on E2PL 9/23/2019, 7:16:37 pm increasing the timeout to 10000ms and more hasn't changed anything, so i'll keep an eye out for the update. thank you so much for keeping E2PL alive!
