Happy2Play 9802 Posted March 1, 2017 Posted March 1, 2017 (edited) Okay then you need to go to the Metadata Manager and set your TV parent folder to content type TV. Edit- Once you have done that you will need to perform a Library Scan. Edited March 1, 2017 by Happy2Play
Happy2Play 9802 Posted March 1, 2017 Posted March 1, 2017 (edited) Example of nested effect (only affects TV content) I have a action folder inside my TV library so if the content type is not set then Action become a Series and everything under it is mis-organized in Emby. So making it type TV test Emby everything in this folder is a Series. Hope this makes sense. Not exactly like your issue but the same. In your example K:\Media\TV is misidentified as "Scream: The TV Series" Edited March 1, 2017 by Happy2Play
x88dually 9 Posted March 1, 2017 Author Posted March 1, 2017 happy, i had that happen once but dont remember which version or time it happened. Your example is exactly my problem !! I'm glad someone knows what i'm doing. lol havent done a library scan on new install yet.
x88dually 9 Posted March 1, 2017 Author Posted March 1, 2017 on main server, content type on all movie and tv is set to inherit, and everything is right with matadata. should i change tv listing to tv content or leave well enuff alone ?
x88dually 9 Posted March 1, 2017 Author Posted March 1, 2017 in metadata man, listed under title, orig title and sort title. Date added says 2016-11-18. i dont get it ?
Happy2Play 9802 Posted March 1, 2017 Posted March 1, 2017 (edited) on main server, content type on all movie and tv is set to inherit, and everything is right with matadata. should i change tv listing to tv content or leave well enuff alone ? If your library folders are x:\media for TV and not x:\media\tv then yes you have to change the type from inherit to TV for your TV libraries. The only exception is if all your series folders fall directly in the x:\media folder. But your logs don't show that. Edited March 1, 2017 by Happy2Play
x88dually 9 Posted March 1, 2017 Author Posted March 1, 2017 (edited) ok thx. Should i change the other servers from inherit to tv ? and have to do a library scan ? What about the movie folders ? Edited March 1, 2017 by x88dually
Happy2Play 9802 Posted March 1, 2017 Posted March 1, 2017 (edited) Movie folders are not a issue, just TV do to additional season structures. Assuming this is you issues you should change it on all servers, then a library scan should resolve the nesting issue. ***Setting this is all dependent on Folder structure and how your libraries are created in Emby. Edited March 1, 2017 by Happy2Play
Happy2Play 9802 Posted March 1, 2017 Posted March 1, 2017 Let up know if this resolves the issue you were having.
ebr 16309 Posted March 1, 2017 Posted March 1, 2017 is X: a physical drive attached to the server or a mapped network drive?
Happy2Play 9802 Posted March 1, 2017 Posted March 1, 2017 is X: a physical drive attached to the server or a mapped network drive? That was my example OP is setting a Unset Library with these folders. under libraries where you add folders to be scanned into library : K:\Media click add, done, next folder M:\Media L:\Media done, click save an the rest is above. should i go into every season folder looking for series nfo files ?
