mekwall 10 Posted April 3, 2017 Posted April 3, 2017 (edited) That file is not HDR, if it were you'd see 4:4:4 for the Chroma Subsampling, and AT LEAST 12 bit for the Bit Depth 4:2:0 is SDR. As for the grey bars you'll probably need to fix the color range either on the TV or the device you're playing to it with the correct range so that your blacks are correct. You're wrong. It is 10-bit SMPTE 2084 HDR format (aka HDR10) which uses Rec. 2020 color space (4:2:0 chroma subsampling is allowed). My TV recognize the source as HDR as well. https://en.wikipedia.org/wiki/High-dynamic-range_video#HDR10 Edited April 3, 2017 by mekwall
ebr 16338 Posted April 3, 2017 Posted April 3, 2017 If I try to install the beta version, The app on the tv sais it doesn't support it. So I can't install it. What app says it doesn't support what?
Samenluisteren 0 Posted April 3, 2017 Posted April 3, 2017 (edited) Sorry, I thought I was clear. The Emby android TV Beta app sais this tv isn't compatible to install the beta app. Edited April 3, 2017 by Omeniel
Samenluisteren 0 Posted April 3, 2017 Posted April 3, 2017 (edited) What app says it doesn't support what? Sorry, I thought I was clear. The Emby android TV Beta app sais this tv isn't compatible to install the beta app. I Will take a screenshot tonight. Edited April 3, 2017 by Omeniel
nague 5 Posted November 29, 2021 Posted November 29, 2021 Is the workarround pointed in this thread for Sony Android TV still working in the 2021 app ? Currently, Emby is not transcoding DTS in DD. I only get a PCM stereo signal from ARC.
ebr 16338 Posted November 29, 2021 Posted November 29, 2021 28 minutes ago, nague said: Is the workarround pointed in this thread for Sony Android TV still working in the 2021 app ? Currently, Emby is not transcoding DTS in DD. I only get a PCM stereo signal from ARC. Hi. This is a really old thread. Exactly what issue are you having and what version of the app do you have?
nague 5 Posted November 30, 2021 Posted November 30, 2021 Thx @ebr for your quick answer. Actually my issue is the same as describe here, but I found the solution in a more recent thread :
