Spaceboy 2573 Posted July 11, 2017 Posted July 11, 2017 (edited) the other sites are using a reverse proxy so theres no html or php files in the caddy directory. Organizr is running as a website so you have to point caddy to where the html files are stores. If the above didnt work and your only planning on running 1 website from caddy then you could move the Organizr files from \caddy\www\organizr to caddy\www and then put the change i suggested above back to normal and test again. For example the way i do it with NGINX is sort of the same. so for me i have 3 websites running location / root www\Organizr location / root www\blog location / root www\Homepage then i have all my other services reverse proxied like you have gotcha, I understood about sonar/radar etc but I now I see you have to do this for all sub-levels, your blog and your homepage. well you never know, I may need another website in future so lets try and do this properly! but your post raises another question. There were no html files in the organizr master file that I downloaded, should there have been? when I extract the zip file there are no html files in the root of the organizr folder Edited July 11, 2017 by Spaceboy
CBers 7554 Posted July 11, 2017 Posted July 11, 2017 but your post raises another question. There were no html files in the organizr master file that I downloaded, should there have been? when I extract the zip file there are no html files in the root of the organizr folder Correct, as you open index.php to start Organizr.
Spaceboy 2573 Posted July 11, 2017 Posted July 11, 2017 Correct, as you open index.php to start Organizr. ah ok, that's my trouble shooting exhausted then... but ultimately i'm still getting a 404 error when trying to access domain/organizr . I can open an index.html in www if I revert the changes I made following synol's guidance so everything seems to be working apart from organizr. although my external user is having trouble connecting from a firetv through the new reverse proxy so perhaps its not all working
Swynol 375 Posted July 12, 2017 Posted July 12, 2017 ok, i will try installing caddy today and see what i can work out. not very familiar with the config file.
Swynol 375 Posted July 12, 2017 Posted July 12, 2017 installed caddy but managed to hit the acme challenge limit as it was erroring on getting a cert. have to wait an hour before i can request again. forgot to forward my root domain name i.e. domain.com to my ddns. 1
Spaceboy 2573 Posted July 12, 2017 Posted July 12, 2017 installed caddy but managed to hit the acme challenge limit as it was erroring on getting a cert. have to wait an hour before i can request again. forgot to forward my root domain name i.e. domain.com to my ddns. thank you very much for taking a look at this! although you did say you were interested in checking out caddy so maybe in a round about way i'm helping you out! 1
Swynol 375 Posted July 12, 2017 Posted July 12, 2017 ye your right i did want to test, was just being lazy. I'm getting somewhere now. Caddy is up and running. i have a index.html file in caddy\www if i go to mydomain.com i get my html file. I put Organizr files in caddy\www\organizr and used the config https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr fastcgi / localhost:9000 php gzip } it sort of works. I now dont get a 404, Organizr loads but it fails to load some files it needs. so my full config looks like mydomain.com { startup /caddy/php/php-cgi -b 127.0.0.1:9000 & ext .html .htm .php root /caddy/www gzip proxy /emby 127.0.0.1:8096 { transparent websockets } } https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr fastcgi / localhost:9000 php gzip }
Swynol 375 Posted July 12, 2017 Posted July 12, 2017 (edited) woop woop got it working. i had to put the fastcgi and php start up into the organizr 'block' startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php If you had multiple sites that used .php then i'm not sure if you will be able to use the same php port number for each block or if a different port will work. i.e. https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } https://mydomain.com/anotherphp { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } or like this https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } https://mydomain.com/anotherphp { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9001 & fastcgi / localhost:9001 php gzip } anyway here is the full config for mine. i havent added any of the extra security yet, but its a start. You will have to change your x-frame security header to SAMEORIGIN for the services to work inside Organizr. Also change Referrer-Policy "strict-origin" to "no-referrer" unless your using some analytics stuff. mydomain.com { ext .html .htm .php root /caddy/www gzip proxy /emby 127.0.0.1:8096 { transparent websocket } proxy /sabnzbd localhost:8087 { websocket transparent } proxy /sonarr localhost:8989 { transparent } proxy /ombi localhost:3579 { transparent } proxy /radarr localhost:7878 { transparent } proxy /headphones localhost:8181 { transparent } } https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } EDIT: sorry changed a few formatting and added stuff Edited July 12, 2017 by Swynol 2
Swynol 375 Posted July 12, 2017 Posted July 12, 2017 (edited) just looking at different configs for Caddy, it looks very interesting. If you have your own certs you can use the following to load them. They need to be in .pem and .key format tls { load /www/certificates } also anyone looking as to where the certs are stored when caddy automatically generates them, on windows its C:\Users\%username%\.caddy\acme\.... Edited July 12, 2017 by Swynol
Spaceboy 2573 Posted July 12, 2017 Posted July 12, 2017 woop woop got it working. i had to put the fastcgi and php start up into the organizr 'block' startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php If you had multiple sites that used .php then i'm not sure if you will be able to use the same php port number for each block or if a different port will work. i.e. https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } https://mydomain.com/anotherphp { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } or like this https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } https://mydomain.com/anotherphp { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9001 & fastcgi / localhost:9001 php gzip } anyway here is the full config for mine. i havent added any of the extra security yet, but its a start. You will have to change your x-frame security header to SAMEORIGIN for the services to work inside Organizr. Also change Referrer-Policy "strict-origin" to "no-referrer" unless your using some analytics stuff. mydomain.com { ext .html .htm .php root /caddy/www gzip proxy /emby 127.0.0.1:8096 { transparent websocket } proxy /sabnzbd localhost:8087 { websocket transparent } proxy /sonarr localhost:8989 { transparent } proxy /ombi localhost:3579 { transparent } proxy /radarr localhost:7878 { transparent } proxy /headphones localhost:8181 { transparent } } https://mydomain.com/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi / localhost:9000 php gzip } EDIT: sorry changed a few formatting and added stuff ok i tried this just replacing mydomain with my actual domain but caddy doesnt start with this as my conf file. i get a parse error: unknown directive. i've tried looking at the text to see if i can spot the error but i can't
Spaceboy 2573 Posted July 12, 2017 Posted July 12, 2017 also whoever wrote this wiki https://github.com/causefx/Organizr/wiki/Caddy-Installation , its quite wrong
Swynol 375 Posted July 12, 2017 Posted July 12, 2017 (edited) what did you name the caddy file? mine is just called caddyfile placed in the same place as caddy.exe also do you have the php files installed? you should have a folder in caddy called php. and then edit the php.ini file, search for ;extension=php_pdo_sqlite.dll ;extension=php_sqlite3.dll ;extension=php_openssl.dll ;extension=php_curl.dll and then remove the ; from the front of them i think I've seen that error before when PHP wasnt configured or in the correct location EDIT: are you running caddy by just clicking on the .exe? if so also make sure you right click and run as administrator. had some issue with ports not binding when not running as admin Edited July 12, 2017 by Swynol
Spaceboy 2573 Posted July 13, 2017 Posted July 13, 2017 what did you name the caddy file? mine is just called caddyfile placed in the same place as caddy.exe also do you have the php files installed? you should have a folder in caddy called php. and then edit the php.ini file, search for ;extension=php_pdo_sqlite.dll ;extension=php_sqlite3.dll ;extension=php_openssl.dll ;extension=php_curl.dll and then remove the ; from the front of them i think I've seen that error before when PHP wasnt configured or in the correct location EDIT: are you running caddy by just clicking on the .exe? if so also make sure you right click and run as administrator. had some issue with ports not binding when not running as admin i've tried just caddyfile and a .caddyfile that i've called with the correct arguments. caddy starts both ways and i can see the contents of index.html in www. php is in a subfolder called php. i renamed php dev.ini to php.ini and uncommented those lines. i also had to uncomment the line that tells php where the ext folder is as i initially installed php in c:\ and it was still looking for the extensions in c:\php\ext. i was getting errors when launching php for this but after inserting this line they went away. i've tried starting caddy using a service via nssm and via the command prompt with and without administrator privileges. i followed the caddy / organizr guide i referenced to the letter and it all works with the exception of organizr. the only thing i have changed is the caddyfile you've included above. i still can't see why i can't get caddy to start using your caddyfile. any further help gratefully received!
Spaceboy 2573 Posted July 13, 2017 Posted July 13, 2017 I think there was an issue with copying and pasting into the caddy file. I'm rewriting by hand but just come up against the acme limit!
Spaceboy 2573 Posted July 13, 2017 Posted July 13, 2017 what did you name the caddy file? mine is just called caddyfile placed in the same place as caddy.exe also do you have the php files installed? you should have a folder in caddy called php. and then edit the php.ini file, search for ;extension=php_pdo_sqlite.dll ;extension=php_sqlite3.dll ;extension=php_openssl.dll ;extension=php_curl.dll and then remove the ; from the front of them i think I've seen that error before when PHP wasnt configured or in the correct location EDIT: are you running caddy by just clicking on the .exe? if so also make sure you right click and run as administrator. had some issue with ports not binding when not running as admin ok, i got caddy to run with your caddyfile and it runs but organizr still isnt working so back to square one. i can see caddy and cgi /fastcgi processes in task manager so I think this means both php and caddy are running. what else can I try?
PrincessClevage 175 Posted July 14, 2017 Posted July 14, 2017 Is this stand alone or available in the Emby server plugin catalogue?
CBers 7554 Posted July 14, 2017 Posted July 14, 2017 Is this stand alone or available in the Emby server plugin catalogue? Standalone, as is Ombi.
Swynol 375 Posted July 14, 2017 Posted July 14, 2017 ok, i got caddy to run with your caddyfile and it runs but organizr still isnt working so back to square one. i can see caddy and cgi /fastcgi processes in task manager so I think this means both php and caddy are running. what else can I try? Strange. are you still getting a 404 when trying to go to https://mydomain.com/organizr? if you can take a screen shot of your caddy folder and inside the www folder and post here. Also strange that you hit the acme limit, as once you have your cert it saves them and is valid for 90 days. you would only usually hit the limit if its trying to get a new cert again. the limit is 5 in 1 hour. another option is i zip my caddy folder up and send it to you to extract and see if that works. Is this stand alone or available in the Emby server plugin catalogue? standalone.
Spaceboy 2573 Posted July 14, 2017 Posted July 14, 2017 (edited) Strange. are you still getting a 404 when trying to go to https://mydomain.com/organizr? if you can take a screen shot of your caddy folder and inside the www folder and post here. Also strange that you hit the acme limit, as once you have your cert it saves them and is valid for 90 days. you would only usually hit the limit if its trying to get a new cert again. the limit is 5 in 1 hour. yep, still getting the 404, every other service is working. the acme error was due to my mistyping of the url for organizr... caddy folder www folder and here is my caddyfile for good measure. my domain.org { ext .html .htm .php root /caddy/www gzip proxy /radarr localhost:7878 { transparent } proxy /sonarr localhost:8989 { transparent } proxy /emby localhost:8096 { transparent websocket } proxy /ombi localhost:3579 { transparent } proxy /headphones localhost:8181 { transparent } proxy /sabnzbd localhost:8087 { transparent websocket } } https://mydomain.org/organizr { ext .html .htm .php root /caddy/www/organizr startup /caddy/php/php-cgi -b 127.0.0.1:9000 & fastcgi /localhost:9000 php gzip } Edited July 14, 2017 by Spaceboy
Spaceboy 2573 Posted July 14, 2017 Posted July 14, 2017 here is my caddy folder zipped up. all domain info removed. feel free to tell me why i'm an idiot https://1drv.ms/u/s!AqYdKMNjJrrjnokWlMxxGnJaHNfQ5Q
Swynol 375 Posted July 14, 2017 Posted July 14, 2017 everything is almost exactly like mine except in your caddy file you have fastcgi /localhost:9000 php in mine i have fastcgi / localhost:9000 php notice the space after / 1
Spaceboy 2573 Posted July 14, 2017 Posted July 14, 2017 hurrah, something seems to be working! let me try organizr for a bit. I still have other questions on caddy set up though!
Swynol 375 Posted July 14, 2017 Posted July 14, 2017 awesome. guessing it was something to do with that slash. It should ask you where to put the database file. the default is fine but i tend to prefer to put it in the organizr folder to keep everything tidy. Next we can look at the security settings.
Spaceboy 2573 Posted July 15, 2017 Posted July 15, 2017 ok, my final issues: even if i'm not signed in to organizr, if i go to domain/organizr/index.php then i can see the organizr buttons at the top of the screen but i can also see all the tabs down the left of the screen and each of them can be opened bringing me to that service's login screen. i kind of expected all of this to be hidden until ive logged into organizr. i guess similarly, even if i've logged out of organizr, but i didnt log out of one of the services, say sonarr, then i can still go to the sonarr tab and keep using sonarr. i know i'm still logged into sonarr but again as i'm accessing it through organizr then i expected it to be hidden behind a login screen. This second issue isnt really that important but the first is advertising your services externally which doesnt seem like a great idea to me? perhaps there is a simple setting that changes this but i couldnt see anything. there does seem to be a help function in the screenshots but i cant see this. just trying to log on to organizr now i'm getting 502 bad gateway. there was a fix for that on the installation page so i'll try that previously when i could access organizr and went to domain/organizr i got a sort of broken login screen, accessing via domain/organizr/index/php is fine. and i couldnt get everything in the homepage to work, emby, sab and the speed test were fine but the dropdown for music, movies and tv which i guess are headphones, radarr and sonarr respectively didnt seem to do anything. lets take the caddy chat back here https://emby.media/community/index.php?/topic/48718-how-to-renew-ssl-certs-on-windows/&do=findComment&comment=467229 rather than cluttering up organizr's thread and there are some other interested readers there too
CBers 7554 Posted July 15, 2017 Posted July 15, 2017 ok, my final issues: even if i'm not signed in to organizr, if i go to domain/organizr/index.php then i can see the organizr buttons at the top of the screen but i can also see all the tabs down the left of the screen and each of them can be opened bringing me to that service's login screen. i kind of expected all of this to be hidden until ive logged into organizr. How are your tabs setup? Are they USER access, or USER and GUEST? 1
