Team-Manimal 0 Posted March 3, 2017 Posted March 3, 2017 Emby Theatre Version 2.5.38 Since the introduction of the vertical view in movies I cannot scroll down my movie list past those movies starting with K (I have 2000+ movies) I can see all my movies okay in the web app. There was similar problem with the horizontal view around the time Emby Theatre was released. Any suggestions please? Many thanks PS. Feature request – please can we have the ability to ‘sort’ movies by release date back ASAP? (i.e. similar to the web app?) as this is servery missed since the view went from Horizontal to Vertical.
Jobber8742 9 Posted March 3, 2017 Posted March 3, 2017 (edited) Same issue here. I have about 1300 movies and can't get past S. I also used the release date view quite often and would like it back, but this quantity limitation is a much more pressing issue right now because I have no way to watch the movies past that point. Edited March 3, 2017 by Jobber8742
ebr 16336 Posted March 3, 2017 Posted March 3, 2017 What if you hit one of the letters on the letter bar?
Jobber8742 9 Posted March 3, 2017 Posted March 3, 2017 What if you hit one of the letters on the letter bar? It repeats random previous letters. I can get to S. When I hit T, it shows me the A's. When I hit U, it shows me the M's, etc.
Luke 42243 Posted March 3, 2017 Posted March 3, 2017 OK thanks for the report guys, I'm looking into this.
blade005 185 Posted March 3, 2017 Posted March 3, 2017 It repeats random previous letters. I can get to S. When I hit T, it shows me the A's. When I hit U, it shows me the M's, etc. I could be wrong, but I thought the behavior I was seeing when I hit T and it jumped back to A was that it was going back to the first entry that had THE as a prefix and then followed with an A. It didn't seem to be ignoring THE, A, AN prefixes in titles.
Team-Manimal 0 Posted March 4, 2017 Author Posted March 4, 2017 Most of the letter bar seletions after K, just show the movies beginning with K, i.e the last movies that Emby will show in my movies list. Pressing 'L' in the letters bar shows movies beginning with 'B' Pressing 'P' in the letters bar shows movies beginning with 'A' Additionally sometimes when I start Emby Theatre the search and user icons at the top right of the screen do not show and I have to close then restart Emby theatre once or twice to get them to re-appear.
Jobber8742 9 Posted March 4, 2017 Posted March 4, 2017 The letters are no longer jumping, but now it just cuts off at S. It's going to be a major problem for people with moderate sized libraries if you can have more that 600-700 movies.
nicko84 72 Posted March 4, 2017 Posted March 4, 2017 (edited) Hello, Same issue. I can't access to all movies after "S", choosing a letter in the alphabet left bar or scrolling down among the movies. A little bit anoing ! Edited March 4, 2017 by nicko84
mws1047 2 Posted March 5, 2017 Posted March 5, 2017 Appreciate that this issue is being investigated. FWIW, I get a different outcome on different clients. Off the same server, with one ET I can scroll to C only when using desktop. On another only to E. On the one only able to scroll to E on a desktop, when presenting to the TV it will scroll to L. Both scrolling and selecting letters past L produces no response. My display settings are set to Auto
wex101 12 Posted March 5, 2017 Posted March 5, 2017 My wife is about to murder me over this bug. She can't get to her Twilights! Maybe if she'd learn to use a search bar
crazybbs 24 Posted March 5, 2017 Posted March 5, 2017 (edited) Guys, to help you while luke resolve the problem, you could install the plugin another users did to enable date added in movies tab, this plugin still use the old horizontal view Added paging to Movies. channel up/down should work as well. @@Nick - in ET go to Settings->Installed Plugins. Click Install Plugin->Install from URL. Paste the url https://davidtjudd.github.io/emby-web-davidskin/package.json in the textbox and click OK. Go back to Settings->Display. Set the Skin to David's Skin. Not sure about the ClearArt. Wouldn't ClearArt and DiscImages make more sense on the OSD? I think that's how most of the Kodi skins use it. Edited March 5, 2017 by crazybbs
Jobber8742 9 Posted March 8, 2017 Posted March 8, 2017 This appears to have been resolved on my system as of last night.
Solution Team-Manimal 0 Posted March 13, 2017 Author Solution Posted March 13, 2017 Emby Theatre Version 2.5.38 Since the introduction of the vertical view in movies I cannot scroll down my movie list past those movies starting with K (I have 2000+ movies) I can see all my movies okay in the web app. There was similar problem with the horizontal view around the time Emby Theatre was released. Any suggestions please? Many thanks PS. Feature request – please can we have the ability to ‘sort’ movies by release date back ASAP? (i.e. similar to the web app?) as this is servery missed since the view went from Horizontal to Vertical. Emby Theatre Version 2.5.39 seems to have fixed the problem... many thanks
