DParsons 4 Posted March 3, 2017 Posted March 3, 2017 A few days ago my liveTV module on my Emby server became blank with nothing being displayed. The guide still shows up but empty of any data and also channels still show. I am able to still stream livetv both locally and remotely by using the channels module, but without guide info. I've tried uninstalling reinstalling the NextPVR addon in Emby but livetv continues to be empty. emby server logs 03032017.7z
Luke 42239 Posted March 3, 2017 Posted March 3, 2017 Hi, there are some errors coming from the next pvr api, that might be the reason 2017-03-03 13:27:28.8907 Error HttpClient: Error getting response from http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=00930a92e67e4fc0b8af92ff43aa9c8f *** Error Report *** Version: 3.2.5.0 System.Net.WebException: The remote server returned an error: (500) Internal Server Error. I would ensure that you have a fully functional setup on the next pvr side. Let us know if this helps. Thanks.
DParsons 4 Posted March 4, 2017 Author Posted March 4, 2017 NextPVR is operating normally. I can use it with no problems, I wonder what else might be happening. It has been fine and it just started a day or two ago and there has been no changes that I'm aware of in the last couple of days. I might try uninstalling Emby and resetting it up completely again. Reinstalling the NextPVR addon had no affect.
Luke 42239 Posted March 4, 2017 Posted March 4, 2017 Again it is the next pvr web service sending back a 500 error code, I don't think you need to reinstall Emby. What I would suggest doing is checking next pvr logs to see if there's anything useful there. There must be some logging to coincide with that 500 response code.
DParsons 4 Posted March 4, 2017 Author Posted March 4, 2017 Thanks Luke, I'll see if Sub can see any issues on the NextPVR logs.
vaise 340 Posted March 4, 2017 Posted March 4, 2017 Have you tried rebooting your system - or restarting the NextPVR recording service (right click it in the bottom right and restart). That will re-start the NextPVR web service then. You can have nextPVR working fine from a windows gui perspective, and all the normal NextPVR stuff is working, but it is not offering up its stuff to the web. You can check this on http://localhost:8866/index.html (I think it is index, I cant remember off the top of my head and not at home currently to check). There are other reported issues such as this in this forum. Hope that helps.
DParsons 4 Posted March 4, 2017 Author Posted March 4, 2017 Thanks, I have. Even tried reinstalling both and nothing will work. I checked the NextPVR web client and it is fully functional, just Emby will not display the guide. It will still steam so it is mostly working just no epg so I can't schedule recordings. I can watch livetv and that is my only option at the moment.
vaise 340 Posted March 5, 2017 Posted March 5, 2017 I schedule my recordings from the windows nextPVR gui myself (at least until emby is proven good for the HDHR old style devices). I find the nextPVR windows gui the best currently. I just check every week, or when I have time, then use the CTRL > key combination to go to each day, always in the 6:30 PM timeframe which shows it all on one page. I then make sure our stuff is there (it is mostly series recordings), nd add any one-off's. So i have never used the emby guide in anger, but I have recorded the odd one from the roku guide on the beta every now and again. I only have 12 channels in the list do I dont even have to page up/down. This is the first time I have heard about emby not working when the nextPVR web guide is fully working.
DParsons 4 Posted March 5, 2017 Author Posted March 5, 2017 @@Luke I have submitted the nextpvr logs to them but it was a day after the event and they said the logs didn't go back far enough to show the error. I'll post some new logs as soon as possible. I was hoping they could look at the logs I posted here, I provided the link to this post but I'm not sure if they can see them. @@vaise It has worked perfectly for a long time. Emby is not my main method of scheduling recordings and I use it mostly remotely, KODI is my main media center on my HTPC and the livetv/PVR function is my main interest in Emby. It has been an exceptional program and this must be some sort of odd glitch that I'm hoping can be sorted out soon.
DParsons 4 Posted March 5, 2017 Author Posted March 5, 2017 Immediately after making this post I checked Emby and both the local and remote/android apps are working again. Livetv is the same as it has always been and I've scheduled recordings with the web and android apps. I'm posting logs that I just created after it started to work again to see if you all can see any obvious reasons for this. It went off and stayed that way for me for approximately the last three days and just this morning is back to normal. emby server logs.7z
Luke 42239 Posted March 5, 2017 Posted March 5, 2017 Now the next pvr urls are no longer returning an error.
emveepee 133 Posted March 5, 2017 Posted March 5, 2017 (edited) Note that 500 is a valid response to some NEWA JSON calls requiring special handling. In this case the call that was failing here was not the guide listing info. What I saw on the EPG side of NextPVR was no guide data was being returned 2017-03-04 07:36:13.290 [iNFO][59] #*** Created listing for 0 events in 0.519 seconds. In the future if this happens again you would need to confirm there was guide data in NextPVR and on a Kodi refresh and report that on the NextPVR forum. Martin Edited March 5, 2017 by emveepee
DParsons 4 Posted March 8, 2017 Author Posted March 8, 2017 Hello Martin these are the logs from today. It would have started around 2:06pm according to the time of the log entry in NextPVR. Emby logs 030817.7z
emveepee 133 Posted March 8, 2017 Posted March 8, 2017 (edited) The log you sent here are after the logs you posted on the NextPVR forums because you must have restarted Emby which doesn't help. The NextPVR logs clearly showed sending back EPG data earlier. In the earlier logs and in the Emby logs hopefully an Emby dev will find out why Emby is spamming NextPVR with /public/ManageService/Get/SortedFilteredList calls. I see one lots of 4 or more POSTS at a time 2017-03-08 14:28:03.2951 Info App: [NextPvr] Start GetTimer Async, retrieve the 'Pending' recordings 2017-03-08 14:28:03.2951 Info App: [NextPvr] Start GetTimer Async, retrieve the 'Pending' recordings 2017-03-08 14:28:03.2951 Info App: [NextPvr] Start GetTimer Async, retrieve the 'Pending' recordings 2017-03-08 14:28:03.2951 Info App: [NextPvr] Start GetTimer Async, retrieve the 'Pending' recordings 2017-03-08 14:28:03.2951 Info HttpClient: HttpClientManager POST: http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=88e749dad43c4b88ad4f1b9ed3151340 2017-03-08 14:28:03.2951 Info HttpClient: HttpClientManager POST: http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=88e749dad43c4b88ad4f1b9ed3151340 2017-03-08 14:28:03.2951 Info HttpClient: HttpClientManager POST: http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=88e749dad43c4b88ad4f1b9ed3151340 2017-03-08 14:28:03.2951 Info HttpClient: HttpClientManager POST: http://localhost:8866/public/ManageService/Get/SortedFilteredList?sid=88e749dad43c4b88ad4f1b9ed3151340 and that seems to have caused problems on the server with the 500 return but you didn't post the NextPVR side to help explain why. After that time there is significantly more spamming. I did see another thing 2017-03-08 14:29:02.7850 Info App: [NextPvr] Start CreateTimer Async for ChannelId: 7187 & Name: Criminal Minds: Beyond Borders 2017-03-08 14:29:02.7850 Info App: [NextPvr] Start GetDefaultScheduleSettings 2017-03-08 14:29:02.7850 Info HttpClient: HttpClientManager GET: http://localhost:8866/public/ScheduleService/Get/SchedSettingsObj?sid=88e749dad43c4b88ad4f1b9ed3151340 2017-03-08 14:29:02.8070 Info HttpClient: HttpClientManager POST: http://localhost:8866/public/ScheduleService/Record?sid=88e749dad43c4b88ad4f1b9ed3151340 2017-03-08 14:29:02.8681 Error HttpClient: Error getting response from http://localhost:8866/public/ScheduleService/Record?sid=88e749dad43c4b88ad4f1b9ed3151340 You may have caused an error 500 that Emby doesn't handle perhaps if your created conflicts. After all that at 2017-03-08 14:34:41 you started streaming live TV. With the transcoding going on and Emby's aggressive logging of the m3u8 playback, added to all the disk writing that NextPVR is doing to write the live tv buffer and log it's own calls, I don't doubt at all that your system could struggle. Martin Edited March 8, 2017 by emveepee 1
emveepee 133 Posted March 8, 2017 Posted March 8, 2017 (edited) I see another thing for the dev's two. For Live TV the client count seems to be incrementing. The client ID should stay static for the client not increment. 2017-03-08 14:34:41.7305 Info App: [NextPvr] Streaming http://localhost:8866/live?channeloid=7196&client=MB3.1 2017-03-08 14:47:46.3944 Info App: [NextPvr] Streaming http://localhost:8866/live?channeloid=7192&client=MB3.2 2017-03-08 17:07:26.3211 Info App: [NextPvr] Streaming http://localhost:8866/live?channeloid=7196&client=MB3.3 2017-03-08 17:12:37.3900 Info App: [NextPvr] Streaming http://localhost:8866/live?channeloid=7191&client=MB3.4 Martin Edited March 8, 2017 by emveepee 1
Luke 42239 Posted March 9, 2017 Posted March 9, 2017 @@emveepee, what if it's different clients of Emby Server, should it still be static in that situation?
emveepee 133 Posted March 9, 2017 Posted March 9, 2017 Right, different clients should maintain a static ID. When I coded that it was for simplicity but it could be anything unique the more permanent the better. This way NextPVR will know to close a live tv file if the same client connects twice freeing up tuners faster. Martin 1
Luke 42239 Posted March 9, 2017 Posted March 9, 2017 Just so I'm clear, that means one static ID shared by all of them, or one for each? Thanks !
emveepee 133 Posted March 9, 2017 Posted March 9, 2017 (edited) One unique ID for each client preferably persistent. Note that this doesn't relate to the JSON call problem. Martin Edited March 9, 2017 by emveepee
Luke 42239 Posted March 9, 2017 Posted March 9, 2017 Ok, thanks for the info. I will look into the excess calls to get the recording list. 1
pünktchen 1410 Posted March 9, 2017 Posted March 9, 2017 Ok, thanks for the info. I will look into the excess calls to get the recording list. I've already reported about spamming the tv backend with many unnecessary requests one year ago: https://emby.media/community/index.php?/topic/32135-guide-not-loading/page-4&do=findComment&comment=312379 But you've never fixed it comletely. I'm caching now your timer requests in the MediaPortal plugin, otherwise it would be unusable. 2
markyp 38 Posted April 6, 2017 Posted April 6, 2017 Live TV from 13.34.Emby.Log.txtI'm having similar issues... webclient works ok but emby just gets stuck on LiveTV... here's the log... started to stream from ITV3...
Luke 42239 Posted April 6, 2017 Posted April 6, 2017 hi @@markyp, this particular log looks OK to me. can you please describe your issue in more detail? Thanks.
markyp 38 Posted April 6, 2017 Posted April 6, 2017 When I try and access LiveTV the screen just stays blank, with the rotating progress indicator... The app doesn't then respond to any input either!
