Nathanio 35 Posted March 6, 2017 Posted March 6, 2017 (edited) Hi Guys, Come across a simple SD channel recording that won't playback via webapp for some reason. Here is the transcoding log: http://slinky:8096/emby/videos/4b94fd45bde46f511eb90f251f5b1078/hls1/main/0.ts?DeviceId=5548921b98fd20ac8a1e0cfbd6c0cb49&MediaSourceId=4b94fd45bde46f511eb90f251f5b1078&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=7872001&AudioBitrate=128000&Level=51&Profile=high&PlaySessionId=6d5555e403e74971a812dcd263a61a2a&api_key=160878da397f47b1aea21642d4601711&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=0fb8c95c81acd453c59d8ed861205bb3&RequireAvc=true {"Protocol":"File","Id":"4b94fd45bde46f511eb90f251f5b1078","Path":"G:\\ServerFolders\\EmbyTV\\Series\\Combat Dealers\\Season 2\\Combat Dealers S02E03 Australia.mp4","Type":"Default","Container":"mp4","Name":"SD/MPEG2VIDEO/MP3","IsRemote":false,"ETag":"0fb8c95c81acd453c59d8ed861205bb3","RunTimeTicks":37784879104,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"VideoType":"VideoFile","MediaStreams":[{"Codec":"mpeg2video","CodecTag":"mp4v","Language":"und","TimeBase":"1/90000","CodecTimeBase":"1/50","IsInterlaced":false,"BitRate":1722172,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":576,"Width":544,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Main","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp3","CodecTag":"mp4a","Language":"und","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"Und MP3 stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":128000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":1854548,"RequiredHttpHeaders":{}} C:\Users\Administrator\AppData\Roaming\Emby-Server\ffmpeg\20160410\ffmpeg.exe -f mp4 -codec:0 mpeg2video -codec:1 mp3 -i file:"G:\ServerFolders\EmbyTV\Series\Combat Dealers\Season 2\Combat Dealers S02E03 Australia.mp4" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 1722172 -bufsize 3444344 -vsync -1 -profile:v high -level 4.1 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -codec:a:0 copy -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "S:\Transcode\transcoding-temp\61ef25e4d2dedfeb48185c2f87a0cab1.m3u8" -y "S:\Transcode\transcoding-temp\61ef25e4d2dedfeb48185c2f87a0cab1%d.ts" ffmpeg version N-79277-g0c90b2e Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.3.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 20.100 / 55. 20.100 libavcodec 57. 34.100 / 57. 34.100 libavformat 57. 32.100 / 57. 32.100 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 41.100 / 6. 41.100 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:G:\ServerFolders\EmbyTV\Series\Combat Dealers\Season 2\Combat Dealers S02E03 Australia.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2mp41 encoder : Lavf57.32.100 Duration: 01:02:58.49, start: 0.000000, bitrate: 1854 kb/s Stream #0:0(und): Video: mpeg2video (Main) (mp4v / 0x7634706D), yuv420p(tv), 544x576 [SAR 32:17 DAR 16:9], 1722 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc (default) Metadata: handler_name : VideoHandler Stream #0:1(und): Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, s16p, 128 kb/s (default) Metadata: handler_name : SoundHandler [libx264 @ 0000000002a421c0] using SAR=1/1 [libx264 @ 0000000002a421c0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0000000002a421c0] profile Main, level 4.1 [libx264 @ 0000000002a421c0] 264 - core 148 r2665 a01e339 - H.264/MPEG-4 AVC codec - Copyleft 2003-2016 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=1722 vbv_bufsize=3444 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 Output #0, segment, to 'S:\Transcode\transcoding-temp\61ef25e4d2dedfeb48185c2f87a0cab1%d.ts': Metadata: encoder : Lavf57.32.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1024x576 [SAR 1:1 DAR 16:9], q=-1--1, max. 1722 kb/s, 25 fps, 90k tbn, 25 tbc (default) Metadata: encoder : Lavc57.34.100 libx264 Side data: cpb: bitrate max/min/avg: 1722000/0/0 buffer size: 3444000 vbv_delay: -1 Stream #0:1: Audio: mp3 (mp4a / 0x6134706D), 48000 Hz, stereo, 128 kb/s (default) Stream mapping: Stream #0:0 -> #0:0 (mpeg2video (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 139 fps=0.0 q=28.0 size=N/A time=00:00:07.36 bitrate=N/A speed=14.7x frame= 339 fps=338 q=28.0 size=N/A time=00:00:15.36 bitrate=N/A speed=15.3x frame= 546 fps=363 q=28.0 size=N/A time=00:00:23.64 bitrate=N/A speed=15.7x frame= 789 fps=393 q=28.0 size=N/A time=00:00:33.36 bitrate=N/A speed=16.6x frame= 1002 fps=399 q=28.0 size=N/A time=00:00:41.88 bitrate=N/A speed=16.7x frame= 1227 fps=408 q=28.0 size=N/A time=00:00:50.88 bitrate=N/A speed=16.9x frame= 1452 fps=414 q=28.0 size=N/A time=00:00:59.88 bitrate=N/A speed=17.1x frame= 1760 fps=439 q=28.0 size=N/A time=00:01:12.21 bitrate=N/A speed= 18x frame= 2033 fps=450 q=28.0 size=N/A time=00:01:23.13 bitrate=N/A speed=18.4x frame= 2286 fps=456 q=28.0 size=N/A time=00:01:33.24 bitrate=N/A speed=18.6x frame= 2517 fps=456 q=28.0 size=N/A time=00:01:42.48 bitrate=N/A speed=18.6x frame= 2734 fps=454 q=31.0 size=N/A time=00:01:51.16 bitrate=N/A speed=18.5x frame= 2930 fps=449 q=28.0 size=N/A time=00:01:59.01 bitrate=N/A speed=18.3x frame= 3167 fps=451 q=28.0 size=N/A time=00:02:08.49 bitrate=N/A speed=18.3x frame= 3272 fps=435 q=28.0 size=N/A time=00:02:12.69 bitrate=N/A speed=17.6x frame= 3438 fps=428 q=32.0 size=N/A time=00:02:19.32 bitrate=N/A speed=17.4x frame= 3647 fps=428 q=30.0 size=N/A time=00:02:27.69 bitrate=N/A speed=17.3x frame= 3866 fps=428 q=28.0 size=N/A time=00:02:36.45 bitrate=N/A speed=17.3x frame= 4077 fps=428 q=30.0 size=N/A time=00:02:44.88 bitrate=N/A speed=17.3x frame= 4282 fps=427 q=29.0 size=N/A time=00:02:53.08 bitrate=N/A speed=17.3x frame= 4427 fps=420 q=30.0 size=N/A time=00:02:58.89 bitrate=N/A speed= 17x frame= 4533 fps=416 q=-1.0 Lsize=N/A time=00:03:03.09 bitrate=N/A speed=16.8x video:32373kB audio:2861kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0000000002a421c0] frame I:177 Avg QP:22.10 size: 35036 [libx264 @ 0000000002a421c0] frame P:2096 Avg QP:25.30 size: 10348 [libx264 @ 0000000002a421c0] frame B:2260 Avg QP:28.31 size: 2327 [libx264 @ 0000000002a421c0] consecutive B-frames: 24.1% 24.0% 12.5% 39.4% [libx264 @ 0000000002a421c0] mb I I16..4: 36.5% 0.0% 63.5% [libx264 @ 0000000002a421c0] mb P I16..4: 26.2% 0.0% 0.0% P16..4: 40.6% 0.0% 0.0% 0.0% 0.0% skip:33.2% Plays back fine on android and theatre clients. Media info: Media Info Video CodecMPEG2VIDEOCodec tagmp4vProfileMainLevel8Resolution544x576Aspect ratio16:9AnamorphicNoInterlacedNoFramerate25Bitrate1722 kbpsPixel formatyuv420pRef frames1 Audio LanguageundCodecMP3Codec tagmp4aLayoutstereoChannels2 chBitrate128 kbpsSample rate48000 HzDefaultYesTitleUnd MP3 stereo Default Containermp4 PathG:\ServerFolders\EmbyTV\Series\Combat Dealers\Season 2\Combat Dealers S02E03 Australia.mp4 Not sure why it's struggling with it. Plays back HD channel recordings fine. Causing FFMPEG to run to 100% on the server when it starts. I get the programme background but no video starts. EDIT: Server Version 3.2.5.7 beta and Chrome. Plays video back in edge but no audio. Edited March 6, 2017 by Nathanio
Luke 42241 Posted March 6, 2017 Posted March 6, 2017 It looks like you've enabled recording to mp4 while preserving original video. mpeg2video inside an mp4 container is not very common. i wonder if there's just some kind of issue that ffmpeg might be having with it. Can you either allow video conversion or switch the container to mkv? See if that makes a difference. thanks.
Nathanio 35 Posted March 6, 2017 Author Posted March 6, 2017 Hi Luke, I think I selected the preserve audio and video when we had some issues with recording a while ago. I'll disable and check again. I'll leave as mp4 for the time being Thanks
Nathanio 35 Posted March 16, 2017 Author Posted March 16, 2017 Thanks for the tip @@Luke, that seemed to work great
