nilpetreli 1 Posted February 27, 2017 Posted February 27, 2017 Hi Guys I am trying to connect remotely but get connection failure Firewall is switched off and CanYouSeeMe.org says Error: I could not see your service on 8*.**.***.* on port (8096) Any ideas?
Luke 42197 Posted February 27, 2017 Posted February 27, 2017 Hi @@nilpetreli, welcome. I would suggest checking out our Connection Troubleshooter. Please try the steps listed there and let us know exactly which ones succeed and which ones fail. Thanks !
Solution nilpetreli 1 Posted March 1, 2017 Author Solution Posted March 1, 2017 Thank you. Got it sorted. It was the port forwarding which was the problem. I had to make sure the WAN Type matched the WAN interface when setting it up. 1
