SwanStream 64 Posted September 11, 2022 Posted September 11, 2022 19 minutes ago, Happy2Play said: Shows and Seasons are folders that do not contain Media Info, Media Info only exists on Episodes (Audio and Video files). So for TV it will only exist on Episodes tab. Got it. I hear ya, but you know,... episodes exist within Seasons and Seasons Exist within TV shows... For the non-programmer thinking people wouldn't it be easier way-finding if the "idea" carried up the chain? I have a 85 year old ma that doesn't quite get the whole 'folders' thing, but knows she wants to find the shows (not just episodes) from her home land. She'd forgive you if every episode in that show wasn't guaranteed to be in that language exclusively. PS Thanks for pointing me in the right direction mate, just expressing a perspective... even though it likely makes programmers break out in hives!
mstar 0 Posted February 16, 2024 Posted February 16, 2024 (edited) +1 for language filter for TV Shows. Currently, I separate media by language into folders. Edited February 16, 2024 by mstar
beesyrup 10 Posted October 21, 2024 Posted October 21, 2024 Apologies for necro'ing this thread, but I would like to see this as well. In terms of a simple implementation, would it be possible to check to see if the audio track for a video file included. Thanks for your help!
Luke 42245 Posted October 21, 2024 Posted October 21, 2024 15 hours ago, beesyrup said: Apologies for necro'ing this thread, but I would like to see this as well. In terms of a simple implementation, would it be possible to check to see if the audio track for a video file included. Thanks for your help! HI, there is already a filter on audio language. 1
beesyrup 10 Posted October 22, 2024 Posted October 22, 2024 (edited) Hi @Luke, You're right. There is a Library filter. My apologies. I kept looking at the Search functionality to see if we could pass it through the search bar, but I realize you have to go into your Library (only for Movies), click on Filter, select Audio Language, and select the appropriate language code. Would like to see this on TV shows as well Edited October 22, 2024 by beesyrup Clarify that the functionality only exists for Movies. 1
