KayJay 2 Posted March 3, 2017 Posted March 3, 2017 Please help, I connected my hotspot to my computer yesterday and emby tried to download the latest version 3.2.5.0. After this all scheduled tasks were failing and the emby app itself keeps crashing and doesn't let me play my media. I've tried deleting the app and installing the stable one for the website but i get the same thing. Please find pictures of the cancelled scheduled tasks and the error log. embyerrorlog.txt embyerrorlog.txt
Luke 42197 Posted March 3, 2017 Posted March 3, 2017 Hi, the logs look OK to me. I would suggest doing the following - uninstall all plugins, then go into Emby library setup, and uncheck the boxes for chapter image extraction for each library that you've turned it on for. Once you've done this then please try it out and let us know if the issue persists. Thanks.
KayJay 2 Posted March 3, 2017 Author Posted March 3, 2017 Hi, the logs look OK to me. I would suggest doing the following - uninstall all plugins, then go into Emby library setup, and uncheck the boxes for chapter image extraction for each library that you've turned it on for. Once you've done this then please try it out and let us know if the issue persists. Thanks. Hi thanks for the suggestion. I've just uninstalled 3 plugins but the chapter image extraction wasn't checked? I've restarted Emby and tried the scheduled tasks again but it's still closing on its own?
KayJay 2 Posted March 3, 2017 Author Posted March 3, 2017 Please supply a new log, thanks. What ever has happened is now causing my computer to crash, could be something else but it keeps BSOD'ing. Here are the errors i'm getting if anyone can help: ================================================== Dump File : 030317-33796-01.dmp Crash Time : 03/03/2017 20:59:07 Bug Check String : MEMORY_MANAGEMENT Bug Check Code : 0x0000001a Parameter 1 : 00000000`00041792 Parameter 2 : ffffe7bf`ff7bf308 Parameter 3 : 00000000`20000000 Parameter 4 : 00000000`00000000 Caused By Driver : ntoskrnl.exe Caused By Address : ntoskrnl.exe+14a6f0 File Description : NT Kernel & System Product Name : Microsoft® Windows® Operating System Company : Microsoft Corporation File Version : 10.0.14393.693 (rs1_release.161220-1747) Processor : x64 Crash Address : ntoskrnl.exe+14a6f0 Stack Address 1 : Stack Address 2 : Stack Address 3 : Computer Name : Full Path : C:\WINDOWS\Minidump\030317-33796-01.dmp Processors Count : 6 Major Version : 15 Minor Version : 14393 Dump File Size : 385,628 Dump File Time : 03/03/2017 21:02:31 ================================================== ================================================== Dump File : 030317-41265-01.dmp Crash Time : 03/03/2017 20:47:19 Bug Check String : MEMORY_MANAGEMENT Bug Check Code : 0x0000001a Parameter 1 : 00000000`00041201 Parameter 2 : ffffa580`003764c8 Parameter 3 : 87c00000`79ce6025 Parameter 4 : ffffba05`175bd450 Caused By Driver : ntoskrnl.exe Caused By Address : ntoskrnl.exe+14a6f0 File Description : NT Kernel & System Product Name : Microsoft® Windows® Operating System Company : Microsoft Corporation File Version : 10.0.14393.693 (rs1_release.161220-1747) Processor : x64 Crash Address : ntoskrnl.exe+14a6f0 Stack Address 1 : Stack Address 2 : Stack Address 3 : Computer Name : Full Path : C:\WINDOWS\Minidump\030317-41265-01.dmp Processors Count : 6 Major Version : 15 Minor Version : 14393 Dump File Size : 394,916 Dump File Time : 03/03/2017 20:49:03 ================================================== ================================================== Dump File : 030317-30921-01.dmp Crash Time : 03/03/2017 19:08:57 Bug Check String : MEMORY_MANAGEMENT Bug Check Code : 0x0000001a Parameter 1 : 00000000`00004477 Parameter 2 : 00000000`20000000 Parameter 3 : 00000000`00000000 Parameter 4 : 00000000`00000000 Caused By Driver : ntoskrnl.exe Caused By Address : ntoskrnl.exe+14a6f0 File Description : NT Kernel & System Product Name : Microsoft® Windows® Operating System Company : Microsoft Corporation File Version : 10.0.14393.693 (rs1_release.161220-1747) Processor : x64 Crash Address : ntoskrnl.exe+14a6f0 Stack Address 1 : Stack Address 2 : Stack Address 3 : Computer Name : Full Path : C:\WINDOWS\Minidump\030317-30921-01.dmp Processors Count : 6 Major Version : 15 Minor Version : 14393 Dump File Size : 412,460 Dump File Time : 03/03/2017 19:11:01 ================================================== ================================================== Dump File : 030317-34093-01.dmp Crash Time : 03/03/2017 18:37:19 Bug Check String : IRQL_NOT_LESS_OR_EQUAL Bug Check Code : 0x0000000a Parameter 1 : 00000000`00000034 Parameter 2 : 00000000`00000002 Parameter 3 : 00000000`00000000 Parameter 4 : fffff803`bb0d7d89 Caused By Driver : ntoskrnl.exe Caused By Address : ntoskrnl.exe+14a6f0 File Description : NT Kernel & System Product Name : Microsoft® Windows® Operating System Company : Microsoft Corporation File Version : 10.0.14393.693 (rs1_release.161220-1747) Processor : x64 Crash Address : ntoskrnl.exe+14a6f0 Stack Address 1 : Stack Address 2 : Stack Address 3 : Computer Name : Full Path : C:\WINDOWS\Minidump\030317-34093-01.dmp Processors Count : 6 Major Version : 15 Minor Version : 14393 Dump File Size : 380,788 Dump File Time : 03/03/2017 18:38:52 ==================================================
Happy2Play 9802 Posted March 3, 2017 Posted March 3, 2017 You going to have to troubleshoot your BSOD before worring about Emby. Google suggest you run memory diagnostics.
ebr 16309 Posted March 3, 2017 Posted March 3, 2017 A BSOD is almost always a hardware driver issue. Usually either memory or graphics.
Luke 42197 Posted March 3, 2017 Posted March 3, 2017 Yea that looks like a hardware malfunction at this point, sorry.
