PhyberApex 16 Posted March 25, 2018 Posted March 25, 2018 (edited) Can you tell me what server version, app, transcoding? I can try and test it today Server Version 3.3.1.0, Client was emby for kodi latest beta, and no transcoding but IIRC that did not matter. I'm 100% sure it happend on direct stream tho. ~Cheers Edited March 25, 2018 by PhyberApex
Angelblue05 4132 Posted March 25, 2018 Posted March 25, 2018 (edited) It's a bug with the websocket progress report. It's only cosmetic. In emby for kodi, I changed playback report to http in the beta version which resolves this bug. I'll push to stable beginning of the week. Sent from my iPhone using Tapatalk Edited March 25, 2018 by Angelblue05 1
NeauxGeaux 9 Posted August 3, 2018 Posted August 3, 2018 @@randomevents It appears as of Version 3.5+ the web hooks aren't getting triggered. 1
Volfan6415 19 Posted September 14, 2018 Posted September 14, 2018 I am showing this as well. Just noticed that my webhooks are no longer working. I am seeing the following in my logs 2018-09-13 18:46:26.052 Error App: Error creating Emby.WebHooks.WebHooks *** Error Report *** Version: 3.5.2.0
Luke 42255 Posted September 14, 2018 Posted September 14, 2018 It's possible the plugin needs an update.
PhyberApex 16 Posted September 15, 2018 Posted September 15, 2018 Version 3.6.0.2 beta here. Working as intended on my debian. ~Cheers
Volfan6415 19 Posted September 20, 2018 Posted September 20, 2018 I am running on 3.5.2 so perhaps there is something in beta that fixes it
hstamas 179 Posted December 2, 2018 Posted December 2, 2018 (edited) I am running on 3.5.2 so perhaps there is something in beta that fixes it I just installed beta 3.6 and can confirm that this plugin still works. Edited December 3, 2018 by hstamas 1
Keo 3 Posted December 16, 2018 Posted December 16, 2018 How do you install plugins not in the catalog?
Luke 42255 Posted December 16, 2018 Posted December 16, 2018 You need to be able to compile the plugin source code to a .dll file and then copy that .dll file into the server's plugins folder.
hstamas 179 Posted December 16, 2018 Posted December 16, 2018 I How do you install plugins not in the catalog? I believe the release download is already compiled. https://github.com/nxenos83/emby.plugin.Webhooks/releases Note that Emby's plugin folder is hidden by default (at least it is on Mac OS) so you would either need to copy it over via a commma d prompt or shoe hidden files and folders.
Keo 3 Posted December 19, 2018 Posted December 19, 2018 I I believe the release download is already compiled. https://github.com/nxenos83/emby.plugin.Webhooks/releases Note that Emby's plugin folder is hidden by default (at least it is on Mac OS) so you would either need to copy it over via a commma d prompt or shoe hidden files and folders. Any advice on how to trouble shoot this? I have it configured to send an event on playback, but my webserver never receives anything. I have the port and IP correct in my URL. Is there anyway for me to see the send logs from emby?
Luke 42255 Posted December 19, 2018 Posted December 19, 2018 It will probably be in the emby server log.
Keo 3 Posted December 19, 2018 Posted December 19, 2018 I took some time tonight to expand your work and fill in some of the gaps for use in my own tool -: { "event": "media.play", "user": false, "owner": false, "Account": { "id": "redacted", "title": "redacted" }, "Server": { "title": "redacted", "uuid": "redacted" }, "Player": { "local": true, "publicAddress": "192.168.1.110", "title": "Emby Mobile", "uuid": "redacted", "name": "Chrome" }, "Metadata": { "guid": "28e0459a-a0a2-acc1-8af2-fd4048131dd6", "librarySectionID": 0, "type": "music", "title": "Major Tom (völlig losgelöst)", "grandparentTitle": "Atomic Blonde", "parentTitle": "Atomic Blonde OST", "index": 2, "ratingCount": 0, "addedAt": 0, "updatedAt": 0, "runTimeTicks": 2992590080 }, "Session": { "sessionId": "804e5453f78093d5d63288ab20edfe22", "positionTicks": 0, "timestamp": "2017-11-11 02:53:51.663" } } Submitted a PR in case you're interested. I don't suppose you have a compiled version of this dll that you'd be willing to share would you? You are displaying much of the data I want.
Luke 42255 Posted May 2, 2019 Posted May 2, 2019 Any update? It has stopped working several days ago Hi there @@jibenito, since this is built by a volunteer community member, I think you'll be more likely to get a response if you can provide more information. The first thing I would do is describe what "stopped working" means. A server log would be helpful as well. Thanks. 1
PhyberApex 16 Posted July 17, 2019 Posted July 17, 2019 (edited) As nobody seemed to be working on this anymore I forked the repo and updated it to the newest stable version. You can find it over here. Will probably add a release within the next few days / weeks but it is compilable and works as of now ~Cheers. Edited July 17, 2019 by PhyberApex 1
Luke 42255 Posted October 22, 2019 Posted October 22, 2019 There will be a new webhooks plugin with the upcoming Emby Server 4.3: https://emby.media/community/index.php?/topic/77969-new-webhooks-plugin/
JustEric78 24 Posted February 25, 2020 Posted February 25, 2020 In case anyone is searching for information on being able to trigger multiple different IFTTT applets via the Emby webhooks plugin. I just posted a walk through using a third party that was willing to build this functionality out for us via their site. https://emby.media/community/index.php?/topic/82998-webhooks-free-method-to-trigger-different-ifttt-applets-using-httpssequematiccom-walk-through/
