ebr 16332 Posted February 7, 2014 Posted February 7, 2014 It already is for the next version. Longer titles will scroll.
lja 51 Posted February 7, 2014 Author Posted February 7, 2014 (edited) Great. Will keep playing with my other issue. Hoping a future release will resolve it. Edited February 7, 2014 by lja
lja 51 Posted February 7, 2014 Author Posted February 7, 2014 (edited) @ebr: Just tried dev 3.0.3.6 The long title scrolls but sometimes one letter remains on the poster. Hope you will still consider the weather inclusion. Edited February 7, 2014 by lja
ebr 16332 Posted February 8, 2014 Posted February 8, 2014 Just as a wild stab please try this version and see if the backgrounds are the right size in the List view.
lja 51 Posted February 8, 2014 Author Posted February 8, 2014 Just as a wild stab please try this version and see if the backgrounds are the right size in the List view. Are you referring to this image previously posted?
ebr 16332 Posted February 8, 2014 Posted February 8, 2014 Yes, that backdrop should not be extending all the way under the list.
lja 51 Posted February 8, 2014 Author Posted February 8, 2014 Yes, that backdrop should not be extending all the way under the list. Still the same. Would the size of the backdrops affect it?
ebr 16332 Posted February 8, 2014 Posted February 8, 2014 No the size of the backdrops have no effect. I still cannot reproduce this no matter what I try so it is almost impossible for me to fix.
ebr 16332 Posted February 8, 2014 Posted February 8, 2014 Do you have anything in the overscanscaling or overscanpadding elements in your config file?
lja 51 Posted February 8, 2014 Author Posted February 8, 2014 Do you have anything in the overscanscaling or overscanpadding elements in your config file? Overscanscaling:yes. The adjustment was made to fit my 2.37 screen.
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 Okay, so that explains why everything is squished sideways on your screen caps. You don't have a lens, you are scaling MB? Please try removing that (resetting to 0) and see what happens.
lja 51 Posted February 9, 2014 Author Posted February 9, 2014 Okay, so that explains why everything is squished sideways on your screen caps. You don't have a lens, you are scaling MB? Please try removing that (resetting to 0) and see what happens. The original setting was 1 and I previously returned it to 1 but that made no difference with the backdrop behind the list. Setting the adjustment to 0 gave a black screen in list view.
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 Yeah, sorry it should have been one. BUT, was it only the list view that had a problem when it was set to 0...?
lja 51 Posted February 9, 2014 Author Posted February 9, 2014 Yeah, sorry it should have been one. BUT, was it only the list view that had a problem when it was set to 0...? Actually, the only screen to show was the initial slash welcome.
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 Does your CoverFlow view exhibit the same problem (the backdrop going under the description)?
lja 51 Posted February 9, 2014 Author Posted February 9, 2014 Does your CoverFlow view exhibit the same problem (the backdrop going under the description)? Yes. However could you post an image of what it should look like? Just wish to be sure. Thanks.
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 It should look like this: Try this version of Chocolate. It isn't a fix per-se but it will give me a clue as to what is causing the issue if the issue goes away.
trusselo 225 Posted February 9, 2014 Posted February 9, 2014 if you need anyone to verify any of this on an other 1440x900 screen (16:10 aspect). let me know i have 3.
lja 51 Posted February 9, 2014 Author Posted February 9, 2014 Okay, re-download and try again... No change again. I do not usually use coverflow so I have just noticed also that the info at the top left is not as intended. https://dl.dropboxusercontent.com/u/19298307/cf.PNG
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 if you need anyone to verify any of this on an other 1440x900 screen (16:10 aspect). let me know i have 3. Are you having the same problem he is?
lja 51 Posted February 9, 2014 Author Posted February 9, 2014 I kept a PC on MBClassic 117 and Chocolate 3.0.3.1 and everything looks as intended still using the same monitor. The PC with the updates is on MBClassic 125.
ebr 16332 Posted February 9, 2014 Posted February 9, 2014 I think all of this screen resolution stuff is a red herring. LJA - do you have the EHS disabled? Try this version...
trusselo 225 Posted February 9, 2014 Posted February 9, 2014 not having and never have seen any of the issues in this thread. my config page, list views all look fine.
