stettler 31 Posted March 12, 2017 Posted March 12, 2017 Hello, Another problem that I noticed while making tests: I put several video with different frame rates in the same "serie" folder (to avoid looking for them everywhere while doing tests). Some video are 24fps, other 25 fps or 50 fps. I noticed that, in that case, ET won't change to the monitor to the correct display rate: All video will be played at the same display rate. (playing the same videos from their original locations work fine. So the problem is really caused by having videos with different frame rates in the same folder)
Luke 42243 Posted March 12, 2017 Posted March 12, 2017 Perhaps the server hadn't completed probing the new files yet, therefore Emby Theater was not yet aware of the framerate of the new videos.
stettler 31 Posted March 12, 2017 Author Posted March 12, 2017 I ran the scan library task fully before (and made the tests several hours after). Also, all the video were in "direct play" (dunno if that change anything for this case)
Luke 42243 Posted May 1, 2017 Posted May 1, 2017 @@stettler The next release of Emby Theater will feature improved performance, hardware acceleration, and better multi-monitor support. If you'd like to try it out ahead of time you can do so here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-1 Enjoy.
