sualfred 677 Posted March 11, 2017 Posted March 11, 2017 (edited) Hey there, As soon as I add a new show by using the AutoOrganize tool, it won't be automatically added to my database. I have to trigger a library scan. That's not a big deal but this is causing another issue: The auto organize index shows the show twice. I also get randomly the notication that 2 of those shows have new seasons (web popup), but this is simply wrong. Maybe it has something to do with that "duplicate content" bug? Edit: Attached the log. Kevin Can Wait and Designated Survivor are the two series, which are always "added" after each library scan. Both of them are also listed twice in the Auto Organize dialog. Log.txt Edited March 11, 2017 by sualfred
Luke 42197 Posted March 11, 2017 Posted March 11, 2017 Auto-organize notifies the real-time monitor so if you wait a few minutes the change will also be reflected that way.
sualfred 677 Posted March 11, 2017 Author Posted March 11, 2017 Auto-organize notifies the real-time monitor so if you wait a few minutes the change will also be reflected that way. Yes, you are right. This was broken on my side a few version ago but it seems to recognize them now after a while. But this doesn't explain why the Auto Organize has duplicate items in the list and why I always get notified about a new season for the other two shows even if nothing has changed? The nfo file is also written again and again after a library scan. Please take a look at the attached screens.
Luke 42197 Posted March 11, 2017 Posted March 11, 2017 They are just obsolete database entries. We need to improve the database cleanup. thanks.
sualfred 677 Posted March 11, 2017 Author Posted March 11, 2017 (edited) They are just obsolete database entries. We need to improve the database cleanup. thanks. Ok, that explains the duplicates. Thanks. But what about the ongoing notifications? ^^ The logs are telling something something about a "virtual season". Edited March 11, 2017 by sualfred
sualfred 677 Posted March 20, 2017 Author Posted March 20, 2017 @@Luke I've added a new show with the Auto Organize feature today, and it wasn't automatically added to the library. I got the popup notifications about new episodes but the listing of the show and the season wasn't available. I've waited a couple of minutes and nothing has changed, but with a manually triggered library scan it was added. And: I still get the annoying notifications about Kevin Can Wait and Designated Survivor.
Luke 42197 Posted March 20, 2017 Posted March 20, 2017 I would check again. If it recognized the new episode then the series has to be there. Thanks !
