skank 85 Posted March 1, 2017 Posted March 1, 2017 Hi im85288 Nice skin ! I might use this skin for a long time, are you the same im as on emby forum?i'm using emby too, to populate library. However i have some questions, i hope you will take time to answer Look at a screenshot i made Is it possible to:- Get ride of the looking glass (green arrow)- whats the difference between the yellow (home button) and red arrow (folder icon) , is it possible to merge those 2, or get rid of one.- is it possible the have the categories items (blue arrow) place next to the other icons (pink arrow place) (my home button should be my movies button)- add an option to use/not use cases for the movie covers- is it possible to have a widget "in cinemas" and coming soon?- have other icons for categories (title, year, actor, moviestudios'...) , including colored ones?- have other icons for movie genres? i downloaded some via addon, but doesnt work?- have a nice main background, now its still Concerning emby:- i have couple of folders like- movies.HDTV, movies.BLURAY, movies.3D, movies kids 3D, movies kids.BLURAY now i want the skin to have 2 profiles: one for kids and one for adultsdo i make these profiles inside kodi or inside emby? - for adults i want: a categories movies: these should contain all, then a categorie 3D (should contain movies.3D and movies kids.3D etc etc) do i need to use smart playlists from the skin?can i have widgets for it then in the skin? Is this just the beginning of your skin or is it almost complete?
skank 85 Posted March 2, 2017 Author Posted March 2, 2017 Something is seriously wrong with the skin with multiple profiles, trying to login on other profile doesnt workCan you modify the login screen so 3 icons are horizontal next to eachother instead of the left menu bar being used?
skank 85 Posted March 3, 2017 Author Posted March 3, 2017 @@im85288? and others for other info i asked?
im85288 1493 Posted March 6, 2017 Posted March 6, 2017 Hi @@skank - yes this is my skin and yes I think there is only one im85288 As for your questions/queries etc, I hardly ever have time for skinning these days so do not update the skin very often. To answer one of your more important questions: "- whats the difference between the yellow (home button) and red arrow (folder icon) , is it possible to merge those 2, or get rid of one." This skin is different from all the others out there in that I have a separate "Home" screen which has 13 configurable widgets, the home button servers two purposes....1 - it takes you to the home screen when in library mode, 2 - it brings up the widget configuration when already on the home screen. So to summarize, do not expect quick support with this skin. If there is any urgent bugs I will attempt to resolve them though as this is the skin I use on my various kodi installs.
skank 85 Posted March 7, 2017 Author Posted March 7, 2017 Aha thx for the response Ok for not updating frequently however, 2 things if you could theres a bug i think with multiple profiles, trying to login one profile gives strange stuff its unuseable the other stuff, i see about home screne, but can i merge those 2 ?
im85288 1493 Posted March 7, 2017 Posted March 7, 2017 Aha thx for the response Ok for not updating frequently however, 2 things if you could theres a bug i think with multiple profiles, trying to login one profile gives strange stuff its unuseable the other stuff, i see about home screne, but can i merge those 2 ? Can you check in the default Estuary skin to see if the multiple profile problem is there too? My version is very much based on the default skin so I would expect things to work the same....so it may actually be a general problem rather than one specific to this skin. No you cannot merge the two home screens together as the "home" one is custom for this skin....you can use the library mode if you want the behavior of the default estuary skin (but with support for creating custom menu items etc using skin shortcuts)
skank 85 Posted March 8, 2017 Author Posted March 8, 2017 Can you check in the default Estuary skin to see if the multiple profile problem is there too? My version is very much based on the default skin so I would expect things to work the same....so it may actually be a general problem rather than one specific to this skin. No you cannot merge the two home screens together as the "home" one is custom for this skin....you can use the library mode if you want the behavior of the default estuary skin (but with support for creating custom menu items etc using skin shortcuts) i checked with normal default estuary skin, no problems with multiple users, everything works With your mod, things are fu**ed up when using multiple users 1
im85288 1493 Posted March 8, 2017 Posted March 8, 2017 Ok thanks, maybe next update it may be resolved
skank 85 Posted March 14, 2017 Author Posted March 14, 2017 Any idea when you're next update will be? Eagerly waiting for the fix
im85288 1493 Posted March 15, 2017 Posted March 15, 2017 Any idea when you're next update will be? Eagerly waiting for the fix Sorry no ETA I'm afraid...it's on my todo list though
