PVTD 37 Posted March 6, 2017 Posted March 6, 2017 So I ran a new server with new copy of Windows Server 2012 R2. First all my data was on my local server, now I moved the data to another server. Problem is, I could not figure out the permission problems I was having, Emby did NOT want to find ANY remote device. Yet it has admin rights, runnin on the admin account with admin permissions. I know it's not optimal, but I am out of idea's... Emby Service Permission: Yes, I even tried the second option to run with the local account... Emby Error log: *** Error Report ***Version: 3.2.5.0Command line: C:\Users\Administrator\AppData\Roaming\Emby-Server\system\MediaBrowser.ServerApplication.exe -serviceOperating system: Microsoft Windows NT 6.2.9200.064-Bit OS: True64-Bit Process: TrueProcessor count: 24Program data path: C:\Users\Administrator\AppData\Roaming\Emby-ServerApplication directory: C:\Users\Administrator\AppData\Roaming\Emby-Server\systemSystem.ArgumentException: The UNC path should be of the form \\server\share.at System.IO.LongPathHelper.Normalize(String path, UInt32 maxPathLength, Boolean checkInvalidCharacters, Boolean expandShortPaths)at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)at System.IO.Path.GetFullPathInternal(String path)at System.IO.DirectoryInfo.Init(String path, Boolean checkHost)at Emby.Common.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive)at MediaBrowser.Api.EnvironmentService.GetFileSystemEntries(GetDirectoryContents request)at MediaBrowser.Api.EnvironmentService.Get(GetDirectoryContents request)at Emby.Server.Implementations.Services.ServiceExecGeneral.d__2.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Emby.Server.Implementations.Services.ServiceController.d__13.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Emby.Server.Implementations.Services.ServiceHandler.d__15.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Emby.Server.Implementations.HttpServer.HttpListenerHost.d__74.MoveNext()System.ArgumentExceptionat System.IO.LongPathHelper.Normalize(String path, UInt32 maxPathLength, Boolean checkInvalidCharacters, Boolean expandShortPaths)at System.IO.Path.NormalizePath(String path, Boolean fullCheck, Int32 maxPathLength, Boolean expandShortPaths)at System.IO.Path.GetFullPathInternal(String path)at System.IO.DirectoryInfo.Init(String path, Boolean checkHost)at Emby.Common.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive)at MediaBrowser.Api.EnvironmentService.GetFileSystemEntries(GetDirectoryContents request)at MediaBrowser.Api.EnvironmentService.Get(GetDirectoryContents request)at Emby.Server.Implementations.Services.ServiceExecGeneral.d__2.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Emby.Server.Implementations.Services.ServiceController.d__13.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Emby.Server.Implementations.Services.ServiceHandler.d__15.MoveNext()--- End of stack trace from previous location where exception was thrown ---at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)at Emby.Server.Implementations.HttpServer.HttpListenerHost.d__74.MoveNext()2017-03-06 15:42:38.9882 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/Environment/ParentPath?path=%5C%5CAstrid%5C2017-03-06 15:42:38.9882 Info HttpServer: HTTP Response 400 to ::1. Time: 5ms. http://localhost:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%5C%5CAstrid%5C2017-03-06 15:42:39.1283 Info HttpServer: HTTP GET http://localhost:8096/emby/Environment/Drives. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:47.0) Gecko/20100101 Firefox/47.0 Light/47.0 2017-03-06 15:42:39.1283 Info HttpServer: HTTP Response 200 to ::1. Time: 2ms. http://localhost:8096/emby/Environment/Drives2017-03-06 15:42:40.7586 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:40.7586 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:42.7432 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:42.7432 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:45.7376 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:45.7376 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:47.7462 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:47.7462 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:50.7497 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:50.7527 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:52.7663 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:52.7693 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:55.7478 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:55.7478 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:57.7514 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:42:57.7554 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:42:58.4729 Debug LibraryMonitor: Changed detected of type Changed to Z:\SERIES\The Good Place\Season 12017-03-06 15:42:58.4729 Debug LibraryMonitor: New file refresher created for Z:\SERIES\The Good Place\Season 12017-03-06 15:43:00.7398 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:00.7398 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:02.7384 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:02.7384 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:05.7370 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:05.7370 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:07.7396 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:07.7396 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:10.7421 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:10.7421 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:12.7517 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:12.7558 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:15.7493 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:15.7533 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:17.7489 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:17.7529 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 4ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:20.7413 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:20.7413 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:22.7469 Info HttpServer: HTTP GET http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36 2017-03-06 15:43:22.7469 Info HttpServer: HTTP Response 200 to 192.168.0.149. Time: 3ms. http://192.168.0.222:8096/emby/ScheduledTasks?IsEnabled=true2017-03-06 15:43:23.8008 Info HttpServer: HTTP GET http://localhost:8096/emby/Environment/DirectoryContents?includeDirectories=true&path=%5C%5C169.254.121.178%5C. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:47.0) Gecko/20100101 Firefox/47.0 Light/47.0 2017-03-06 15:43:23.8008 Info HttpServer: HTTP GET http://localhost:8096/emby/Environment/ParentPath?path=%5C%5C169.254.121.178%5C. UserAgent: Mozilla/5.0 (Windows NT 6.3; Win64; x64; rv:47.0) Gecko/20100101 Firefox/47.0 Light/47.0 2017-03-06 15:43:23.8008 Error HttpServer: Error processing request Windows can successfully access all ways to the drives and have FULL permission. If it's by IP or by \\server\, even as remote drive and remote folder. I can delete, move, copy and write all I want. BTW, 169.254.121.178 is the direct IP with the 10Gb card. They are connected directly to each other. While 192.168.0.149 is the same server, but by classic LAN to network.
Solution PVTD 37 Posted March 6, 2017 Author Solution Posted March 6, 2017 Well I hate this... As soon I write this post, it starts to work a bit more (I have to put the extact share folder location as it doesn't want to browse). I did not change anything, I just kept trying the same thing hoping it was a browser glitch, but no, Windows decided to make me run 10km more for nothing... It seems to work now.
Luke 42197 Posted March 6, 2017 Posted March 6, 2017 Since you are using the windows service just be aware, things are almost always simpler when using the tray icon.
PVTD 37 Posted March 6, 2017 Author Posted March 6, 2017 Since you are using the windows service just be aware, things are almost always simpler when using the tray icon. I do not like the Service either, but I use it in case the server reboots and I can't access it to log in. The tray version requires you to log in as soon the server boots up (even with auto sign it, it still waits for user interaction :/)
ebr 16309 Posted March 6, 2017 Posted March 6, 2017 (even with auto sign it, it still waits for user interaction :/) I run the tray app and automatically log in and automatically start the server. No interaction is required.
