Cerothen 98 Posted April 6, 2017 Posted April 6, 2017 v1.30 brings Emby to the Organizr homepage! Let me know if music doesn't work, I didn't have any music on my server so I didn't know what the item type was. https://github.com/causefx/Organizr/pull/230
sh0rty 727 Posted April 6, 2017 Posted April 6, 2017 (edited) Let me know if music doesn't work, I didn't have any music on my server so I didn't know what the item type was. https://github.com/causefx/Organizr/pull/230 Music doesn't work (at least on my installation) What info do you need to know exactly? Edit: @@Luke Item type of music please? Edited April 6, 2017 by shorty1483
Cerothen 98 Posted April 6, 2017 Posted April 6, 2017 Music doesn't work (at least on my installation) What info do you need to know exactly? Edit: @@Luke Item type of music please? Resolved it, it was in there as "Music" when it should have been "MusicAlbum". Next pull request should also allow users to authenticate with their Emby credentials if the usernames match. https://github.com/causefx/Organizr/pull/235 1
Cerothen 98 Posted April 8, 2017 Posted April 8, 2017 Organize 1.31 live now. Recently added music now works. Further emby integration by allowing users to log in and create accounts using their emby credentials. Ldap user log in and ftp user log in. There are other things as well, I focused on contributing emby integration and creating the support for back end authentication. 2
schmitty 66 Posted April 10, 2017 Posted April 10, 2017 Is it possible to add Ombi to Organizr? Sent from my iPhone using Tapatalk
schmitty 66 Posted April 10, 2017 Posted April 10, 2017 Yes. I haven't seen it in the homepage settings Sent from my iPhone using Tapatalk
CBers 7554 Posted April 10, 2017 Posted April 10, 2017 I haven't seen it in the homepage settings Oh you mean adding it to the HOMEPAGE ?? No, don't think it's an option as yet. I thought you meant add a tab for Ombi.
schmitty 66 Posted April 10, 2017 Posted April 10, 2017 I thought you had to add it to the homepage first, to add a tab Sent from my iPhone using Tapatalk
CBers 7554 Posted April 10, 2017 Posted April 10, 2017 I thought you had to add it to the homepage first, to add a tab No, just add a tab in Settings, Edit Tabs.
schmitty 66 Posted April 10, 2017 Posted April 10, 2017 I had trouble with that. I created a tab first, saved it, it said saved... then disappeared Sent from my iPhone using Tapatalk
CBers 7554 Posted April 10, 2017 Posted April 10, 2017 Strange. You could ask on @@causefx's Gitter channel: https://gitter.im/Organizrr/Lobby 1
Animosity022 6 Posted April 10, 2017 Posted April 10, 2017 Just installed and seems to be working well. I really like it and was looking for something like this.
dosullivan84 1 Posted April 17, 2017 Posted April 17, 2017 I'm a complete novice with this, I'm trying to follow the instructions on your wiki page but Im abit lost do I have to Run Nginx as a service? If so I tried doing part 2 but I think I've gone wrong and now I can't redo part 2 so if I do need to do part 2 how do I start over and uninstall Nginx?
CBers 7554 Posted April 17, 2017 Posted April 17, 2017 I'm a complete novice with this, I'm trying to follow the instructions on your wiki page but Im abit lost do I have to Run Nginx as a service? If so I tried doing part 2 but I think I've gone wrong and now I can't redo part 2 so if I do need to do part 2 how do I start over and uninstall Nginx? I can't remember what part 2 is, but you can always run "NSSM REMOVE NGINX", delete the NGINX folder and start again. Or, you could ask on @@causefx's Gitter channel: https://gitter.im/Organizrr/Lobby
dosullivan84 1 Posted April 17, 2017 Posted April 17, 2017 (edited) I can't remember what part 2 is, but you can always run "NSSM REMOVE NGINX", delete the NGINX folder and start again. Or, you could ask on @@causefx's Gitter channel: https://gitter.im/Organizrr/Lobby Thanks, part 2 is Running Nginx as a service. OK so I've done that and reinstalled Nginx but when I get to right click and restart Nginx service I'm getting an error, that it can't find it, so I'm not sure what to do after that Edited April 17, 2017 by dosullivan84
Swynol 375 Posted April 21, 2017 Posted April 21, 2017 @dosullican84 can you post your NGINX config (remove the domain names)
schmitty 66 Posted April 23, 2017 Posted April 23, 2017 @@dosullivan84 try following these instructions https://forums.ombi.io/viewtopic.php?f=9&t=25
homerfan 3 Posted April 25, 2017 Posted April 25, 2017 awesome changed all my hide headers and all is working This may be to much to ask, but would you mind sharing your updated nginx.conf file? This has been my first crack at setting all of this up and your example config file have been SOOO helpful. Best, homerfan
Swynol 375 Posted April 27, 2017 Posted April 27, 2017 (edited) @@homerfan ye no worries, this is my server block just for Organizr using my own certs and forcing HTTPS connection ## Organizr ## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name home.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { root html; index index.php index.html index.htm; } location ~ \.php$ { root html; fastcgi_pass 127.0.0.1:9000; fastcgi_index index.php; fastcgi_param SCRIPT_FILENAME C:/nginxlion/html$fastcgi_script_name; include fastcgi_params; } } here is my whole NGINX config. Looks more complicated than it is but its just broken down into different server blocks. if you want iframe to work i had to add these lines to the services which wouldn't work by default. You have to list all the subdomains, so for me its around 10 or so subdomains. add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk subdomain.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE #user nobody; # multiple workers works ! worker_processes 2; events { worker_connections 8192; } http { #include /nginx/conf/naxsi_core.rules; include mime.types; default_type application/octet-stream; sendfile off; server_names_hash_bucket_size 128; map_hash_bucket_size 64; ## Start: Timeouts ## client_body_timeout 10; client_header_timeout 10; keepalive_timeout 30; send_timeout 10; keepalive_requests 10; ## End: Timeouts ## #gzip on; ## Organizr ## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name home.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { root html; index index.php index.html index.htm; } location ~ \.php$ { root html; fastcgi_pass 127.0.0.1:9000; fastcgi_index index.php; fastcgi_param SCRIPT_FILENAME C:/nginxlion/html$fastcgi_script_name; include fastcgi_params; } } ##EMBY Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name emby.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://192.168.10.10:8096; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk"; } } ##Sonarr Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name sonarr.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:8989; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } ##Radarr Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name radarr.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:7878; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } ##NZB Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name nzb.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:6792; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } ##Plex Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name plex.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:32400; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; #Next three lines allow websockets proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } ##Unifi Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name unifi.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass https://192.168.10.10:8443; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk unifi.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE } } ##Unifi Guest Portal## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name guest.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass https://127.0.0.1:8843; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk subdomain.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE } location /ws/ { proxy_pass http://127.0.0.1:8843/ws/; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; } } ##CCTV Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name cctv.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://192.168.60.10:8099; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk subdomain.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE } } ##HTPC Manager Server## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name htpc.secretdomain.co.uk; #path to your SSL files, nginx must now handle all of the SSL, not each individual server #to your backend is regular HTTP its assumed safe, its on your local network or the same PC as nginx ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:8097; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk unifi.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE } } ##Heating## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name heat.secretdomain.co.uk; #path to your SSL files, nginx must now handle all of the SSL, not each individual server #to your backend is regular HTTP its assumed safe, its on your local network or the same PC as nginx ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://192.168.10.91:80; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; } } ##uTorrent## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name utorrent.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:7070/; proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade; proxy_set_header Connection "upgrade"; proxy_redirect off; proxy_set_header Host $host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_pass_header Set-Cookie; proxy_pass_header P3P; } } ##HDD Temps## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name update.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://127.0.0.1:8929/status; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk unifi.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE } } #PRTG Stats Map## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name stats.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { proxy_pass http://192.168.10.10:8081/; proxy_hide_header X-Powered-By; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; proxy_set_header X-Real-IP $remote_addr; proxy_set_header Host $host; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; add_header X-Frame-Options "SAMEORIGIN" always; add_header Content-Security-Policy "frame-ancestors secretdomain.co.uk unifi.secretdomain.co.uk"; #LIST ALL SUBDOMAINS HERE } location /public/stats { proxy_pass http://192.168.10.10:8081/public/mapshow.htm?id=2069&mapid=1; } location /public/status { proxy_pass http://192.168.10.10:8081/public/mapshow.htm?id=2155&mapid=1EC016F4-43DC-44FD-A4F1-E10033FBD0CB; } } #Webpage## server { listen [::]:80; listen 80; listen [::]:443 ssl; listen 443 ssl; server_name www.secretdomain.co.uk; ssl_session_timeout 30m; ssl_protocols TLSv1.2 TLSv1.1 TLSv1; ssl_certificate SSL/cert.pem; ssl_certificate_key SSL/private.key; ssl_session_cache shared:SSL:10m; if ($scheme = http) { return 301 https://$server_name$request_uri; } location / { root html; index index.html index.htm; } } } Edited April 27, 2017 by Swynol 1
Davide 9 Posted May 11, 2017 Posted May 11, 2017 I followed the Github guide to install it on Windows... I installed Nginx and PHP, copied the Organizr files into "C:\nginx\html\organizr", but I cannot access to Organizr.
CBers 7554 Posted May 11, 2017 Posted May 11, 2017 I followed the Github guide to install it on Windows... I installed Nginx and PHP, copied the Organizr files into "C:\nginx\html\organizr", but I cannot access to Organizr. Open a browser and goto: http://ipaddress/index.php
Davide 9 Posted May 11, 2017 Posted May 11, 2017 At http://ipaddress/index.php I get the error "404 Not Found"
CBers 7554 Posted May 11, 2017 Posted May 11, 2017 At http://ipaddress/index.php I get the error "404 Not Found" You did substitute ipaddress for the IP address of the PC that Organizr is running on didn't you
Davide 9 Posted May 11, 2017 Posted May 11, 2017 You did substitute ipaddress for the IP address of the PC that Organizr is running on didn't you Sure, I have substitute ipaddress with IP address of the PC... and I get the error
