jordy 284 Posted November 17, 2020 Posted November 17, 2020 (edited) Guys, If you want to have the tabs view AND have Shows & Movies as the default Tab On the web homepage, click your user icon, Select Home page scroll down until you see the sections for TV & Movies and then change the default screen. Edited November 17, 2020 by jordy Spelling and text
RandyW 1 Posted May 28, 2023 Posted May 28, 2023 I know this is an old topic, but it is still an issue, 3 years later. Is there any way yet, in the Apps, or "Theater View" to make the landing page for each section NOT be suggestions? I jsut want to click movies and see my list of movies.
ebr 16354 Posted May 28, 2023 Posted May 28, 2023 2 minutes ago, RandyW said: Is there any way yet, in the Apps, or "Theater View" to make the landing page for each section NOT be suggestions? I jsut want to click movies and see my list of movies. Hi. Yes. In most of the apps you can set a default landing tab in the Home Screen settings. In the TV apps, there is a cog menu right in each library view that allows you to set this for each library. 1
