arasquinha 3 Posted October 5, 2017 Posted October 5, 2017 Hi, log files are more helpful right now than those configuration screenshots. thanks ! sorry. i have my personal thread going with my issue. I will post there. i was just responding here as the nice individual was attempting to help me out. https://emby.media/community/index.php?/topic/51249-original-hdhr-us-support-with-live-tv/
kanipek 230 Posted October 5, 2017 Author Posted October 5, 2017 i have a windows 2016 server running emby the issues i am having are also occuring on this device so its not a firewall issue. i do have the firewall turned off. the hdhomerun is on the same internal network/lan. it should not have firewall issues. i have not installed any plugins What type of channels are you tuning to? Are they over the air? (looks like they are from the one screeshot) or Cable? if they are cable do you know if there is any DRM settings being used by the provider? I guess the easy way to figure that out if you have cable is what channels can you get by plugging the cable directly in to a TV. I would disable "Enable Throttling". I would disable at a minimum - "Preserve Original Video...." and "Preserve Original Audio...." not sure if the settings apply to live tv or not,
arasquinha 3 Posted October 5, 2017 Posted October 5, 2017 these are all ota ATSC i live in north america. i will try that. 1
