Emby Info pop-up going crazy in Kodi
Already mentioned this in the Fast Startup Sync thread but it seems no Fast sync issue.
After playing an episode in Kodi a popup appears on top and is going really fast up and down.
The pop-up says "Emby for Kodi incremental sync 0%."
I have changed the Emby setting "show progress if more item than" to 25000 and now the popus going carzy are gone and new items are visable for me.
To me it seems a fast sync issue some how. With this change it is solved for me.
Kodi log
Also see this topic
Can this be reviewed?
Guest
