FordGT90Concept 103 Posted March 12, 2017 Posted March 12, 2017 I'm going to TL;DR this: Symptom: -Live TV on Leelbox Master, the program info on the bottom would flicker and not go away. -Live TV on Leelbox MQX Pro, same thing. -Live TV on NVIDIA Shield, same thing. -Live TV on computers are fine. Live TV via HDHomeRun app on Leelbox is fine. Observation: -Log was getting spammed hard: 1-2 KiB/s. The spamming stopped when stopping Live TV. -Only occurs in Live TV. Watching recording is fine. -Leelbox is running old version of Emby. Shield is running latest. -Swapped the two (because one is wired and one is wireless) and all three devices did the same thing. Attached logs. logs.zip
ebr 16337 Posted March 12, 2017 Posted March 12, 2017 Sounds like the stream is continuously erroring out and restarting. I would suspect it also stutters quite a bit. Please follow the instructions to send a log from the app when it happens. Thanks. How to Report a Problem
FordGT90Concept 103 Posted March 12, 2017 Author Posted March 12, 2017 Well that's odd, it seems to be working fine now. That said, I sent the logs anyway from the SHIELD. If the logs go back 24 hours, it should still have the problem logged in there.
